Old 03-23-2002, 02:13 PM   #2341
stefan's Avatar
Send a message via AIM to stefan
Exclamation Red Aluminum screw kit available now!
Guys,
I now have a aluminum screw kit for the XXX-S available in red other colors are also available)
The screw kit contains all screws in the right sizes, flat head, cap head and button head (except the small screws that hold the bottom tunnel cover)
It also contains 4 red aluminum wheel nuts!!!
Conrtact me for pricing please.
Cutom Anodizing
stefan is offline   Reply With Quote
Old 03-23-2002, 05:24 PM   #2342
Default Spring rates AE, Yok and Losi
Here's the spring rates. I believe these are correct.
lbs/inch
AE-Green 12.00
AE-Silver 14.50
Yok-Yellow16.00
AE-Blue 17.00
Yok-Pink 17.50
Yok-Green19.00
AE-Gold 19.50
Yok-Orange22.00
AE-Red 22.00
AE-Copper25.00
Losi: lbs/inch
White 7.6
Orange 8.6
Yellow 9.6
Pink 10.6
Red 11.6
Silver 12.6
Blue 14.6
Purple 20
Black 25
yokomojo is offline   Reply With Quote
Old 03-23-2002, 11:24 PM   #2343
yodace's Avatar
R/C Tech Charter Subscriber
How do gear for punch and on a ozite 36 ft by 90 ft carpent track? running a p2k2, spur 88
I was geared at 18/88, alittle weird
yodace is offline   Reply With Quote
Old 03-24-2002, 12:11 AM   #2344
shrekair's Avatar
Trader Rating: 9 (91%+)
22 or so
shrekair is offline   Reply With Quote
Old 03-24-2002, 07:21 PM   #2345
Evil_S10's Avatar
Send a message via AIM to Evil_S10
QUICK QUESTION
Losi makes colored rod ends. Will they work on my XXX-S? Just because they are so much longer than stock.
Evil_S10 is offline   Reply With Quote
Old 03-24-2002, 07:37 PM   #2346
RacerTex's Avatar
Does someone make an aftermarket bumper set? I would like to get some droop adjustments that stay put. Has anyone modified the current droop screw setup? I feel like going back to adjusting with shock length.
RacerTex is offline   Reply With Quote
Old 03-24-2002, 07:45 PM   #2347
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Evil_S10:
yes, you can cut them off.....
Tres is offline   Reply With Quote
Old 03-24-2002, 08:05 PM   #2348
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
stefan: any chance i can get hold of those? do they ship internationally? im from manila philippines and shipping is usually the problem i encounter.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 03-24-2002, 08:36 PM   #2349
stefan's Avatar
Default Roborat
check your e-mail,
Stefan
Old 03-24-2002, 09:21 PM   #2350
STLNLST's Avatar
Trader Rating: 19 (100%+)
I just got home from the carpet nats and man am I tired. Congrats to all of the winner's. It was a wild weekend. I will give details when I can stay awake longer.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-24-2002, 09:43 PM   #2351
Front Block question:
When using the Trinity Low Roll Center mounts, do you use the upper or lower holes to mount the "0F" front blocks?
Rear Block question:
Also when using the Trinity Low Roll Center mounts, do you use the upper or lower holes to mount the " "2R" rear blocks?
I am having trouble with my arms movements and think I have my blocks mounted wrong.
Flash
Flash is offline   Reply With Quote
Old 03-24-2002, 10:04 PM   #2352
ROBORAT's Avatar
Flash: use the lower mounts all around when using the LRC blocks. u shouldnt have a problem.
Stefan: got your mail and replied. are the rates for the collars for a pair or a set of four?
Old 03-24-2002, 10:10 PM   #2353
Roborat - That's what I thought also, except I can't mount the "0F" block in the bottom hole. It causes my arms to bind and not move freely. I can mount any other block except the "0F". Any ideas?
Flash
Old 03-24-2002, 10:41 PM   #2354
ROBORAT's Avatar
Flash: u have to shave off a very small amount of plastic where the arms meet the chassis. (there's a small plastic reinforment rib in the chassis that the arms come into to contact with.) hope that helps.
Old 03-24-2002, 11:23 PM   #2355
I had already done that, which did not fix it.
I had to shave some material off the graphite a-arms, they were rubbing against the chassis.
Flash
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
