Old 05-29-2002, 01:32 AM   #2776
Sigearhead's Avatar
Trader Rating: 68 (100%+)
yeah, a couple of the guys at my track have the same problem and they have told me to just deal with it, they can't get rid of it either. I don't believe it affects performance, it's just annoying...
Sigearhead is offline   Reply With Quote
Old 05-29-2002, 05:04 AM   #2777
sosidge's Avatar
Has anyone heard any whispers about whether Losi are going to bring out a "Spashett Edition" or something similar of the XXX-S?
I'm thinking full Graphite parts, and threaded shocks of the right length in the kit.
Old 05-29-2002, 03:33 PM   #2778
shrekair's Avatar
Trader Rating: 9 (91%+)
i wish
shrekair is offline   Reply With Quote
Old 05-30-2002, 10:28 PM   #2779
Send a message via Yahoo to Doug Gaut
STLNLST,
Can you PLEASE post your setup from the Reedy race soon. I would love to try it at our local track this weekend!!
Doug Gaut is offline   Reply With Quote
Old 05-31-2002, 05:49 AM   #2780
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally posted by Doug Gaut
STLNLST,
I hope to get off of work early today so I will get this set up on the thread so that guys can try it out this weekend. Sorry for the delay
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-31-2002, 07:38 AM   #2781
HarshGuy's Avatar
STLNLST, what's the deal ....we make you and admin of that "other site" and you stop posting over there sup???
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-31-2002, 08:22 PM   #2782
STLNLST's Avatar
I have plenty of posts over there
Old 05-31-2002, 08:39 PM   #2783
shrekair's Avatar
what different oil/piston setups are you guys getting to work? mainly looking for carpet but anything works.
i mainly run 50/50 w/ 56 pistons f+r. or 50/50 56 front 55 rear piston. 40/40 56/55 f/r works as well , all of these are rubber tires on carpet
Old 06-01-2002, 06:06 AM   #2784
STLNLST's Avatar
Reedy Race Set Up
Front
56 piston
60 wt oil
purple sping
3mm droop
#3 hole on tower
#3 camber link position
1/2 degree of camber
4.5mm ride height
arms middle
0 kick up
4 degree caster blocks
Rear
56 piston
60wt oil
purple spring
5mm of droop
#3 hole on tower
#1 camber link position
A hole on hub
inside hole on arm
titanium ball stud used
4.5mm ride height
1/2 degree toe in blocks on the correct way (2.5 rear toe in)
arms middle
0 anti squat
batteries foward
Matt started with 80wt oil all the way around and said that he was going to go down to 60wt so I put the 60 wt in my car. He also used steel out drives in the front with the diff a little tighter than the rear. He ran his gearing at 31/128. He also ran his front arms slightly foward with one regular spacer and a .030 in the rear of the arm and one .030 spacer in the front.
I spoke to Matt today and he stayed with the 80wt oil.
Old 06-01-2002, 06:08 AM   #2785
STLNLST's Avatar
I ran 56 pistons with 50wt oil all the way around with blue spring up front and red in the rear on carpet with rubber tire's.
Old 06-01-2002, 08:16 AM   #2786
OBY
OBY's Avatar
can anyone recommend some good aluminium steering bellcranks for my xxxs?
OBY is offline   Reply With Quote
Old 06-01-2002, 09:00 AM   #2787
Thank you STLNLST!!!! Your help is appreciated.
Old 06-01-2002, 10:54 AM   #2788
STLNLST's Avatar
Doug.......next time I will have that info to you faster. I'm getting old..........LOL
Old 06-01-2002, 11:10 AM   #2789
STLNLST, what roll center were you using??
Old 06-01-2002, 12:20 PM   #2790
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default Editable Losi XXX-S Forms
On my clubs website which im the webmaster of, I have created pdf forms with editable text areas so that you could type out your setups and print them out with Adobe Acrobat Reader. Heres the kewl part, if you have the full version Adobe Acrobat, you can not only print them out but save them as well. Give it a try and tell me what you think of it, also be sure to check out our club while you are at the site. Heres the link:
http://home.midsouth.rr.com/memphisrc/setup.htm
BHenderson is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
