Old 05-06-2002, 03:01 PM   #2656
newracer's Avatar
R/C Tech Charter Subscriber
the door is great I just couldn't figure out an easy way to move the drive train back and forth to see the play, I'll try rolling the car on the table the next time
All my past cars have had an exposed spur gear so I just moved the gear with my finger. It's just something to get used to mostly.
On a side note, I finally got to run my car this past weekend, I liked it a lot. I never really had the right tire choice though so I couldn't experiment with the setup much. The car feels very consistant which I like a lot.
Just to double check, the internal ratio for the xxx-s is 1.83
newracer is offline   Reply With Quote
Old 05-06-2002, 03:03 PM   #2657
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
thats right newracer. 1.83
I ran my XXX-S yesterday and it was planted. I'm VERY happy with the car and the way it handles around the local track here.
BHenderson is offline   Reply With Quote
Old 05-06-2002, 04:00 PM   #2658
shrekair's Avatar
Trader Rating: 9 (91%+)
actually the final drive on a losi xxx-s is 1.826 its minimal but if thats the only thing u have left to tune it may change a little bit.
And The losi sedan is an awesome car!!!!
shrekair is offline   Reply With Quote
Old 05-06-2002, 04:04 PM   #2659
shrekair's Avatar
As for the losi turning into the corner u can reduce rear toe in or add front toe out. stand all the shocks up one hole helps too.
Old 05-07-2002, 12:41 AM   #2660
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
wellthe only time i remove my cover is when the moon is full......and who checks gear mesh?????
Matt M. is offline   Reply With Quote
Old 05-07-2002, 04:08 AM   #2661
Does anyone know what a good starting gear ratio for a Fantom stock (P2K2) motor would be?
Sydewynder is offline   Reply With Quote
Old 05-07-2002, 10:48 AM   #2662
psycho's Avatar
Where you racing at, Sydewynder? I usually run 28/90 (5.88:1) with a Trinity P2K2 at Castle. If you have the stock yellow spur, I'd have 27, 28 and 29T pinions for that track. You've got mail.
psycho is offline   Reply With Quote
Old 05-07-2002, 01:38 PM   #2663
Could somebody please explain the rear toe options available for this car? I think stock is 2 degrees per side and I'd like to try the car with a little less rear toe. Are 1 degree and 1/2 degree available? What about 0? Am I looking at it wrong? Is Losi saying there is one degree per side stock for a total of 2 in the entire rear end?
Schuie Driver is offline   Reply With Quote
Old 05-07-2002, 01:48 PM   #2664
Schuie- The car has 2 degrees of rear toe in per side. This is in the inner hinge pin mounts. The stock hub carriers are 0 degree. There are 1/2 and 1 degree hubs optional parts. So you can achieve 1 to 3 degrees toe in per side by using the hubs to either add aor subtract toe in. For instance 1/2 degree hubs on "backwards" will net you 1 1/2 degree per side. I hope that is clear for you.
Chad
ChadK is offline   Reply With Quote
Old 05-07-2002, 02:38 PM   #2665
I'm running at Delta right now.
Doesn't your motor get very hot with 5.88:1? I've change to 64 pitch so I'll have to get pinions. Thanks.
Old 05-07-2002, 04:33 PM   #2666
psycho's Avatar
Sydewynder
Hmmm... I didn't know Delta ran electric. I learn something new every day! The motor definitely gets warm, but I hate it when guys blow by me on the straightway! Delta is a lot tighter track than Castle, though, so you probably don't need to gear that low. Maybe start around 26T pinion (6.19:1) and go up a tooth at a time until your speed tops out on the back straight as you're letting off going into the turn.
Old 05-07-2002, 10:18 PM   #2667
Sydewynder
Yeah they have electric and if you go for novice sometimes they run nitro and electric together when there isn't enough people.
Ok so just start out with what Losi recommended and go from there? Thanks.
Old 05-08-2002, 06:27 AM   #2668
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Hey gang, if you are looking to dress up your car you should look into the stainless steel screw and wheel nuts for the XXX-S. They come in a nice container that you can use for other things as well. Stop by the website to check them out.
We are also stocking replacement and hopup parts for the XXX-S as well. If you can think of anything else we should add just drop me a pm or email.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-08-2002, 07:26 PM   #2669
DO you guys have blue screws aswell?
teamAE is offline   Reply With Quote
Old 05-08-2002, 09:46 PM   #2670
Super Moderator
Kraig's Avatar
I don't have any blue screw kits yet but I am actively seaching! I hope to know something soon!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
