Old 08-30-2001, 10:31 AM   #196
Originally posted by mike_Webb
Question about the XXX-S and the front end. I was thinking about buying a flat sheet of Graphite and cutting it out to attach it to the chassis and the Body Mount to make it more firm up there.
if you do that remember that if you hit something hard enough the shock from the impact will travel through the chassis and actually might tweak it
holy ear guy is offline   Reply With Quote
Old 08-30-2001, 01:16 PM   #197
Trader Rating: 35 (100%+)
Smile
I currently drive a MR-4TC Special, but after reading a couple of articles and the posts here, I'm considering the Losi car.
Several of the design aspects of this car make me want to get it. Specifically, the one peice chassis belt cover is a neat idea. I also like the ease of access to the diffs.
An article that I read said that XXX-S required a Losi made spur gear, but that an adapter was on the way that would allow spurs from other manuf. to work. Can any of you guys confirm this?
Also, not having seen the car in person, I'm wondering about the motor mount... Is it aluminum, or is it made of the same material as the chassis? My concern is the motor heat on composite material???
Last, threaded shocks. I've seen the posts that some of you are using the threaded units from the StreetWeapon. Are these shocks a perfect fit, or just a "patch" until Losi releases shocks designed specifically for the XXX-S?
Geppetto is offline   Reply With Quote
Old 08-30-2001, 01:25 PM   #198
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
What I did to my shocks should be fine,,instead of the cyrul shocks.. I cut half of the threads off of the shock shaft ,,shortening it about 1/8th inch. this lowers the piston in the shock,, keeping it in the oil.
I also shortened the shock end by 1/8th inch,, which allows for more down travel (no bottoming)
the next thing I did was take trinity blue collars and modify them so they 2 together is one piece. I cut most of the ring off of the bottom of one, and opened the hole in the top of the other so that one "plugs into" the other,, then JB welded (epoxy) them together,, they now have 2 orings, and fit awesom! and look KEWL!!!! Now they will fit on the front of the car as well as the rear (can only fit one otherwise)
KB
Keith Billanti is offline   Reply With Quote
Old 08-30-2001, 01:33 PM   #199
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
I am thinking about getting a XXX-S and was wondering how the car does on carpet with foams and a stock motor. I looked at the Losi web site and found Andrew Gray's carpet/foam set up and it looked like the car would be stiff and carry a lot of corner speed. I need to know if the car can keep up with a TC3 on a tight indoor carpet track with foams and a stock motor. Please let me know the ups and downs of the car. Thanks.
Ty is offline   Reply With Quote
Old 08-30-2001, 01:37 PM   #200
I wont drive mine on carpet for another 2 months,, last week at our annual race there wasnt one TC3 in the "a" if that says anything,,
stock may be a little closer than mod,, but in mod,, there is no TC3 around here that can touch a XXXS,, and there are only about 5 of us who have them.
KB
Old 08-30-2001, 01:42 PM   #201
Regional Moderator
Darkseid's Avatar
Geppetto: Thinking of switching huh? Yes there will be an adapter for the spur gear. Losi driver Jason Corl said so himself when discribing his car in the Racer News section of Car Action.
The motor plate is aluminum. the clamp that holds it is plastic. You can be sure their will be an aluminum clamp out soon. Hopefully they will follow they example set by the new Losi truck and pick another color for the aluminum on this car. Blue-everybodies been there and done that. Try red, green, black, something other than BLUE!
The Losi cars are making for some great competition at the track. Looks like a really good car. I'll stick with my C4.1 though. Good luck!
TLR 22...Tamiya F104...
Old 08-30-2001, 02:19 PM   #202
TurnNBurn's Avatar
If you want to talk about a return of the old guard, I read somewhere that Jack Johnson has been seen running his XXX-NT here and there...
If Joel's racing again, he's probably doing it just for fun this time around, although you know that Trinity and Losi are still going to give him whatever he wants!
TurnNBurn is offline   Reply With Quote
Old 08-30-2001, 02:53 PM   #203
Administrator
Matt M.'s Avatar
the shocks are a direct fit, although paul lemiuex said that he thinks losi is coming out with a shorter shaft.....and body...
on the body brace.....i would worry more about stripping out the screws on a hard hit.....
Matt M. is offline   Reply With Quote
Old 08-30-2001, 03:13 PM   #204
Trader Rating: 19 (100%+)
Jack will be out soon with his XXXs. I think his almost through Bag B.
MDawson is offline   Reply With Quote
Old 08-30-2001, 04:21 PM   #205
R/C Tech Founder
R/C Tech Charter Subscriber
Yea, I managed to strip at least three of the small 4-40 3/8" screws when I was putting the car together.
Somebody told me about these things called instructions, but I didn't look too hard for them...
futureal is offline   Reply With Quote
Old 08-30-2001, 05:12 PM   #206
Ty - I race the car with foams in the stock class at a couple of local indoor carpet tracks and it's doing quite well. Definitely not a problem keeping up with the TC3's. I was concerned about this car on carpet too until I saw how well they did. In my opinion this car seems a little easier to drive in comparison to my TC3 but that's probably just attributable to set up. If you need a base line set up just let me know.
Schuie Driver is offline   Reply With Quote
Old 08-30-2001, 07:44 PM   #207
Ty
Ty's Avatar
Schuie driver:
A baseline setup would be great. Gearing, motor, batts, other equipment would be great also. Are you running with any modifications to the car? What body, tires, oil, springs, shock and camber positions. Thanks so much.
Old 08-31-2001, 12:06 AM   #208
TRF414M's Avatar
I would like to know what is the material that they are currently using in XXX-S. Are they graphite? I saw the new option parts from Losi in their web site, are they all new parts for XXX-S?
TRF414M is offline   Reply With Quote
Old 08-31-2001, 02:12 AM   #209
Thumbs up
I get mine today!!!!!!!!
Any thing I should look out for..........
Wolverine is offline   Reply With Quote
Old 08-31-2001, 05:31 AM   #210
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
TRF - The Losi XXX-S stock chassis & parts are made from the losi Stiffzel, its like a composite. The option parts you was were the graphite parts.
Wolverine - Take your time, and pre-thread all the screws with the oversived 4-40 ( its the gold screw ). If you don't, you will do what Futureal did and strip the head of the small screws.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
