Old 06-27-2002, 01:24 PM   #3106
yodace's Avatar
R/C Tech Charter Subscriber
how do you tell if your hingpin angles are different from one side to another? MY look equal on both sides.
yodace is offline   Reply With Quote
Old 06-27-2002, 01:27 PM   #3107
yodace's Avatar
were could I find pics of a newer XXX S, the one your describing?
Old 06-27-2002, 03:02 PM   #3108
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
AE-Racer, those cvds cost me $29. The auction was at $21 with 3min to go and a bidding war broke out. It was a matter of me really wanting them. I wanted a pair for the rear only.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 06-27-2002, 03:05 PM   #3109
ASM
ASM's Avatar
Fire, the MF bumper is in one the pics I posted. It's much more dense than the stock one as TSR6 stated.
Scott Meeks
USVTA Member #116
Old 06-27-2002, 03:53 PM   #3110
Trips's Avatar
Trader Rating: 16 (100%+)
I used some 10 inch long pieces of 3/32 music wire. I mounted the arms, then stuck the music wire through the outer hinge pin holes in the arms. I then checked the angle of the wire in relation to the sides of the chassis. It looked identical on both sides.
Then I took the same pieces of music wire and stuck them through both hub carriers and tightened the setscrews. When I placed the hub carriers on a flat board, the wires should have been parallel. They weren't.
I don't have the Losi anymore, or I'd take some pictures of what I'm trying to describe.
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-27-2002, 04:17 PM   #3111
yodace's Avatar
I think I understand.
Why did you sale the losi?
Old 06-27-2002, 04:32 PM   #3112
yodace's Avatar
Looks different to me>
The hub carriers have a lower and upper holes, and the rear pivot block looks different. Does anybody know if this upgrades are out yet.
Old 06-27-2002, 05:03 PM   #3113
Fire's Avatar
thanks for the info on the bumper guys~~
hopefully i don't need to replace one in the near future
i think the rear toe has something to do with the inner front pivot block, if let it alone when tightening it then will pointing at different angles
Fire is offline   Reply With Quote
Old 06-27-2002, 06:34 PM   #3114
Trips's Avatar
I wanted to try a Yok SP, had to sell one to get the other. Money's tight lately.
T
MARSHAL!!
Old 06-27-2002, 08:08 PM   #3115
yodace's Avatar
I used to have a Yok Sp> Sold it.
Old 06-27-2002, 09:34 PM   #3116
shrekair's Avatar
Trader Rating: 9 (91%+)
it's the same brace, it has just been shaved for weight.
deutch - all i would add to your bill is a 64 pitch 118 or 128 tooth spur gear. at that point you shouldnt need anything else. but if you think about tuning options you may want to get different graphite castor blocks, and different degree rear toe blocks.
shrekair is offline   Reply With Quote
Old 06-27-2002, 10:48 PM   #3117
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
deutch-
If you are going to run rubber tires, on any kind of medium to high traction surface, you'll likely be needing a oneway. You don't really need anything aluminum - maybe the pivot blocks for low and high roll center once you get into setup mode.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 06-27-2002, 10:54 PM   #3118
Fire's Avatar
Does the belt suppose to move left and right while the motor is spinning?? seems like the rear diff has some sideway movements, is that normal??
Old 06-27-2002, 11:13 PM   #3119
Trips's Avatar
It's been reported before, seems like it's a normal thing when the car is new, and the side to side movement of the belt goes away after it's been run a while.It's normal for a diff to have a bit of side to side play, assuming you mean the pulley is free to wobble slightly. The entire diff shouldn't have any significant side to side movement in the bulkhead tho.
Trips
MARSHAL!!
Old 06-28-2002, 06:27 AM   #3120
Thanks for the info, guys.
One more question: What bearing and diff lube do you guys recommend? Does it really matter?
BTY, this board has a ton of useful info and has made my decision making process much easier.
Thanks again.
Deutch is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
