Old 02-26-2002, 09:33 PM   #2056
Trader Rating: 19 (100%+)
Default Re: Gearing/shock ?
Originally posted by MDM3
I was thinking of starting with a 25 or 26 pinion with a new P2K2 Pro.
I have now 24-27 pinions.
running the 90t 48spur.
fairly tight LHS parking lot track
The LHS guy tells me I am crazy "Way too overgeared for running that setup. Drop to a 19 or 20"
What to do?
The P2K2# 28,262 120.8 watt,67.7 eff.,165 trq. Decent or dog?(I thought the RPM looked low)
Per the tip on the XXXS Tech page, I shortened the bottom shock eylets 1/8" and trimmed the top collar ring 1" springs.
Will this suffice until the threaded short shock kit arrives? Thanks Mike
Mike,
The eyelet mod you did will lower the ride height. To get the benefit of increase steering you can shorten your front shock shafts by .100 shorter than the Losi shafts.
Although you wont have the full benefit of the new shock shafts and shortened shock bodies - this will be a good fix until your order arrives.
Btw, your guy at your LHS is mis-spoken. Start with 24. 19 and 20 is way too low.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 02-26-2002, 11:53 PM   #2057
Default re Titanium screw sets
Sydewynder
Titanium racing in the UK does a complete Ti screw set for 33. Ive not yet bought one but consider it to be good value for money at that price!!
Rich
chownr is offline   Reply With Quote
Old 02-27-2002, 04:48 AM   #2058
littledog's Avatar
R/C Tech Charter Subscriber
How much would that be in us dollars?
littledog is offline   Reply With Quote
Old 02-27-2002, 06:07 AM   #2059
Its round about $45.
You can see the other Titanium stuff they do (diff outdrives, cvds, hinge pins etc etc) at their web site http://www.titaniumracing.com/site.html
i dont know whether they will ship to the US but e-mail them you never know. I have been in contact with Paul white their sales manager. If they cant ship direct try Apex models http://www.apexmodels.co.uk or snetterton model shop http://www.sm-modelshop.co.uk cos they are both supposed to stock Titanium Racing products and are first class mail order specialists
Good luck
Rich
Old 02-27-2002, 06:55 AM   #2060
Trader Rating: 87 (100%+)
This is my current set-up:
Front:
4 degree blocks
purple congo springs
56 pistons with 60 wt oil
One in on the shock tower from outside
Camber rod one out from the inside
High roll center
4.5mm ride hight
Losi Sway bar 2nd lightest size
Rear:
Stock rear hubs
Losi Purple springs
One hole in on shock tower from outside
Camber Rod long as possible
High roll center
4.5mm ride hight
Plaid tires up front and purple rears
This was avery easy to drive set-up and smooth transitions on the tight carpet track we run on. Just keep a good amount of tension on the belt and have fun!
dan-o is offline   Reply With Quote
Old 02-27-2002, 07:38 AM   #2061
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
My setup is close to yours, I use 57, 40w, black in the rear. And no swaybar up front. I find this setup to be the easiest to adjust from track to track. Just move the shocks around to add or remove steering. I also use congo yellow in the front sometimes.
For anyone running carpet, you can't go wrong with this setup. It's very smooth with good steering, but not overly agressive.
ChristopherKee
ChristopherKee is offline   Reply With Quote
Old 02-27-2002, 08:19 AM   #2062
Ill Factor's Avatar
Default Graphite Conversion
Does anyone know how much weight the Graphite conversion kit drops? Also can you use the short shafts with the stock sized bodies? My local LHS says this will work fine and that I will not need the short bodies.
Ill Factor is offline   Reply With Quote
Old 02-27-2002, 08:47 AM   #2063
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Rich
Do you know what grade of Titanium that they use? I was looking at putting together a commercial pure grade 4 titanium kit.
BHenderson is offline   Reply With Quote
Old 02-27-2002, 09:44 AM   #2064
Send a message via AIM to WHITESTER
ChristopherKee
I agree! Both of you have a setup close to mine. Except I am running 80wt shock oil all the way around. With the lighter shock oil how will that effect handling? I know others are running a similar setup at my local track. I am not running a swaybar either. The carpet I am running on is very old, and has a TON of traction.
WHITESTER is offline   Reply With Quote
Old 02-27-2002, 03:19 PM   #2065
Mad_Cats's Avatar
Send a message via Yahoo to Mad_Cats
Default Re: Graphite Conversion
If I am not mistaken, one Ounce
Mad_Cats is offline   Reply With Quote
Old 02-27-2002, 04:30 PM   #2066
Originally posted by Doug Gaut
On the one-way questions. I had a problem with my outdrives after I installed the retaining rings because it squezed them a little and bound up on the ball. I took a flat file and removed a (very) small amount of material on both sides. It takes no time at all. Now everything is free. I built a second one this weekend for a friend and we didnt have the binding problem on the cvds but we did have a problem with a bind in the drivetrain. As we rotated the tires something would catch and bind up. I took the front end back apart and found that I had not completely tightened up the 3 screws that attach the bearings. I was worried about over tightening them but it is far worse to not have them totally tight. Once we tightened them all the way up everything was fine. BTW, we both have picked up over half a lap with the one-ways installed!!!
Now I have a question. What type of lube should be used on the one-way bearings? I used diff lube but was just wondering if there is something else I should be using?
Thanks Doug
I have used Racer's edge's one way lube. Some others use light oil and others say use nothing at all. The key is maintainence (regular cleaning) and to use a very very light coat of lube. The 1 way needle bearings need to be free to roll [i]and lock[i/]. If there's too much grease it'll prevent the needles from locking properly.
Sydewynder is offline   Reply With Quote
Old 02-27-2002, 04:32 PM   #2067
Default Re: re Titanium screw sets
Originally posted by chownr
Sydewynder
Rich
Thanks for the info chownr.
Old 02-27-2002, 06:06 PM   #2068
CRASH's Avatar
Trader Rating: 26 (100%+)
Setup for stock, fairly tight track, long straight!
Front:
Natural piston
80 Weight oil
Blue springs
Shocks stock location
No Limiters
No Kickup
4 Degree caster blocks
Camber rod as long as possible
-1 degree of camber
0 Degree toe in or out
5mm Ride height
Xpress narrow tires HPI Black molded soft inserts
Rear:
Red piston
80 Weight oil
Blue springs
No limiters
No anti-squat
-1 Degree of camber
1/2 Degree hub carriers, 2 1/2 Total
5mm Ride height
Xpress wide tires stock inserts
No one-way
Batteries Forward
Transponder in front window
Protoform Stratus body
CRASH is offline   Reply With Quote
Old 02-27-2002, 09:23 PM   #2069
Regional Moderator
kansasracer's Avatar
Crash,
I this the setup you run at BS?
kansasracer is offline   Reply With Quote
Old 02-27-2002, 11:55 PM   #2070
Default re Titanium stuff
Brandon
I havent got a clue what grade they use but Im sure if you e-mail them theyd be pleased to help
Rich
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
