Old 04-08-2002, 01:47 PM   #2476
ok thank you
teamAE is offline   Reply With Quote
Old 04-09-2002, 10:48 AM   #2477
newracer's Avatar
R/C Tech Charter Subscriber
what wrenches are you guys using for the wheels nuts and shock nuts? All my tools are metric and I got the car used so I am looking for something like a cross wrench. I got the RPM pne for Losi cars but it doesn't fit the wheel nuts.
newracer is offline   Reply With Quote
Old 04-09-2002, 11:08 AM   #2478
CRASH's Avatar
Trader Rating: 26 (100%+)
Thumbs up Milled XXXs
How due you post multiple pics in a reply? Bit off topic I know, just curious. Pics of milled xxxs in for sal forum. Wanted to post here just not sure how to post multiples.
CRASH is offline   Reply With Quote
Old 04-09-2002, 11:32 AM   #2479
newracer's Avatar
if the picts are on a server already you should be able to click the "IMG" button and put in the url for a pict then do it again, again, and again, etc
if you need to attach them then I think you can only do one per post
Old 04-09-2002, 01:45 PM   #2480
Trips's Avatar
Trader Rating: 16 (100%+)
11/32 for the wheel nuts, 1/4 for the shock nuts, and 3/16 for the ball studs.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-09-2002, 02:03 PM   #2481
newracer's Avatar
I figured that out but was more wondering what brand/style of wrenches people are using, I am thinking about getting the integy set. I wish there was a small cross wrench that fit them all.
Old 04-09-2002, 04:42 PM   #2482
ttr
ttr's Avatar
Default Vibration in steering
If I hold the car in my hand and the steering is at the left or right endpoint the front wheels are vibrating very hard and the motor slows down a bit. Looks like the front CVDs can not work fine at full steering angle. If I take out the CVDs they feel smooth, no binding. Is it a common problem? Should I limit the steering endpoint?
ttr is offline   Reply With Quote
Old 04-09-2002, 05:44 PM   #2483
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
ttr: read back through some of the post for more info.
You need to limit the steering with some small washers...
Check pic also....
Hope this helps...
Tres is offline   Reply With Quote
Old 04-09-2002, 06:56 PM   #2484
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default Tres
I've seen that now on a few of the XXX-S including spashett's. Other than just a stop what does that do?? Can't you achieve the same effect by taking some of the throw out on the radio?
BHenderson is offline   Reply With Quote
Old 04-09-2002, 07:06 PM   #2485
Default steering stops
If you only dial out throw on the transmitter, your wheel can still travel (Accident or heavy stress) with the give from the servo saver. By putting the stop in place, the wheel wont turn any further, and you wont risk damaging your cvds.
would be nice if losi just pre molded this in place...
new2xxxs is offline   Reply With Quote
Old 04-10-2002, 02:32 AM   #2486
highx's Avatar
Default Trinity touring car wrench
I think that is what the four way wrench is called that Trinity makes for standard touring cars. Just don't get the metric one. Quick question, have any of you tried the Trinity spur gear adapter? I was considering it because the standard spurs seem to be pretty warped. If you have any input I would appreciate it.
highx is offline   Reply With Quote
Old 04-10-2002, 07:31 AM   #2487
Tres's Avatar
highx: yes, on the adapter.... Works ok, you will have to use thin spur gears though....
Old 04-10-2002, 09:59 AM   #2488
Trips's Avatar
I'm using Trinity wrenches, the only issue is the 11/32 wheel wrench wouldn't fit into Sorex 5 spoke rims, I had to grind the outer diameter of the wrench down a lot to get it in. It did fit every other wheel I've ever used with no problem.
Trips
MARSHAL!!
Old 04-10-2002, 10:44 AM   #2489
David Joor's Avatar
Default Carpet Setup
I have a finalized setup for carpet foams. The hitch is that at our track we run full size TRC foams (62.5mm) to save on costs. So please read the bottom of the setup sheet to explain how to reset droop as the tires get smaller. If you have trued tires then the droop settings will be to much for your car. Droop was set with a Losi gauge at the lowest part of the arm (angled down side). FYI - I own a carpet track so a lot of testing went into this, if you have any questions feel free to ask. The track is a 75x36 with 8 second laps in mod, so this setup has more steering then most of the setups I have tried or made in the past.
http://www.rczone.net/modules.php?na...=getit&lid=123
Avid Racing Concepts LLC.
http://www.avidrc.com
AE | Reedy | KO | Tekin | Powermaster | Avid | Upgrade | BCE | Paint by Smiley
David Joor is offline   Reply With Quote
Old 04-10-2002, 01:10 PM   #2490
highx's Avatar
Default Trinity Spur Gear Adapter
What brand of spurs do you use? Just want to get some info from racers before I drop $35 on this thing. Thanks for any help.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
