Old 05-24-2002, 02:02 PM   #2746
ahhh...okay, cool. thanks for your help Trips
reddew is offline   Reply With Quote
Old 05-26-2002, 07:42 AM   #2747
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
Default XXX-S Drive Train problem
I spent a better part of last night trying to fix the problem to no avail and decided its time to run it by some of the folks here in a clear manner:
When assembling my kit I noticed that my belt would tend to drift depending on the direction I would rotate the wheels (ie- forward or reverse driving). When doing forward rotation, the belt would head away from the spur gear and towards the metal tensioner assembly and rub. When doing a reverse rotation, it would head towards the spur gear.
I also noticed that the pulley would every so slightly rub the spur every so often during a complete revolution. This would give off a scraping sound. I have taken out the complete assembly and worked it to see if anything is loose and the pulley has a slight wobble to it. This wobble also seemed to be prevalent in my spur gear as well.
I also went to work on my diffs to see if it was something there. I noticed that on what I am using as my rear diff one of the bearings that goes over the drive cup and holds the diff slides very easy on and off. While the other once it gets to a point snaps on and is hard to remove. The bearing that goes on easy also seems to allow its drive cup to wobble more as if it is not a snug fit.
the pulley that makes up the rear diff seems to have a wobble in it as well when I went and tested its rotation. This was also detected when I tested my 41T pulley gear to see if my problems were being caused by a bad pulley gear. This wobble was extremely apparent.
Overall, I received a scraping sound whenever I completed rotate the drivetrain and the belt drifts. I however didn't see a wobble in the actual drive cups and I didn't see any effect on my CVDS.
As for my CVDs, one of the CVD axle was an extremely tight fit for the part that holds the set screw and now has become stuck in there as if the part wasn't formed properly. I am not sure how to get it out.
I think this about somes up the problems I am having and the help I need. I have never had an issue like this before with a kit during assembly and I am a pretty big Losi fan so to say the least this is very dissappointing. I am hoping it is something I did wrong so I can take it to someone to correct but clearly it seems as if the parts were not formed right in some way.
If you can offer any help please feel free. Even with these issues, I have seen the car perform and its a shame for the one I have to be sideline as I am still determined to race it.
Old 05-26-2002, 02:44 PM   #2748
yodace's Avatar
R/C Tech Charter Subscriber
what is a good set up for a bumpy, dusty, tight track? or what tire work best?
yodace is offline   Reply With Quote
Old 05-26-2002, 05:46 PM   #2749
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
Found a mod to increase corner speed a bit. At first it was just because i was board, I took the rear hubs and ground around .15" off the top so when you mounted the ball stud in the hole it was quite a bit lower. this makes the rear roll a lot more in the center and exiting the corner, increasing corner speed. It made it a little harder to drive but its worth the speed. I'll take a picture of it soon and post.
KeNelson03 is offline   Reply With Quote
Old 05-26-2002, 07:27 PM   #2750
Tech Legend
Cain's Avatar
Got the problems fixed today at the hobby shop. The bearing in the tensioner wasn't all the way down and I removed burs from the CVD and it is really smooth now.
Old 05-27-2002, 08:34 AM   #2751
ttr
ttr's Avatar
Default Reedy race setups needed
Can someone please post here the team Losi setups from the Reedy race? I am highly interested in those no one-way setups for that technical track.
ttr is offline   Reply With Quote
Old 05-27-2002, 09:31 AM   #2752
STLNLST's Avatar
Trader Rating: 19 (100%+)
Default Re: Reedy race setups needed
I will post mine when I wake up again. I'm a little too tired to type more than this.
Mark Dawson- It was great to finally meet you and thanks for all of your input.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-27-2002, 02:16 PM   #2753
yodace's Avatar
Old 05-27-2002, 05:07 PM   #2754
newracer's Avatar
I know both of these have been posted before but.....
what is the part# for the steel CVD bone?
and the part# for the Yokomo TC3 aluminum outdrives?
newracer is offline   Reply With Quote
Old 05-27-2002, 08:46 PM   #2755
yodace's Avatar
Old 05-27-2002, 09:40 PM   #2756
newracer's Avatar
HPI x-patterns work good on dusty tracks, the Advans might work ok too
you probably want a high ride height and soft springs and light oil
Old 05-27-2002, 10:41 PM   #2757
Cool Rumours about a new Losi prototype!!
The following link will show you a picture of hat is said to be a new Losi onroad prototype working well....
http://www.team-orion.ch/live/images...losi-proto.jpg
Strange that this is the only info available! Some parts can be recognized as actual Losi parts (not only the Losi stickers) so there might be something close to the truth here.
Anybody else knowing more or is this old (to old) news already?!
Arnoud is offline   Reply With Quote
Old 05-27-2002, 10:53 PM   #2758
OK, this was a historicalpicture of the year 2000. Keep it for your history books only. Sorry!
Old 05-27-2002, 11:45 PM   #2759
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Hey you guys are going to love this- we made EDITable setup sheets for the XXX-S- you can make your own to look just like the PROS setup sheets- here's the link- check out our local club's site while you're there.... http://home.midsouth.rr.com/memphisrc/setup.htm
BigDogRacing is offline   Reply With Quote
Old 05-28-2002, 02:24 PM   #2760
Is anyone having problems with breaking the front C hubs/spindle carriers? If you are, how did you fix it? Are there any stronger replacements?
Sydewynder is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
