Old 09-03-2001, 08:12 AM   #241
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ya some times you have to really tighten them up...also, you could use some green slime on the orings..that works best for me....
Matt M. is offline   Reply With Quote
Old 09-03-2001, 09:34 AM   #242
robk's Avatar
Trader Rating: 22 (100%+)
sirSpeedy:
Pits are back? i thought GTP closed its doors forever. I talked to one of the guys from GTP , and they told me they were going out of business. If you can find out more let us know.
Old 09-03-2001, 11:23 AM   #243
Administrator
Matt M.'s Avatar
guys while i am at the hobby show i will look into the availability of pit tires
Old 09-03-2001, 11:26 AM   #244
pits or sorex's?
I have a charity race in laurel next sunday and I need a set of tires(rubber)
the asphalt is outdoor kind of dusty and untreated.
the temperature of the track is probably around 90-110 deg.
where can I find the sorex's or pits at?
so my LHS can order them in.
oh yeah and what insert should I go with?
holy ear guy is offline   Reply With Quote
Old 09-03-2001, 11:36 AM   #245
Administrator
Matt M.'s Avatar
sorex 36....hpi red inserts...or yok firm.....take your pick....tell me more on the track...do they leef blow it??? suger water???i am not sure where to get them but sorex has a web page at www.teamsorexusa.com
Old 09-03-2001, 12:20 PM   #246
not sure if they leaf blow it. but I know they don't treat it
Old 09-03-2001, 12:24 PM   #247
are the 32r's softer than the 36r'soh and I'm gunna run the tires on the XXX-S cause the car rox
Old 09-03-2001, 12:31 PM   #248
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Yes, Sorex 32 is softer than Sorex 36. It might be hard for your LHS to just go out and order you a set.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-03-2001, 12:47 PM   #249
guess I should 've started this a while ago
so should I try pits?
Old 09-03-2001, 03:30 PM   #250
holy ear guy , I think Hobby Works sells Sorex but I'm not sure hope to see you their ,I race mainly at Hobbytown USA in Glen Burnie and that is oval.
sportracer is offline   Reply With Quote
Old 09-03-2001, 04:49 PM   #251
R/C Tech Founder
R/C Tech Charter Subscriber
Why would it be hard for them? That's what hobby shops are supposed to do!
(Unless of course, it's like the one here, which is perpetually backordered on Sorex...)
futureal is offline   Reply With Quote
Old 09-03-2001, 06:25 PM   #252
RCTech Member #2
TSR6's Avatar
It is hard to get the Sorex tires. I don't even know when we are getting more. I should check into that. We were low on 32's & 28's last i knew..
Troy
RCTech Member #2
Old 09-03-2001, 07:21 PM   #253
Administrator
Matt M.'s Avatar
well bob s got a xxxs....copyer.....he has the same prob as you shane....three female diff halves.....arg....
Old 09-03-2001, 10:28 PM   #254
R/C Tech Founder
Are you serious? Well I got mine from Losi, I'd be happy to give him the extra set I got while he waits for his. And I still have yours in a diff as well! (I built an extra one like you did)
Know if he's planning on racing it at Trackside?
Old 09-04-2001, 01:49 AM   #255
Originally posted by Jamracing 1
See you should have followed directions and that wouldn't have happened....
I thought you said in your post you have built lots of them, maybe you just got a bad "o" ring, try another one, and this time use more lube on it..
I did read the directions............
and I have build a lot of losi shocks.......
and I all ways put a drop of oil on the top o-ring and a drop on the bottom o-ring......
it not my fault, if the o-ring is broken in half, I just got a bad o-ring
Wolverine is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
