Old 09-01-2001, 06:31 AM   #226
HarshGuy's Avatar
Cool
Wow, they do show the chassis in stock ...keul hopefully that means Speedworld (my LHS) will have them in this upcoming week.
HarshGuy is offline   Reply With Quote
Old 09-01-2001, 01:33 PM   #227
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
I haven't been able to find any information on the PIT tires on the web today. I guess they don't want me to buy their tires?
I'm going to start with the Sorex's and go from there I guess. Thanks guys for the help.
Has anyone been playing around much with shock position changes. I would think for carpet racing you would want to stand the shock more upright (move the top of the shock out on the tower). Shouldn't this give more reposiveness and keep the car flatter through the corners and give more onpower steering. I was just thinking about this last night but have yet to try it.
Last time at the track for practice my times where very good. Actually on pace and the car was easy to drive. However I felt I might have been loosing some .10s comming off the turn due to a slight push when accelerating.
My setup is totally stock except with Trinity Congo Purple in Front and Trinity Congo Blue in the rear. I have yet to get to race the XXXS since most touring racing is dead right now during the summer and the track is a hour and half away.
Also are the sway bars out yet? If so anyone got the part number?
Jared Kirkwood is offline   Reply With Quote
Old 09-01-2001, 08:39 PM   #228
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
There has been some distribution issues with Pit Shimizu tire recently.
They are imported by GTP California, and last I heard they have gotten their issues sorted out.
I raced at Superior Hobbies in Orlando today...and they had at least 40-50 pair hanging on the wall.....
Their number is (407) 834-9299, or www.superiorhobbies.com
Later....
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 09-01-2001, 08:57 PM   #229
R/C Tech Founder
R/C Tech Charter Subscriber
So Pits are back, eh?
That would be nice, since our local shop here seems to be having issues in trying to find more of the Sorex parking-lot compounds (36, 32). I have a set or two, but I don't think I have enough to get me through the remainder of the outdoor season... at least 2 or 3 more outdoor dates... I need to find a new source! heh
futureal is offline   Reply With Quote
Old 09-01-2001, 08:59 PM   #230
Trader Rating: 21 (100%+)
try speedworldraceway.com for the sorex. check with billy there.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 09-01-2001, 09:04 PM   #231
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Shane - WE have tons down at my LHS.. next time you are here...import some up to wisconson... hope the boarder patrol doesnt give you problems....
WE have tons of 36's ... little low on 32's
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-01-2001, 09:38 PM   #232
mike_Webb's Avatar
Send a message via AIM to mike_Webb
How do these Sorex or PIT's handle on Carpet? What is the Tire Combination of Chocie for Ozite Carpet?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-02-2001, 02:27 AM   #233
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
look at message 214....i posted that a couple days ago...
Matt M. is offline   Reply With Quote
Old 09-02-2001, 05:19 AM   #234
mike_Webb's Avatar
Thanks Mr Losi
Mike
Old 09-02-2001, 09:48 AM   #235
R/C Tech Founder
mr. losi, doesn't Paul run 24-24 at Trackside? That's what the set up sheet on the Team Losi website says. Or do you know different?
I was just gonna go 24-24 on Tuesday and see if his setup works...
Old 09-02-2001, 12:38 PM   #236
Administrator
Matt M.'s Avatar
shane, the last i talked to him it was pit 25-25....but the sorex is close....i would think it change from time to time...due to cond....
Old 09-02-2001, 05:04 PM   #237
Man one the my shock is leaking..............
got oil all over my car stand......
The first losi shock to leak in all of the losi kits that I have put together............
that would be about 30 shocks, not counting the rebuilds
I haven't even run the car, and it leaks
any one else have this problem........???????
Wolverine is offline   Reply With Quote
Old 09-02-2001, 05:30 PM   #238
R/C Tech Founder
This is one of the XXX-S shocks?
Can you tell where it is leaking from, like the cartridge at the bottom or from the upper cap? If it's the bottom, it's possible that an O-ring was torn while the shaft was inserted. I would try taking the O-rings out and checking them, or checking the plastic of the cartidge for possible problems.
If it's the first time you put this particular shock together, it's actually easy for the shaft to rip the O-rings unless you put some drops of oil on the shaft and in the cartridge beforehand. No big deal if you ripped one though since O-rings aren't too expensive...
Old 09-02-2001, 05:34 PM   #239
Suspended
Wink
See you should have followed directions and that wouldn't have happened....
I thought you said in your post you have built lots of them, maybe you just got a bad "o" ring, try another one, and this time use more lube on it..
Jamracing 1 is offline   Reply With Quote
Old 09-02-2001, 10:31 PM   #240
RCTech Member #2
TSR6's Avatar
Mine leaked too.... These you really have to crank down on. All the other shocks i've built don't need to be "Incredible Hulk" tight.... but these just about have to be.
I used mr. losi's RPM Losi shock tool to tighten it. It hasn't leaked since.
Troy
RCTech Member #2
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
