Old 03-19-2002, 12:12 PM   #2311
Originally posted by BLAZN420
sanitair,
Ive always run 4 deg. on the car......with 0 kick......try that or maybe try some kick.....are U running the batts. up front?????
i concur. 4 deg. w/ 0 kick, batteries up front...and it dives harder into the turns w/o giving anything up (atleast that i can tell).
diesel31 is offline   Reply With Quote
Old 03-19-2002, 12:35 PM   #2312
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ttr..try ron rosettis setup from losis web site..i love it....
Matt M. is offline   Reply With Quote
Old 03-19-2002, 05:43 PM   #2313
Trader Rating: 62 (100%+)
mad_cats: thanks for the info i thought the composite ones will fit because they look almost exactly the same, even the lengths. might as well go for the losi aluminum ones.
marvi is offline   Reply With Quote
Old 03-19-2002, 09:00 PM   #2314
Mad_Cats's Avatar
Send a message via Yahoo to Mad_Cats
Default marvi
The only differance I can plain see between the two is the ball Dia. that fits into the Diff.
Mad_Cats is offline   Reply With Quote
Old 03-19-2002, 09:25 PM   #2315
Anyone use a Kimbrough Spur Gear to check ride height? It is exactly 5mm. Just reading R/C car with Kinwalds stock asphalt setup.10mm droop sounded a little extreme. Does anyone else run this much? I'm set at 3/5 and 0 kickup
MDM3 is offline   Reply With Quote
Old 03-20-2002, 11:36 AM   #2316
MDM3-The 10mm droop is measured from the bottom of the chassis to the bottom of the tire. The article says he measures with the tires on the car.
ChadK is offline   Reply With Quote
Old 03-20-2002, 05:36 PM   #2317
Send a message via AIM to WHITESTER
Originally posted by R_Andersen
Guys, I'm running a setup with black front shocks and purple rears, 80 weight oil all around and red and orange pistons. I run on a tight ozite carpet track with purple foams up front and pink foams in the rear. I have a problem with the car pushing on corner exit when under power and the right front wheel chatters real bad. Any advice on what causes the chatter would be appreciated.
I moved the front shocks all the way out, that help with on power steering, for me.
WHITESTER is offline   Reply With Quote
Old 03-20-2002, 05:44 PM   #2318
hyperformance's Avatar
Default springs
anybody using the associated springs on the xxx? i was telling a newbie at the track about how cool ae was for selling a kit with all their springs in it, someone else stated the ae springs would work on the new xxx-s.
http://www2.towerhobbies.com/cgi-bin...1&I=LXAZU0&P=7
check out the paper in the photo, "#3988 for TC3 and xxx-S"
anybody tried this, do they work?
hyperformance is offline   Reply With Quote
Old 03-20-2002, 06:00 PM   #2319
Chad. Thanks Missed that important detail.
Old 03-20-2002, 06:12 PM   #2320
AO
AO's Avatar
Just checking. Does the new chassic make any differents. It is very Expensive man. Thinking of buying one.
AO is offline   Reply With Quote
Old 03-20-2002, 07:55 PM   #2321
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
The Chassis by itself is an ounce lighter. The whole conversion kit... I dunno how much lighter it is. But Graphite is more rigid then plastic, so you're parts are stronger and you definitely have less flex.
Jits
JitsuGuy is offline   Reply With Quote
Old 03-20-2002, 10:11 PM   #2322
ottoman's Avatar
R/C Tech Charter Subscriber
Hyperformance
I run asc springs on my XXX-S. I used the lower spring cups off a TC3 and everything fits nice. I dont remember for sure but I might have run my hobby knife around the top of the spring to scrape off the excess paint so they fit Losi threaded collars. I know I had to do that with one car I ran asc springs on.
ottoman is offline   Reply With Quote
Old 03-20-2002, 10:59 PM   #2323
Hype:
ASC and the Yok springs will fit the XXX-S threaded shocks - no problemo, no scraping.
YJ
yokomojo is offline   Reply With Quote
Old 03-21-2002, 12:54 PM   #2324
Droop and Preload questions
I've been working on gettting the ride height and droop set properly on my XXX-S and I had a few questions. I have the droop set at 3 in the front and 5 in the rear. I'm also running 4mm ride height front and rear. I have the short threaded shocks in front and the standard length threaded shocks in the rear and I'm running uncut proline foam tires. I'm also running the 1.0" springs front and rear.
The problem is that I had to run very little spring preload to get the proper ride height. Now when I pick the car up, the shocks do not extend fully to the droop screws. When I extend the suspension fully to the max droop, the spring is not under any preload. There is actually about a 1/8" gap from the top of the spring to the adjuster nut on the shocks. It seems that since the springs can not extend far enough to ever make contact with the droop scres, that the droop setting is meaningless.
If anyone could tell me if this is normal or what I need to do to correct it, it would be appreciated. I am assuming you would still want some amount of spring preload at full droop.
Thanks,
Rob
R_Andersen is offline   Reply With Quote
Old 03-21-2002, 01:14 PM   #2325
One more question also. Do you need different front carriers to get 4 degrees of caster or are the stock carriers the 4 degree ones? If they aren't, what's the part number for the 4 degree carriers?
Thanks again,
Rob
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
