Old 05-14-2002, 10:25 PM   #2686
Originally posted by yodace
just got a used front one way. I was wondering which direction the white arrows go?
what is the size for the short turnpuckles?
The arrows point forward. Easy way to check is to rotate the diff gear forward like it's under power. Both outdrive cups should lock.
The short turnbuckles are 1-1/8" long.
Sydewynder is offline   Reply With Quote
Old 05-14-2002, 11:38 PM   #2687
STLNLST's Avatar
Trader Rating: 19 (100%+)
Shuie Driver- No problem. I'll post any set up that I use.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-15-2002, 08:45 AM   #2688
shrekair's Avatar
Trader Rating: 9 (91%+)
foam on ozite (carpet)
front:
41 t pulley
trinity congo spring purple
80 wt. 56 piston
camberlink 2 or 3 hole
0 F block w/ 2 or 4 deg castor blocks (driver preference)
.030 spacer glue to spindle (spashett trick)
shocks in hole 2
droop - 3
jaco plaid foam
rear:
42t pulley
trinity congo spring blue
either 70 wt 56 piston or 80 wt. 55 piston
camber link in either hole 1 or 2
0 R block
shocks in hole 2
droop - 5
jaco purple
hope this helps
~James
shrekair is offline   Reply With Quote
Old 05-16-2002, 10:23 AM   #2689
Thanks for posting your setup, What will running the 41 tooth pulley in front and the 42 in rear affect the car.
racerfreedxxxs is offline   Reply With Quote
Old 05-16-2002, 11:16 PM   #2690
Team R's Avatar
Default Tires question
Hello all
I've seen where some of you drivers have used different tires on the front and rear of your car ( like Sorex 36 and 32). I tried to find some of the posts that I saw, but had on luck.
How dose it affect the handling of the car? Dose a softer tire give of take a way traction on which end of the car you put it on?
Thanx
Team R is offline   Reply With Quote
Old 05-17-2002, 12:30 AM   #2691
STLNLST's Avatar
I normally only run a different tire combo on carpet. The harder compound usually goes in the front of the car. It all depends on your car set up. For asphalt you should be okay with the same tire all the way around but if you feel that you could use a little more rear traction use a softer tire in the rear.
Old 05-17-2002, 08:41 AM   #2692
yodace's Avatar
R/C Tech Charter Subscriber
I have a one way. I was wondering if but together right are supposed to screw the light spring into the outdrives? Or the leave them free floating?
yodace is offline   Reply With Quote
Old 05-17-2002, 08:43 AM   #2693
shrekair's Avatar
Set your losi on a smooth surface like a pool table turn the wheels fully and with a 42 42 combo the frotn wheels will fight a little bit when u roll it. with a one it will be smooth or u need a 41 so the front wheels can roll faster and not creat drage againsed the rear wheels. that and its a little more off power steering.
Old 05-17-2002, 09:54 AM   #2694
psycho's Avatar
yodace
The springs should stay in the outdrives on their own once you press them in there. There is no need to screw them in.
psycho is offline   Reply With Quote
Old 05-17-2002, 10:45 AM   #2695
tufferwilde's Avatar
Default Tamiya Track
has anyone on here run on the Tamiya test track... I am trying to figure out what I should bring along to the reedy race (won't have room for EVERYTHING)
What I am actually looking for is some description of the track size, sweeping corners, etc...
Thanks in advance!
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 05-17-2002, 01:57 PM   #2696
newracer's Avatar
I have run there, you can see part of the track here
http://www.tamiyausa.com/events/reedyrace2002/
it is pretty big, about 100 x 50
there is a long straight in front of the drivers stand that leads into a long sweeping left corner, from there is depends on the layout, they can set it up several different ways, usually after the sweeper there is a short straight into a hairpin, then a few S's maybe a hairpin then a short straight on the top left away from the stand, then some more S's and a tightening corner right before the straight, but like I said it really depends on how they lay it out, there are several different options
but the track is smooth and usually a lot of grip
newracer is offline   Reply With Quote
Old 05-17-2002, 10:05 PM   #2697
Team R's Avatar
Default Ride Height Question
Hello
This may be a rookie question, but I'm still pretty new to my
XXX-S.
How do you adjust the ride height on the car?
There, I did it. That is my allotment of rookie question for the year.
Thanx to all for any input they send my way.
The GEEZER
Old 05-17-2002, 10:15 PM   #2698
Trips's Avatar
Trader Rating: 16 (100%+)
You adjust the ride height with the spring collars above the springs. The lower you go with the collars, the higher the ride height of the car. If you find that lowering the collars isn't increasing the ride height, you've probably got the droop screws in too far and need to back them off first. It's probably best to back the droop screws way off before setting the ride height, then once the ride height is where you want it, set the droop with the droop screws.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-17-2002, 10:34 PM   #2699
Send a message via AIM to ZER01
Leave those springs in the outdrives. They are there for a reason, they keep the outdrives from backing out of their hub.
ZER01 is offline   Reply With Quote
Old 05-18-2002, 10:11 PM   #2700
Trader Rating: 62 (100%+)
do i have to put grease or some other lubricant on the hinge pins when using matt francis red suspension arm mounts? the hinge pins are steel and the blocks are aluminum and i was wondering if there will be accelerated wear on aluminum due to the metal to metal contact.
marvi is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
