Old 04-02-2002, 07:46 AM   #2446
HarshGuy's Avatar
Transmition ratio with over or underdrive is 1.78 ....BTW there is an online final drive ratio, rollout, theoretical maximum speed chart available here: http://www.rcracing.com/Page.cfm?InfoID=1100
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-02-2002, 04:37 PM   #2447
Regional Moderator
Addict sa RC's Avatar
Ah ok. So it's always the smaller diff pulley that takes precedence. Thanks.
Addict sa RC is offline   Reply With Quote
Old 04-02-2002, 07:03 PM   #2448
Default Fisrt track appearances
I am looking at spending sometime traveling this summer, and bringing my xxxs with me.
What I want to discuss with you guys is what do you do when you walk into a forign track. I am new the TC scene, but have raced Losi (in the dirt) since the jrx2. I know the race basics, but I was looking to find out what you guys do when you roll into a new place (or even the old place with a new track).
Specifically:
How do you determine tire combos?
Motors? Gears? Shocks Springs?
In dirt, I usually start by guessing the tire combo, and work on the shock package. I usually will have my "pit boss" (good friend), with a handfull of springs/shocks(varied oil/pistions), in case I am way off or really close and want to dial in. In dirt I usually have 1 or 2 setup(s) per vehicle (plus shock/spring combo) depending on surface.
But TC there seem to be a huge disparity of surface conditions and what works well. I have seen over 30wt in oil and several spring / piston combos that are on the fastest cars (even on this board...) I know its feel, but from the newbies eyes this can be daunting...
For the record, I plan on running at tracks in NJ, NY (eastern), CT - rc madness, and big boys in mass, so I will take any setup ideas you have to pass around for them. I don't plan on racing at big boys this weekend, though I will try and stop by.
thanks.
new2xxxs is offline   Reply With Quote
Old 04-02-2002, 07:10 PM   #2449
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Addict sa RC: i see someone's planning to play around with over/underdrive! hehehe
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 04-02-2002, 09:18 PM   #2450
Mad_Cats's Avatar
Send a message via Yahoo to Mad_Cats
Default Okay its a bit off topic...
I am going to be in Detroit next week for a few days, I posted in the track finder forun with no replies...
Anyone out the from the Detroit area will to give up some info about weekday racing? Thanks
Mad_Cats is offline   Reply With Quote
Old 04-02-2002, 11:30 PM   #2451
Regional Moderator
ROBORAT,
Old 04-03-2002, 05:36 AM   #2452
R/C Tech Founder
R/C Tech Charter Subscriber
I'm not sure if anybody has posted one before, but is there an easily accessible set up for foam mod?
I ran it for the first time last night, the car was not terrible with a blue/silver 60/60 setup, low roll center, no swaybars, longest camber links, 4 degree front caster and 1 1/12 degree rear toe-in (total). Plaid up front and purple rear.
I know it can be better though. I will probably try stiffening things up a bunch for starters. Anything else I might try?
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 04-03-2002, 05:45 AM   #2453
CRASH's Avatar
Trader Rating: 26 (100%+)
Thumbs up Milled XXXs
Anyone interested in a milled XXXs car please IM me for details and pictures. The car is very similar to that of Kinwalds. It has Lunsford titanium hinge pins and turnbuckles, Losi titanium ball studs and threaded shocks, Dynamite graphite front and rear shock towers, Speed Tech aluminum front and rear low roll center blocks, pivot blocks, and steering linkage.
CRASH is offline   Reply With Quote
Old 04-03-2002, 02:10 PM   #2454
Administrator
Matt M.'s Avatar
shane go to losis web site.....pick one......i used one that i got from paul.......it has some unavailabe parts on it though...
Matt M. is offline   Reply With Quote
Old 04-03-2002, 02:17 PM   #2455
R/C Tech Founder
Well, let's go raid Paul's parts chest then.
Old 04-03-2002, 02:36 PM   #2456
ttr
ttr's Avatar
Default part number for cvd bone?
I just managed to break a front steel cvd. I need to replace the bone only, can't find the partnumber for the bone. Is there an alu replacement bone? I would like to put it in the back to save some weight.
ttr is offline   Reply With Quote
Old 04-04-2002, 10:12 AM   #2457
mushu's Avatar
I had the same problem with the steel dogbone part number. My local hobbyshop had to call Losi for the part number (it's not on the website). You might drop them an email. they know about the parts database being out of sync.
mushu is offline   Reply With Quote
Old 04-04-2002, 10:27 AM   #2458
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I believe the steel driveshaft is losa9970. No idea on the aluminum version.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-04-2002, 10:33 AM   #2459
Trips's Avatar
Trader Rating: 16 (100%+)
Default "Slim" Diff??
I was reading about a diff mod on the Trinity forum, the guys there called it the "Slim Diff" supposedly named for a guy named "Slim" at Socal. They said that building the diffs this way would be better than the kit specification.
Anyone using this mod, There seemed to be several variants on how to do it on Trinity's site, I'd like to get the lowdown if possible...
Thanks,
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 04-04-2002, 01:21 PM   #2460
CRASH's Avatar
Slim Diff
Straight from TTT web site.
Quote
"screw, foam washer, super thin 3/16 axle shim, thrust washer, thrust bearing (molded), thrust washer, thrust bearing (molded) thrust washer, outdrive. usual internal diff parts, other molded outdrive, bevelled washer coneing out, bevelled washer coneing in, bevelled washer coneing out, bevelled washer coneing in ()(), plastice 4-40 mini-nut holder, associated micro 4-40 nut, regular micro 4-40 lock nut."
Anyone going to give this a try?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
