Old 02-26-2002, 01:55 PM   #2041
Default Re: Losi XXX-S Titanium Screws
Originally posted by PorscheSuperCup
Guys,
I might be able to offer a compelete screw set for the losi xxx-s, how many of you would be intrested in buying a complete set for your car???
I am.
Sydewynder is offline   Reply With Quote
Old 02-26-2002, 02:04 PM   #2042
Originally posted by ASM
Can someone give me a better idea of how to set the diffs on this car? For example, AE says to tighten them up and then back off 1/8 to 1/4 turn and they're about perfect. Losi doesn't come anywhere close to that type description for the xxx-s. Please let me know what you guys are doing. Many thanks!!!!!!!!!!
What I do is after the screw is seated, I tighten 1/8 to 1/4 turn at a time, rotate the outdrives like you're checking the diff action then hold (pinch) the outdrives between my thumb and index finger in 1 hand so they can't turn and try to rotate the diff gear with the other. I do this process until I can barely turn the diff gear.
You want to rotate the outdrives like your checking diff action so you don't flat spot the balls and rings in one place as you tighten the diff down.
Old 02-26-2002, 02:06 PM   #2043
Originally posted by Tres
Any one having an issue with the one-way install...???
Mine seems to be binding...
drop me an email at: tres_leonard@hotmail.com
or post here for everyone to read.....
Binding in the car? Out of the car? Are the 6 balls spaced evenly in the diff gear? Are the balls in the outdrive dimples on the backside? I just got one and will let you know when I get it together.
Old 02-26-2002, 02:26 PM   #2044
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Thanks guys, I'll give it a shot.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 02-26-2002, 03:34 PM   #2045
yodace's Avatar
R/C Tech Charter Subscriber
Does anybody the part number for red aluminum screw kit? Or were I could get them? I am also interested in geting some titanium screws.
yodace is offline   Reply With Quote
Old 02-26-2002, 03:34 PM   #2046
yodace's Avatar
Does anybody know the part number for the red aluminum screws kit? Or were I could get them? I am also interested in geting some titanium screws.
Old 02-26-2002, 03:56 PM   #2047
yodace's Avatar
what is a good general carpet set up?
sorry for the double post.
Old 02-26-2002, 04:59 PM   #2048
Send a message via Yahoo to Doug Gaut
On the one-way questions. I had a problem with my outdrives after I installed the retaining rings because it squezed them a little and bound up on the ball. I took a flat file and removed a (very) small amount of material on both sides. It takes no time at all. Now everything is free. I built a second one this weekend for a friend and we didnt have the binding problem on the cvds but we did have a problem with a bind in the drivetrain. As we rotated the tires something would catch and bind up. I took the front end back apart and found that I had not completely tightened up the 3 screws that attach the bearings. I was worried about over tightening them but it is far worse to not have them totally tight. Once we tightened them all the way up everything was fine. BTW, we both have picked up over half a lap with the one-ways installed!!!
Now I have a question. What type of lube should be used on the one-way bearings? I used diff lube but was just wondering if there is something else I should be using?
Thanks Doug
Doug Gaut is offline   Reply With Quote
Old 02-26-2002, 05:02 PM   #2049
Trader Rating: 62 (100%+)
Originally posted by MDM3
I was given (2) 1.125 turnbuckles instead of the 1.375 ones for the rear.(step 46) Anyone else had this problem? Maybe the LHS will have a replacement.
i also had this with my kit. i thought i was the only one. i used another shock tower hole (not the stock setup) for the upper link so that i can thread the plastic ends deeper into the turnbuckle while still maintaining the correct camber.
marvi is offline   Reply With Quote
Old 02-26-2002, 05:35 PM   #2050
ASM
ASM's Avatar
Various red screws and nuts can be found at
www.fasteners-express.com
Scott Meeks
USVTA Member #116
Old 02-26-2002, 05:35 PM   #2051
ASM
ASM's Avatar
ooppsss!
www.fastener-express.com
Scott Meeks
USVTA Member #116
Old 02-26-2002, 06:44 PM   #2052
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Doug: thanks for the reply....
I took it all back apart and put it back together...works fine now...
Don't know what the issue was....if I was to guess, I would go with the 3 screws?????
Thanks......
now to find a good carpet set-up with it.....
I planned on taking the Andrew Gray set-up and doing a few changes...
Any ideas?
Thanks,
Tre's
Tres is offline   Reply With Quote
Old 02-26-2002, 09:08 PM   #2053
Default Gearing/shock ?
I was thinking of starting with a 25 or 26 pinion with a new P2K2 Pro.
I have now 24-27 pinions.
running the 90t 48spur.
fairly tight LHS parking lot track
The LHS guy tells me I am crazy "Way too overgeared for running that setup. Drop to a 19 or 20"
What to do?
The P2K2# 28,262 120.8 watt,67.7 eff.,165 trq. Decent or dog?(I thought the RPM looked low)
Per the tip on the XXXS Tech page, I shortened the bottom shock eylets 1/8" and trimmed the top collar ring 1" springs.
Will this suffice until the threaded short shock kit arrives? Thanks Mike
MDM3 is offline   Reply With Quote
Old 02-26-2002, 09:17 PM   #2054
newracer's Avatar
Thumbs up Ti screws
I'd buy them, what price?
newracer is offline   Reply With Quote
Old 02-26-2002, 09:29 PM   #2055
Send a message via AIM to WHITESTER
Default Re: Gearing/shock ?
The LHS guy tells me I am crazy "Way too overgeared for running that setup. Drop to a 19 or 20"[IMG]
All you can do is try. If the other cars are pulling you down the straight, then you need to go up a tooth. If they are pulling you in the infield, go down a tooth or so. You're running rubber tires right?
On carpet, with 58mm tires I'm running 24/90 with the same motor. I would think a 19 tooth or 20 would be too low.
Run some practice laps with someone else, and compare the speed. You might have to go as low as 22,23,24.
WHITESTER is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
