Old 03-30-2002, 02:08 PM   #2431
ttr
ttr's Avatar
Default Do I need low roll-center?
Do I need low roll-center? I race on medium to low grip asphalt, bit bumpy. Would it give more traction? Or is it the same to use softer springs?
ttr is offline   Reply With Quote
Old 03-30-2002, 02:31 PM   #2432
Default aluminum carriers
I was wondering where I could get the aluminum front carriers for the xxx-s? I looked on stormers website and also on speedtechrc and I didn't see the front carriers in aluminum. Any help would be appreciated.
R_Andersen is offline   Reply With Quote
Old 03-30-2002, 02:46 PM   #2433
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default Alum Carriers
Horizon Hobby has Alum Carriers for the XXX-S. They are made by dynamite, heres the link
CLICK HERE FOR XXX-S ALUM CARRIERS
BHenderson is offline   Reply With Quote
Old 03-30-2002, 08:29 PM   #2434
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
guys losi redesigned the front arms.....so to run low roll center, you need to remove some material from the bumpers, and the chassis.....
Matt M. is offline   Reply With Quote
Old 03-31-2002, 11:17 AM   #2435
Evil_S10's Avatar
Send a message via AIM to Evil_S10
Talking
To clear this up. I just bought the rod ends from Losi. The only thing is that they are for the XXX. I have been told that you can cut them down but I dont know if I should. I was just wondering if any other R/C company makes some that I dont need to cut, or should I cut them?
Evil_S10 is offline   Reply With Quote
Old 04-01-2002, 07:43 AM   #2436
Default AE parts for Losi
Hi,
Like to know if AE TC3 shock will fit XXX-S. I am not fond of threaded shock and thinking of getting the AE TC3 shock. Wondering if the length of the shock is suitable for XXX-S.
Does TC3 CVD axle will fit XXX-S ? I heard that the thread end
is a little longer then XXX-S ones. Also, I am using TC3 steering block carrier (C-hub) and wonder if steering block will fit XXX-S.
Like to know such that if my LHS run out of losi spares, I could use some of the TC3 spares.
Please advise.
ongbenghui is offline   Reply With Quote
Old 04-01-2002, 11:41 AM   #2437
ottoman's Avatar
R/C Tech Charter Subscriber
ongbenghui
I run TC3 threaded shock on one of my XXX-S's and they seem to work fine. I had them laying around and I was too cheap to buy another set of threaded shock bodies so.....
ottoman is offline   Reply With Quote
Old 04-01-2002, 11:46 AM   #2438
ottoman,
what spring/oil/piston combo are you running? ie. if you are running 50 wt. oil and blue springs (losi - 14 lbs.), can you use the same 50 wt. and associated's comparable spring?
diesel31 is offline   Reply With Quote
Old 04-01-2002, 01:52 PM   #2439
Can anyone give me a good overal setup for my xxxs.
Mine is pushing very hard turn-in. I have tried several things but the problem stays. I drive 4 degrees caster, no kick-up front or rear, corally take-off tires with medium inserts, 50 wt-oil, front blue and rear silver springs. thanks.
sanitairgoof is offline   Reply With Quote
Old 04-01-2002, 03:20 PM   #2440
STARSCREAM's Avatar
sanitare,
If you want to try a good setup, try the new Todd Hodge setup on www.teamlosi.com go to setup sheets and click on the new setup.......
try the whole setup, even the low roll center in the rear with the high roll center in front......
even try the soft springs in the setup(blue, silver) but also try it with blue springs in the rear and green springs in front.....
post any other questions.....
STARSCREAM is offline   Reply With Quote
Old 04-01-2002, 10:24 PM   #2441
hey blazn420,
What do you mean by "low roll center"? Is it just to use the lower holes in the diff cover? Or do i need something else?
Old 04-01-2002, 10:44 PM   #2442
ottoman's Avatar
Diesel
I run 40 weight but I cant remember what piston, probably the one called for in the stock TC3. I run asc springs, red or gold in front and blue in the rear.
Old 04-01-2002, 10:51 PM   #2443
STARSCREAM's Avatar
you need to get Trinity low roll center blocks. they are red aluminum and part of the Matt Francis line of xxxs parts.....
use them and the lower holes in the diff cover.....
you dont need to try the low roll center on the front end....
Old 04-01-2002, 10:55 PM   #2444
okay thanks, i try that setup.
Old 04-02-2002, 05:27 AM   #2445
Regional Moderator
Addict sa RC's Avatar
I don't know if this has been asked before but:
1. What is the final drive ratio (FDR) of the XXX-S when underdriven?
2. Will this be the same ratio when it is overdriven?
3. When a front one-way is used should the FDR be calculated using the rear pulley only or should the front pulley be taken into consideration?
Hope you guys can help.
Addict sa RC is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
