Old 04-24-2002, 11:35 PM   #2611
Mine fits fine on the MIP tweak station!
Arnoud is offline   Reply With Quote
Old 04-25-2002, 05:05 AM   #2612
The MIP tweak station should be adjustable front to back like Sydewynder said. I know mine was VERY hard to adjust at first, but after a while it becomes easier and easier to move the rear bar (the one without the bubble) back and forth.
Thought I'd post some questions I asked previously but have not had much luck in the response department. If anybody can help out that would be great!
First, I see that Losi has released both the steel and aluminum dogbones as a separate item. (When I first bought the car the only way you could get spare bones was by buying the whole CVD assembly.) Are the steel and aluminum bones interchangeable now or do you need to buy the aluminum CVD assembly first before you can buy just the bones? I thought that the aluminum CVD kits had a shorter axle or something, so there might be a reason I couldn't just swap the steel with the aluminum. Hoping I'm wrong though because the aluminum bones are only $8 a piece.
Second.....for those of you who are using the low roll center option, when you want to run high roll center again do you need to purchase new front and rear bumpers? Would be nice if you could use the same bumpers for both high and low after you've cut off required sections.
Schuie Driver is offline   Reply With Quote
Old 04-25-2002, 07:51 AM   #2613
STLNLST's Avatar
Trader Rating: 19 (100%+)
I don't know the reason for the shorter aluminum assembly but all MIP CVD'S will work. I had the aluminum one's on the front of my car but switched to the steel cvd's while keeping the short axle's one the car.
About the high and low roll centers......I do switch bumpers when I switch between the two because with high roll center I can use standard length droop screws. When running the low roll center you have to use smaller droop screws and trim the hump that the droop screw comes out of. The droop screw is to short if you go from low to high roll center. I hope this answers your questions. If not I can go into more detail when I have a little more time.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-25-2002, 09:10 AM   #2614
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
About the MIP tweak station, I know on mine that the end the shaft slides into didn't get cut, drilled or milled properly. The shaft only goes in so far before it stops. You might want to take a look at that piece to see if you have the same thing. You will just need to clean that out but I don't have any suggestions on how to do it as I have left mine alone.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-25-2002, 10:08 AM   #2615
psycho's Avatar
I think the early MIP tweak stations were made so the center rod doesn't go all the way through the block without the bubble. That's how mine is. I have a buddy that bought one about 6 months ago and his can slide all the way through. It's easy enough to open the hole up a little and let it to slide all the way through.
psycho is offline   Reply With Quote
Old 04-25-2002, 10:09 AM   #2616
Trips's Avatar
Trader Rating: 16 (100%+)
Schuie--
You should be able to use the same axles with both the steel and aluminum bones.
I use the same bumpers for both low and high roll center, I just change the droop screws. For high roll center, I install the droop screws just the way the manual shows, for low roll center I put the front droop screws in the back bumper, and an even shorter set of screws in front.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-25-2002, 05:17 PM   #2617
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I got my MIP Tweak station last December, and i had to ream out the hole a little bit. Just find an old pair of scissors, and get the little ridge out. Thats all it is, is a small burr... or ridge on the inside. It just takes a little bit to get it out. Also... a dremel works too..
I used the dremel first, and finished it with scissors.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-25-2002, 05:25 PM   #2618
Thanks for the help on the questions guys. So you are saying that the bones are interchangable between the steel and the aluminum? I wasn't concerned with the axles as I just planned on using the ones that came with the kit. I was more concerned that I wouldn't be able to use the new aluminum bones with the standard axle.
Old 04-25-2002, 07:10 PM   #2619
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Got a quick question...I've seen several set-ups that use orange and some that use the pink springs which are 2.5" in length if I'm not mistaken. Are these springs being cut down for use on the xxx-s? I saw Kinwald's set-up for low bite and he use pinks in the rear, but once I got them in my hand, they sure are long!! Tell me how to use'em fellows! Thanks
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 04-25-2002, 07:50 PM   #2620
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default ASM
sorry to tell you this but you have the wrong springs. All most all the XXX-S springs are 1.15" some of the heavier wt springs are 1"
BHenderson is offline   Reply With Quote
Old 04-25-2002, 08:20 PM   #2621
Team R's Avatar
Default MIP Tweak Station
Hello all--
After seeing the first couple of replies to my question, I went out and checked the fit on the end of the tweak station that should be able to slide on the rod to adjust for wheelbase. The rod would only go so far into the whole ( no pun intended). After some adjustment I can now adjust for different wheelbases.
Thanks to all that replied to my post
Team R
Team R is offline   Reply With Quote
Old 04-25-2002, 09:18 PM   #2622
CRASH's Avatar
Trader Rating: 26 (100%+)
You have offroad. They make the same colors for the sedan but they are 1.15" in length. They are the same rate.
CRASH is offline   Reply With Quote
Old 04-26-2002, 05:59 AM   #2623
ASM
ASM's Avatar
BIG thanks guys!
Scott Meeks
USVTA Member #116
Old 04-26-2002, 07:05 AM   #2624
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Try this and see if it needs any changes...
It's a PDF XXXs set-up sheet, that is a form you can edit and print....
You will still need Acrobat Reader at the least....
XXXs Set-up Form
I have them for most Losi cars....
Tres is offline   Reply With Quote
Old 04-26-2002, 07:33 AM   #2625
STLNLST's Avatar
XXXs Set-up Form
Thanks for posting that set up sheet. I was tired of writing my set ups down. Now all I have to do is type them on this sheet and it looks so neat and clean
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
