Old 02-23-2002, 09:16 PM   #1996
JimmyMac's Avatar
Default Re: Re: Blue is better
Originally posted by seamus0g
Ithink someone has been playing with Photoshop...
Unllikely... anyways, Stefan, you gonna be at Race City Tomorrow? I might run mod class if you show up. If not, Stock again. Bring the XXX-S, I'd like to check it out.
Jimmy Mac
JimmyMac is offline   Reply With Quote
Old 02-23-2002, 10:26 PM   #1997
stefan's Avatar
Send a message via AIM to stefan
Jimmy,
no racing for me tomorrow.
seamus0g,
dude it would probably take me longer to do it with photoshop than it took me to do the real thing :-))
stefan is offline   Reply With Quote
Old 02-23-2002, 10:29 PM   #1998
Ill Factor's Avatar
Default Stefan
Can you do any color, and if so what would you charge
Ill Factor is offline   Reply With Quote
Old 02-23-2002, 10:37 PM   #1999
stefan's Avatar
Illfactor,
it's only a matter of finding the right dyes.
The greenish yellow shock collars were supposed to be a darker green, but the alu didn't take it too well
The blue is a special anodizing dye that I bought at a plating shop (expensive).
I will be looking for some more colors.
So far, I can do all kinds of blue shades, the neon" yellow, red and gold.
I'd like to get a bright orange and a bright green.
What parts would you wanna have done?
Old 02-23-2002, 11:07 PM   #2000
Ill Factor's Avatar
Default Stefan
I would want red threaded bodies with natural aluminum collars and a red heat sink
Old 02-24-2002, 07:09 AM   #2001
stefan's Avatar
You want the red matching the MF parts?
Natural is no problem.
Old 02-24-2002, 07:28 AM   #2002
Default advise
Just got my XXX-S and finish assembling it. A bit disappointed at first, the package is sort of one bevel washer and the thrust washer is bent.
Anyway....
I got some trouble fixing up my Express wheel on the 12mm hex
hub supplied. I wonder if there is a compatible Aluminium hex hub that I can use ?
I also find if I followed the instruction, my front ride height become very high as compared with the rear. I also notice that the arms are not level with the ground. This seems strange to me because all of the other touring car that I have seems have arms level or arms point up on the ends.
It seems that the shocks are too long for the car.
This is unlike my Yokomo MR4-TC where it seems more balance out of the box.
ongbenghui is offline   Reply With Quote
Old 02-24-2002, 07:49 AM   #2003
CRASH's Avatar
Trader Rating: 26 (100%+)
If I understand other people in this thread coreectly and from what I have seen the front shocks are two long for the front with the car set at high roll center. Losi makes a shorter shock set kit or you can cut them down. MDawson has a good site on this car and can tell you how much to cut off the shaft and the ball cup. Or you can put the lower roll center blocks on the car by Trinity or Speedtech and then you mount the pivot blocks in the lower holes which eliminates this problem. Sorry to be brief but it would take for ever to explain it here, just goto MDawson's site it will help greatly.
http://www.fictionlab.com/losifaq/index.htm
CRASH is offline   Reply With Quote
Old 02-24-2002, 04:13 PM   #2004
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Does anyone know the part number of the just released Trinity Matt Francis red shock collars? Thanks!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 02-24-2002, 05:57 PM   #2005
Evil_S10's Avatar
Send a message via AIM to Evil_S10
Hey Stefan I would pay you good money for them. If you ever plan on selling those puppies. BTW that is an awesome job.
Evil_S10 is offline   Reply With Quote
Old 02-24-2002, 07:14 PM   #2006
ASM
Where did you hear about the MF Red shock collars? I have been waiting for trinity to get a clue on that one.
Flash is offline   Reply With Quote
Old 02-24-2002, 10:15 PM   #2007
stefan's Avatar
Default Evil S10
thanks.
I'll keep those, 1 outdoor set and one for carpet.
You can go ahead and buy some shock bodies and send them to me.
Old 02-25-2002, 12:39 AM   #2008
yodace's Avatar
R/C Tech Charter Subscriber
This may be a dum question. What is a cvd driveshaft? Is it the say thing as the axle or dogbone?
yodace is offline   Reply With Quote
Old 02-25-2002, 08:41 AM   #2009
The CVD is the description for the whole drive assembly from the diff outdrive through to the wheel connection on the stub axle. CVD stands for constant velocity driveshaft. The dogbone is as its name implies the bone shaped driveshaft linking between the diff outdrive and the ball joint on the axle. the axle is the threaded component that you connect the wheel onto and spins in bearings (or bushes) in the spindle carriers.
Hope this helps
Rich
chownr is offline   Reply With Quote
Old 02-25-2002, 12:46 PM   #2010
R/C Tech Founder
ongbenghui: The stock Losi wheel hubs should fit any standard-size touring car tire. There are two different size hubs that come in the Losi kit; make sure you try both of them. The smaller one is for Losi-branded wheels, the larger one is for regular touring wheels.
For the front/rear ride height difference, I can only think of a few things. First, make sure that you have the droop screws in the right places. The longer ones go in the rear, the shorter ones in the front. Second, to reduce the ride height you can lay the shocks down a bit. Third, assuming you are still running the standard clamp-style shocks with the kit, you can move the collars all the way up the shock, so they are almost half-off the shock, and then clamp them. This is how I had to run mine to get the ride height I wanted, until I got the threaded shock bodies.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
