Losi XXX-S
#3091
When you buy the bumper you get one pair of short screws to be used with out a sway bar set-up, and a pair of longer screws with 2 small washers to be used with the sway bar. Directions come as well. The front end now has a nice solid feeling, which is what I was looking for.
#3092
R/C Tech Founder
Does that carbon fiber brace hold up well under hard racing conditions?
#3093
ahh yes, eye candy. but the nice old boards here dont like eye candy too much. will it support hard nosed rubbin?
#3094
the TMF kydex bumbers are a joke
#3096
It wasn't bought to be eye candy. Yes, it'll hold up better than anything currently on the market. If carbon fiber front ends hold up to the speeds and impacts of oval racing, then I'm sure it'll handle that of sedan racing.
Is it completely unbreakable? Certainly not.......is anything? Will it work for me....which is why I bought.....of course. I posted those pics to let you guys be aware of what's available out there for you. Doesn't mean it's right for everyone, or appeals to everyone. Just sharing info.......
Are the shock towers needed? Probably not. I'm using speed techs cause I had a little cash to burn from e-bay sales. Is the bumper brace needed? For me, it was.
#3097
i like the bumper brace
the foam bumper came with the kit is too soft to support itself just using the 2 body posts.
does trinity make a foam bumper for xxxs that is similar to the one they made for the TC3?
#3098
ASM, how much did you pay for those red CVDs?
#3099
i dont even run a foam bumper anymore!!!
i'm gonna try and post pics of my car with blue aluminium bits on it tomorrow...
#3100
Originally posted by Sydewynder
Are you 100% positive is all the rear uprights? The hingepin angles don't look the same to me.
Already did the change in the degree on the upright. Did anybody let Losi know?
When I built my first XXX-S I called Losi about the unequal rear toe, and I was told that it was just an optical illusion and not to worry about it. After looking at others I put a few cars on the Hudy setup gauges and could clearly see that there was a difference. The next time I called Losi about it I mentioned that it not only looked wrong to the eye, but measured wrong on the setup gauges. That time they told me it was normal production tolerances and not to worry about it.
I worried about it anyway, finally I went with a 1/2 degree right hub carrier to even things up. Made the car feel a lot better too.
Trips
#3101
#3102
Yokomo Foam Bumpers fit with a little cutting
#3103
Hey guys,
I am looking at getting back into R/C racing. I used to race on carpet with the original RC10L, JRX2 and an LXT on dirt about 10-12 years ago. I was consistently first in the mod A-main.
I have narrowed down my decision to get the xxx-s over the TC3. I need advise on what I should get along with the basic kit. I had planned on getting the graphite conversion, titanium pins and turnbuckles, and threaded shocks. Money isn't too much of a concern but I don't want to spend a $hitload, and I want to get everything that I might need in the future. I am not sure if I should get any of the aluminum stuff, but I don't want to have to completely disassemble the car to put a few parts on it that I might need down the road. What do you guys recommend???
#3104
Threaded shocks and titanium turnbuckles are a biggie. Make sure you get the "shortened" shocks for the front. Most of the aluminum stuff isn't super necessary, but the aluminum motor clamp is a good idea.
#3105
Originally posted by Trips
I'm not 100% positive that the hingpin angles are equal on every XXX-S out there, but they were equal on mine. I used a couple of long 3/32 piano wire rods throuigh the outer holes in the arms to check.
Trips
Trips
I see the pic of the updated car also has new rear uprights and maybe arms in addition to the shock tower and outer hingepin mount.
