Old 05-21-2002, 07:26 PM   #2731
Trips's Avatar
Trader Rating: 16 (100%+)
Schuie,
Try 56 pistons with 60wt front and rear, and get rid of the kickup. If you want more steering after that go with more rear droop.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-22-2002, 12:35 AM   #2732
STLNLST's Avatar
Trader Rating: 17 (100%+)
Good bye to my fellow XXXS racer's......I'm leaving for the Reedy tomorrow and I don't plan on hauling the lap top to this event so computer access might not be possible unless Matt Francis has his with him. I will post my set up that I end up using at this race for anyone that cares for it.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-22-2002, 04:52 AM   #2733
Good luck STLNLST........bring back some hardware!!!!
Trips.....I always thought you should go stiffer in the front if you wanted more steering so your idea of going to 60 wt oil and 56 pistons has me a little confused. I do agree that I should probably get rid of the kick up though. This question has been asked a gazillion times already but I'm going to ask it again What's the difference between having 0 degrees of kick up and 4 degrees of caster at the block compared to 2 degrees of kickup and 2 degrees at the block? Does the car feel different between these two settings even though the total amount of caster is the same?
Schuie Driver is offline   Reply With Quote
Old 05-22-2002, 09:30 AM   #2734
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
I would love to see setups from this race considering the oneways won't be allowed. Good luck and don't lap the competition to much!
Jared Kirkwood is offline   Reply With Quote
Old 05-22-2002, 09:44 AM   #2735
Schuie- Kickup will affect how the front end moves. This is why negative kickup is called anti-dive. 0 or neg kickup will let the front dive less when braking and the front will lift less while accelerating. This in affect helps controll front to back weight transfer. BTW I have found that I allmost always like the car with 4deg caster blocks and 0 kickup. I would like to try 6deg blocks with some anti-dive if Losi ever gets the 6 deg blocks out to the general public.
Chad
ChadK is offline   Reply With Quote
Old 05-22-2002, 09:47 PM   #2736
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
chad i have used the anti dive and 6 deg blocks with my foam car....i liked it a lot....
Matt M. is offline   Reply With Quote
Old 05-23-2002, 10:07 AM   #2737
Where did you get the 6deg blocks from?
Old 05-23-2002, 03:06 PM   #2738
R/C Tech Founder
R/C Tech Charter Subscriber
He grovels at Lemieux's feet to get prototype parts
edit: Actually, mr. losi and Paul are good friends. Paul comes to race at our track once in awhile and a good time is had by all. It's nice to have a pro all the way out here in cheese land
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 05-23-2002, 03:11 PM   #2739
That's what I thought.
Old 05-23-2002, 07:07 PM   #2740
shrekair's Avatar
Trader Rating: 9 (91%+)
you gotta love 0 0, zero kickup, zero castor. works good for stock rubber on carpet
shrekair is offline   Reply With Quote
Old 05-23-2002, 09:28 PM   #2741
Team R's Avatar
Default What tire to get?
Can you guys tell me what would be a good tire to use on a parking lot track that has a unprepared surface. Iíve been looking at either the HPI 5130 Super Radial Tire or the PRO-Line 1093-S2 Road Rage. Will I be happy with these tires or is there a better tire out there.
Thanks to all for there input.
A Sleep At The Wheel
Team R is offline   Reply With Quote
Old 05-23-2002, 09:46 PM   #2742
Default Re: What tire to get?
For dirty unpreped parking lots, I would use HPI X Patterns Pro compound.
Sydewynder is offline   Reply With Quote
Old 05-24-2002, 03:19 AM   #2743
ttr
ttr's Avatar
I have tried a lot of different tires for dirty tracks (because almost all tracks are dusty at us so I think I can help you. For dirty parking lots the HPI 4521 low profile radial in pro compound is the best. The low sidewall gives a bit more responsive steering than the normal. Only the pro compound gives enough tracktion, the super compound tires last longer but the traction much less. Don't use the foam inserts included with the HPI tires, they much too soft. Get the 4670 HPI 26mm soft molded inserts, or any 26mm wide (NOT 24mm!!!) medium/soft molded inserts, what can support strong enough the sidewall of the tire. The 26mm hpi inserts are extra heavy
Use soft springs on your car.
ttr is offline   Reply With Quote
Old 05-24-2002, 10:57 AM   #2744
Default Question on Paul Lemieux's Roar Setup
Hello,
I am interested in using Paul Lemieux Roar setup...
http://www.teamlosi.com/pictures/jpe...SPaul_nats.jpg
I looked at his setup, but I can't tell if he used the stock 0 degree rear hub carriers or if he used either the .5 or 1 degree rear hub carriers. Any ideas?
Thanks,
reddew
reddew is offline   Reply With Quote
Old 05-24-2002, 12:59 PM   #2745
Trips's Avatar
reddw,
his setup sheet calls for 2 degrees rear toe. The 0 degree rear carriers provide that.
Trips
MARSHAL!!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
