Old 07-04-2002, 01:14 AM   #3136
shrekair's Avatar
Trader Rating: 9 (91%+)
attn all XXX-S drivers
TEAM PRP known for after market PRO3 chassis and top decks is going into the design phase to make a few products for the
XXX-S. we are currently thinking about an improved shocktower w/ more adjustment. possibly in the distant future a woven chassis w/ machined bulkheads and a a top brace. what would you like to see? any specific parts that could be made from woven graphite that u can dream up?
Input always appreciated
James Edwards
Team PRP
shrekair is offline   Reply With Quote
Old 07-04-2002, 02:39 AM   #3137
Trader Rating: 68 (100%+)
i would love to see a xxx-s woven graphite chassis and shock towers, but i hope the sealed drivetrain is retained. maybe a woven graphite chassis with a separate lighweight molded lexan sealed drivetrain tunnel. then an upper deck to join the front and rear bulkheads. but for starters, i would be happy with just the carbon fiber shock towers and maybe a battery brace.
marvi is offline   Reply With Quote
Old 07-04-2002, 04:17 AM   #3138
I would love to see a Woven Carno Graphite shock tower with more holes for chamber adjustment, and more holes for shock adjustment under US$10 each.
ongbenghui is offline   Reply With Quote
Old 07-04-2002, 07:37 AM   #3139
Marvi:
I know where you can find all the graphite parts. You can buy them in binondo you look for cheri she can give you all the necessary arrangements at a closed room conference.
rctech is offline   Reply With Quote
Old 07-04-2002, 09:24 AM   #3140
Fire's Avatar
it's like one step forward and two steps back for getting a double deck chassis for the xxxs.....
Fire is offline   Reply With Quote
Old 07-04-2002, 09:48 AM   #3141
STLNLST's Avatar
Trader Rating: 21 (100%+)
James Edwards
Team PRP
The shock towers would be something to mess around with but the chassis wouldn't be worth doing (IMO) because you would lose the sealed drive train and the chassis as it sits now is one of the best designs I've seen. The wiring tunnel would be lost and the way it's molded for the shock towers to lock into place would be gone. The best thing an after market company could do for the car (again IMO) is re-design the front and rear bumpers so that they don't flex as much. The shock towers only really needs another row of camber locations. If you add too many holes to the shock mounting locations you are going to end up with the Xray shock tower. A racer could dial themselves out with that much adjustment. What ever you come out with I'm sure you would've tested the crap out of it so when it does hit the shops the racer can just put it on and go. Good luck with whatever you come out with.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-04-2002, 09:56 AM   #3142
OBY
OBY's Avatar
here's the aluminium bits....sorry the pics are bad but it wasnt my camera!!
OBY is offline   Reply With Quote
Old 07-04-2002, 09:57 AM   #3143
OBY
OBY's Avatar
again...
Old 07-04-2002, 09:59 AM   #3144
OBY
OBY's Avatar
lala...
Old 07-04-2002, 10:00 AM   #3145
OBY
OBY's Avatar
http://www.cmldistribution.co.uk/fast_xxxs.htm
all excellent quality and very cheap!! and blue!!!!
Old 07-04-2002, 10:41 AM   #3146
Trader Rating: 23 (100%+)
If it is a race to market, the graphite plate shock towers have already been done based on the standard holes and new towers are in test that include additional mounting locations.
As for the graphite main chassis; the tunnel besides providing a sealed system also provides a rigid form for the chassis.
A graphite main would take some good thought and its application my provide limited tuneability but for the aesthetic my provide a good WOW part.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-04-2002, 06:03 PM   #3147
Default e-clip for hinge pin
Hi OBY,
what is the size of e-clip you use for hinge pin ?
Old 07-04-2002, 08:21 PM   #3148
Fire's Avatar
2mm ones will fit~~
is there any special way or tips about building the shocks?? I can't get all the air out of the shocks and it keep making some squeeky sound
Old 07-04-2002, 08:48 PM   #3149
rctech: ok, ill just give you money for the stuff you mentioned. i called you up last night and they said you were still in binondo with your date, looking for graphite parts. ill get it from you this weekend when we try out your repaired v6. be sure to bring a fire extinguisher because last time i used that esc, it smoked
Old 07-04-2002, 09:19 PM   #3150
STLNLST's Avatar
Default Re: e-clip for hinge pin
Originally posted by ongbenghui
Hi OBY,
Here's the clips that I use on my hinge pins.
Team Losi part # A-6103 (3/32)
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
