Old 08-19-2001, 08:13 PM   #16
HarshGuy's Avatar
Hey guys, there is a XXX-S thread going on www.rcracing.com ...it's gotten a good amounts of posts if interetsted.
HarshGuy is offline   Reply With Quote
Old 08-19-2001, 08:14 PM   #17
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i raced my sedan today....veryfast...troy...that wwas not a "lsight push"...that was major....go to losis site and get pauls nats setup....that is what i used.....i have bearings in mine, it does not have much slop....
Matt M. is offline   Reply With Quote
Old 08-19-2001, 08:14 PM   #18
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Cool
Well, if you work at your LHS, and can get them cheap, that's great! But for the x-tra 75 dollars, I don't think I would notice a difference.
Speedo is offline   Reply With Quote
Old 08-19-2001, 08:23 PM   #19
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Matt - Maybe... I guess i'm use to being loose all the time, so it was a welcome change. I'll try that setup, and maybe play with the camber-gain like what you did. For the box setup, i didnt think it was bad.
Speedo - Boca Sportsman don't cost that much. They are just a little more than Dynamite's red seals if i remember correctly.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-19-2001, 08:35 PM   #20
Moderator
Speedo's Avatar
Cool
The stock kit bearings seem to work well for me. I will probably order some bearings from that site, just to see though...cause the prices are great.
Speedo
Old 08-19-2001, 08:51 PM   #21
Administrator
Matt M.'s Avatar
i put bocas ceramic bearings in the clutch of my xxxnt, last year....guess what...they are still in great shape....so i guess it was money well spent...
Old 08-19-2001, 08:52 PM   #22
Moderator
Speedo's Avatar
Cool
I'm sure they are good, I'm just saying that the good ones are a little too pricey for me.
Old 08-19-2001, 08:54 PM   #23
AE_Racer's Avatar
Send a message via AIM to AE_Racer
I ran my L30 on bocas, very smooth
AE_Racer is offline   Reply With Quote
Old 08-19-2001, 08:56 PM   #24
Moderator
Speedo's Avatar
Cool
Cool, I was looking at them at a time, but then I saw the price, I wanted their ultra seal for my XXX.
Old 08-19-2001, 09:00 PM   #25
Administrator
Matt M.'s Avatar
well, if any one has any xxx-s setup questions ask away, if i can't answer, i can ask paul lemieux...i will also see if i can get him to come on here periodically...
Old 08-19-2001, 09:12 PM   #26
Trader Rating: 19 (100%+)
New gear from the Losi camp:
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-19-2001, 09:26 PM   #27
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Troy-
Try shortening the rear camber link one hole on the rear tower, that will let the rear end dump over a little in the rear and give you the steering you are looking for more than likely.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 08-20-2001, 05:41 AM   #28
Suspended
This may sound crazy to everyone, but I just wanted to share a little experimenting that I did this weekend.
I have a Novak TC2 and Tekin G-10 Pro. I have never used the Tekin and decided to give it a try. I liked the idea that you could change the parameters without a pit wizard.
After several packs, I have determined that the tekin is going to be the SC for racing for me.
Just thought I might share this.
Troy, this sweet spot? how did you determine it? I am still strugling trying to find it myself. The factory drivers all say they are running the belt tensioner as loose as they can, but when I do that, bbbbrrrrrrrrrrrgggggggghhhh goes the belt. Another issue that I came up with yesterday is gear mesh. I never gave it much thought until the second pack I went to accelerate and the car was noisier than a TC3. Had to do the old paper trick.
MASTER XXX-S is offline   Reply With Quote
Old 08-20-2001, 06:20 AM   #29
Administrator
Matt M.'s Avatar
i also had a tekin g10...it was a great esc...every bit as good as a novak....but with tekins rumored problems...i swiched to novak...
as for the belt, in stock i run mine fairly loose, as in almost as loose as i can get...now in mod, i have it pretty tight, i have it so the belt just skips on braking....
Old 08-20-2001, 08:00 AM   #30
RCTech Member #2
TSR6's Avatar
Well, It wasn't binding, yet it only clicked about 3 times. So i called that my sweet spot. If i ran any looser, it would click llike crazy ( matt - skip was yellin at me to take it easy..nurse it around the track. I don't think he knew clicking is ok )
Troy
RCTech Member #2
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
