Old 02-16-2002, 09:33 PM   #1921
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
MDM3, something I'd recommend is replacing the 4 steering arm bushings with 4 5mm bearings. I used the dynamite red seals. I think it's one of the first things you should do to the car and am actually frustrated with Losi for even putting those lame bushings in the kit for steering! Oh and the 4 bearings should only cost you about 12 to 14 dollars.
Other then that, the Losi is sweet!
Jits
JitsuGuy is offline   Reply With Quote
Old 02-16-2002, 09:35 PM   #1922
littledog's Avatar
R/C Tech Charter Subscriber
Speaking of heat.Whatch out for your chassis warping near the motor.I seen this happen to the extreme.This guys motor was practicly laying side ways.Heat is not too good for the Losi chassis.
littledog is offline   Reply With Quote
Old 02-17-2002, 09:53 AM   #1923
STLNLST's Avatar
Trader Rating: 17 (100%+)
The chassis never showed any signs of being bothered by the heat with track temps above 140 this past summer. This was with 8 turn modified motors. What sort of problem did this racer have that would cause the motor to lay sideways??
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-17-2002, 10:46 AM   #1924
littledog's Avatar
Default His P2K was geared wrong And he did not want to listen to anybody.
BTW,Any body with any sugestions on gearing with a Phantom 19 turn on a tight low grip outside track.Well I call it tight.It's only got one straight [at times][our club track allways changes].And I'm still running the stock 88t.Constructive critisiom is allways welcome here.THANKS
LITTLEDOG
Old 02-17-2002, 10:51 AM   #1925
STLNLST's Avatar
It always happens that way....someone doesn't want to listen to helpfull advice and the worse case happens. Oh well!!!
I haven't run a 19 turn motor so I'm not sure of the gearing but I'm sure someone on this thread will be able to help you out.
Old 02-17-2002, 11:09 AM   #1926
Send a message via Yahoo to Doug Gaut
We run on a small track and gearing for a p2k is 24/90. With the 19t chameleon (old style) we run 22/90. Just peaks out 3-4 ft from the end of the straight-away.
BTW, the oneway is awesome, just set the track record and found the missing steering that I have been looking for!! Tried a complete new setup and now the car has the punch of a tc3 and the stability of the xxx-s. What a combination!! This car rocks!
What is so strange is that the track is concrete with the track temp being 58 deg. but the bite is soo extreme that we started out with sorex 32s and ended up with sorex 36s by the end of the nite. We are running the Peak JB foams (firm blues).
Doug
Doug Gaut is offline   Reply With Quote
Old 02-17-2002, 04:06 PM   #1927
littledog's Avatar
Oneway?On a tight track?
Old 02-17-2002, 04:10 PM   #1928
Well, its small but flowing with one hairpin. It has alot of bite though. With the stock diff my car had a push in the middle and when I went to the low roll center it still pushed until I put the oneway in it. Go to enidrcracing.com to see pics of the track. Let me know what you think, maybe my setup is all wrong??
Old 02-17-2002, 04:17 PM   #1929
littledog's Avatar
Well our track is somewhat a little tighter than that[In my opinion].your track is pretty much a flowing track.Plus we don't have that much traction a you guys do.But thanks.I do have same problems you had though.I guesse I could give it a try.
Old 02-17-2002, 09:02 PM   #1930
JitsuGuy's Avatar
littledog, even a small tight track has a flowing line to it. If you can drive that line consistantly, the one-way diff is for you... What I've found out is that the one-way will work on any size track, and will make you faster if you can drive the way a one-way needs to be driven. However, If you're heavy on the breaks, a one-way isn't for you.
Jits
Old 02-17-2002, 09:05 PM   #1931
littledog's Avatar
BRAKES!What's that?! I got to get a one way now.Thanks
Old 02-17-2002, 09:09 PM   #1932
Ill Factor's Avatar
Drove the Losi for the 1st time today. No practice and still qualified 2nd. Very quick and easy to drive car. Makes racing very enjoyable for those who are not quite as meticulous, as we can still be very competitve.
A few gripe though.
Durability. Broke two carriers in one day. Not cool.
Set screw thats hold pins stipped out before the car hit the track
All in all I definately think losi has a great greay car.
One question for any one. My car clicked slightly when off power, A buddy said it may be due to me running a drag brake profile. Any know if this normal? OK I lied another question. Where should I run the tensioner?
i
Ill Factor is offline   Reply With Quote
Old 02-17-2002, 09:15 PM   #1933
littledog's Avatar
The noise you heard was the belt skipping slightly.Don't worry it's normal.As for the tentioner.I am a little confused about what you are talking boutBTW I ain't no pro at this but I know bout some of the gripes about the car.I researched bout it before purchase.
Old 02-17-2002, 10:15 PM   #1934
Regional Moderator
kansasracer's Avatar
Doug:
Put the oneway in tonight as well. Had to change my setup slightly but it did rock...
BTW,
You Wichita racers should take a trip up here. Huge carpet track just on the Missouri side (rumor is, there getting a perm facility in a month) right now we are in a roller rink....
Great racing every Sun. it would be fun to have some fresh racers...
kansasracer is offline   Reply With Quote
Old 02-17-2002, 10:53 PM   #1935
STARSCREAM's Avatar
Ill Factor,
for starters, get rid of the drag brake profile, believe me, it is slowing you down.
the belt tension can be checked by having the car on a stand, then holding the rear tires and lightly moving them back and forth while looking inside the gear cover at where the belt moves over the top of the spur gear. (sorry, this is hard to explain with writing) anyways, you should notice the belt having a little slack when lightly rotating the tires back and forth with your hands. there should only be a little of slack. first, tighten the belt so you have no slack, then loosen the tensioner a little till you have a little slack. I hope this works. if you have any other questions about the car then ask. I have had alot of experience with it already and Im really fast with it, later
STARSCREAM is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
