Losi XXX-S
#1846
pic 5
#1847
pic 6. Sorry had to list separately not sure how to put them all together.
The Dynamite graphite shock towers are .1oz lighter than the Losi Graphite towers.
So far the car is 1.4oz lighter, just for the chassis.
#1848
Nice work Crash. What type of machine did you use to do that work?
#1849
Trips-The track is smooth and high bite, I was going to try the kinwald set up off the losi site as a baseline.
Shuie- These guys up here are just soo fast with the TC3's that we have a long way to go indoors, to get this car going. It is just more consisitant and predictable, the AE car is fast and tons of punch, but it just feels like you are riding on the edge too much. The losi car just gave me the warm and fuzzy feeling when driving it. And outdoors on the larger flowing tracks the car is great, just that indoor tight car set-up is needed.
#1850
The above modifications were done on a 15 year old mill ( the name has been worn off), and a dremel. And patience.
#1851
BSYDOR,
Do you feel that you can replicate the work you did with that millwork?
#1852
MDAWSON,
Yes it could be done agan, since it was done by freehand and calipers, it probably would have some slight difference, but close.
#1854
wow...that is some nice work.....
#1856
But does it flex now?
The mill work looks great. However did this increase flexing torsional and/or radial flex? Please be specific. Thanks!
#1857
As far as we can tell at this time it did not decrease any of the chassis rigidity. The car will be ran this weekend and then we will have some test results. The car will have aluminum CVD's front and rear, aluminum lowering blocks, aluminum screws, titanium hinge pins, turnbuckles and ball studs. The car is being built on the premises of making it as light as possible.
#1858
Guys, Kinwald was already running a different chassis at the 'Birds.
It was also milled, but not all the way through.
So, no holes, just recessions, a lot of them
#1859
Nice job on the chassis Crash.
#1860
will the composite CVD shafts from the TC3 fit the XXX-s? or are there losi composite shafts available? also, has anyone tried the spur gear adaptor for different size spurs? what would be a good starting point for stock (other than the 88t spur that came with the kit)? thanks for any info!
