Old 06-18-2002, 12:45 PM   #3001
Default 3000!
Number 3000 to me (I hope, what an honour....)
This is one HUGE thread. Has anyone considered restarting it?
XXXS is offline   Reply With Quote
Old 06-18-2002, 01:49 PM   #3002
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: 3000!
Oh heck no! Everything you need to know about the XXX-S is somewhere in this thread.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-18-2002, 03:05 PM   #3003
Tech Legend
Cain's Avatar
Trader Rating: 223 (100%+)
are the TC3 front hub carriers the same as the XXXS carriers? reason I ask is I saw some aluminum ones on Ebay that I can swear look like my XXXS ones.
Got a pretty good Deal on a TC3 on ebay, all graphite with a lot of extras. Anyone want it
Old 06-18-2002, 03:06 PM   #3004
Tech Legend
Cain's Avatar
Also, how have you mounted your TC2 Cyclone on your XXXS? I picked up a TC3 for the speedo but I am trying to figure out the best way to mount it with that big power capacitor and all. Let me know!
Old 06-18-2002, 03:07 PM   #3005
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
the tc3 parts are not exactly the same, but with some modification they will work...
Matt M. is offline   Reply With Quote
Old 06-18-2002, 03:36 PM   #3006
Fire's Avatar
is there some special way to use the set screw to secure the hinge pins??
of the 4 pins on the car only one set screw actually hold the hing pin in place.........
Fire is offline   Reply With Quote
Old 06-18-2002, 03:43 PM   #3007
R/C Tech Founder
R/C Tech Charter Subscriber
Usually that happens because the first time the set screws were screwed in, the plastic/graphite got stripped.
When I put them in on the Losi, I screw the set screw in a little bit at the time with the hinge pin out, and clear excess material from the hinge pin hole as I go. This lets the screw "tap" the inside of the carrier without having the extra resistance on it, which could cause stripping.
Then, once the hinge pin goes in, the set screw should be able to better grip against it.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 06-18-2002, 03:46 PM   #3008
Either do that or do what I do......attach e-clips to each end of the hingepin. With one gold washer on the backside of the pin you'll never have to worry about them sliding around.
Schuie Driver is offline   Reply With Quote
Old 06-18-2002, 04:01 PM   #3009
Fire's Avatar
thanks for the tips~~
i guess they are stripped now
which sized's eclips should i get for the hinge pins??
Old 06-18-2002, 07:06 PM   #3010
Tech Legend
Cain's Avatar
I am going to be running stick packs in my XXXS (race rules) and I want to better secure the pack as when looking at it and checking it the battery seems to be able to fly out really easy. Racers where i race at have mounted the battery strap post on the side so it holds the pack in, but I would like to try something else so I don't have to modify my chassis. I am thinking of using velcro and strapping the battery to the hold down brace.
Anyone else running into this issue?
Old 06-18-2002, 08:36 PM   #3011
Trader Rating: 62 (100%+)
cain: im using side-by-side packs and theyre also a bit loose on the battery brace. i inserted a strip of foam tire insert in between the battery and the brace to prevent the pack from sliding off. ive been through heavy crashes already but the battery stays put.
fire: i used a tamiya 2mm e-clips part no. 50588 for the outer hinge pins. just put a small washer behind them so they wont slide.
marvi is offline   Reply With Quote
Old 06-18-2002, 08:40 PM   #3012
RCTech Member #2
TSR6's Avatar
Cain - I used ShoeGoo to attach the capacitor both to the backside of the ESC, and to the edge of the chassis. I used a healthy amount of ShoeGoo, and it has never come off.
Old Image, but you should get the point: http://www.shearracing.com/tsr6/xxxs/losichassis1.jpg
( and no, the rear suspension arm is nowhere near the capacitor, It has plenty of clearance, the picture is decieving from where it was taken. )
Troy
RCTech Member #2
Old 06-18-2002, 11:28 PM   #3013
i used to have that problem of the batterys sliding around in the losi brace. i had a pack fan out in the brace because of a hit from another car. i shoe gooed a few packs with success then i tryed to use tc3 foam batteryspacer that worked until i lost it. but the insert trick seems like a good idea also. another problem with the battery holding system. the battery post stretch from trying to hold the batterys in place. has any one heard of the alum. battery posts? has any one bought them?who makes them? thanks guys
ROLLINGaFTGT is offline   Reply With Quote
Old 06-18-2002, 11:51 PM   #3014
Send a message via AIM to ZER01
Here's my method. I guess you could say my car has a higher center of gravity but there's no way in hell my cap is falling off and since I race outdoors there's no hole in my gear cover to let them little diff/spur/pinion eatin' rocks in
ZER01 is offline   Reply With Quote
Old 06-19-2002, 05:30 AM   #3015
Tech Legend
Cain's Avatar
I have never had my side x side packs fly out, even in brutal crashs where everything stayed where it was supposed to be. As for the foam tire thing on the side that seems interesting but I think it may still over power out the side. I have a TC3 coming in so I am going to gut it for the TC2 Cylcone and probably the hexes and foam spacer. Has anyone tried the velcro around the strap method? Who sells the cheapest aluminum hold down strap?
as for the capacitor, I may just mount it with some servo tape to the spur gear cover right before the button hold down screws. Or, that mounting to the wires looks pretty trick.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
