Old 03-17-2002, 04:05 PM   #2281
STARSCREAM's Avatar
the diff vs oneway thing is simple.
myself and every other pro driver run the one way with rubber tires and the diff with foam tires......ALWAYS...
you must set your car up so it handles with the one way if you want to be fast, period.....
with foams there is so much traction that a one way isnt needed and will make your car too twitchy.....
but, when a new car just comes out and a oneway isnt available there are things you can do to the car to make it pretty competitive, but the one way is always faster with rubber....
hope this puts that depate to rest.....
STARSCREAM is offline   Reply With Quote
Old 03-17-2002, 09:01 PM   #2282
stefan's Avatar
Send a message via AIM to stefan
Aluminum screw kit
Guys,
would there be interest in a complete aluminum screw kit for the XXX-S in let's say red, blue and silver?
It would include all screws on the car (also the ones that you are missing if you buy the TC3 screw kit) and would only be slightly more expensive.
If you are interested, go to my site and send me a quick e-mail,please
The response will give me an idea about feasability.
Custom Anodizing
stefan is offline   Reply With Quote
Old 03-17-2002, 09:53 PM   #2283
Default Re: one way vs. diff
Originally posted by diesel31
. . . and i'm getting more corner speed than my tc-3 w/ a one-way . . . but for now and for me, the dual diff works best.
Diesel:
What's your setup for SoCal? A lot of the TC3 drivers there run a sway bar up front - you ever try it with the XXX-S?
I ran my XXX-S at SoCal on Saturday and ran pretty close to the stock setup with a 4mm ride height - I also experienced better lap times with the XXX-S than with the TC3.
Thanks,
Joe
yokomojo is offline   Reply With Quote
Old 03-18-2002, 05:47 AM   #2284
do not listen to BLAZN420, he got it all wrong. you can use the one-way even with foams. it all depends on all other factors. if it feels twitchy, you can adjust toe, springs, oil, etc. btw, the track layout is also a point to condsider.
those in the racing circuit should know... just a tip for fellow xxx-s racers
. . is offline   Reply With Quote
Old 03-18-2002, 05:57 AM   #2285
CRASH's Avatar
Trader Rating: 26 (100%+)
I will agree for mod foam on carpet, evryone runs a diff in the front, you can see this by looking at setups posted on the net. As far as the one-way for rubber tires, the fast guys around here are split 50/50. No one is dominating with either. So at least around here guys go just as fast with the diff as the guys with the one-way, explain that.
CRASH is offline   Reply With Quote
Old 03-18-2002, 01:26 PM   #2286
yodace's Avatar
R/C Tech Charter Subscriber
How do stop a car from traction rolling? My set up is basically stock, but with 50w oil all the way around. rear hub spot closet to the wheel. Running on carpet with foam tires and mod>
yodace is offline   Reply With Quote
Old 03-18-2002, 01:36 PM   #2287
CRASH's Avatar
Stiffen the car up and make sure your ride height is between 4.5mm to 5mm. Increase 50 weight oil to probably 80 weight. We run 80 weight oil white pistons in the front red pistons in the rear and blue springs all the way around and 5mm ride height.
Old 03-18-2002, 01:57 PM   #2288
yodace's Avatar
way is 50w oil to soft, do run 80w with blue springs.
Old 03-18-2002, 02:01 PM   #2289
yodace's Avatar
why do u white pistons up front, and red in the rear. can u run this set up in stock? did you go north mo r/c raceway ?
Old 03-18-2002, 03:02 PM   #2290
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
My current carpet set-up with foams has the one-way installed....
There are other guys at the track that are running the front diff.....
I did do a few changes to get the car to calm down......
Our track is a small carpet track(oflin??? ozite copy)....65x36
With 3/4 ran on the oval......... 2 big sweeping corners, one low speed, one high....
With the one-way, I'm able to pass on the inside there around 75% of the time....low or high speed......
I like the one-way, it seems to be more predictable for me......
It did take a little to get used to....NO BRAKE!!!
or if I'm on the inside of someone in a tight corner, lightly tap the brake and turn.....It's not the fastest line, but in traffic, it really helps in the tight section....
Tres is offline   Reply With Quote
Old 03-18-2002, 03:15 PM   #2291
I think that panama red (blazin) is correct on the diff with foam thing. At Puyallup we all ran diffs. I did it not because of driveability, but I did not want to chunk my foams the first time I grazed a pipe. With the diff I had no chunks, and there was some hard racing manuvers at that race.
B
BrianC is offline   Reply With Quote
Old 03-18-2002, 04:00 PM   #2292
3D
Does antone know the part number for that foam bumper that M.Dawson has on his XXX-S?
3D is offline   Reply With Quote
Old 03-18-2002, 07:23 PM   #2293
yodace's Avatar
does anyone have play in their front spindles? and how do you fix it? does losi make a strong ball stud for the xxx s.
Old 03-18-2002, 09:05 PM   #2294
STARSCREAM's Avatar
yodace,
yah, losi makes a titanium ball stud that all the team guys use on the whole car. they are great......
Old 03-18-2002, 09:47 PM   #2295
yodace's Avatar
are theythe low profile ones?what is the part number?
how do you get rid of the slop in the front spindles?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
