Old 02-02-2002, 06:15 AM   #1786
RacerTex's Avatar
I know the c-hubs fit because I use them on my XXX-S. You need to enlarge the hole some for the CVD to fit through. I never thought about the steering knuckles - no comment. Looks like the rear hubs would fit, but the geometry would be off. They have the axle several mm below the losi ones.
RacerTex is offline   Reply With Quote
Old 02-02-2002, 11:26 AM   #1787
R/C Tech Founder
R/C Tech Charter Subscriber
I would assume that the front knuckles would fit (since they rest in the C-hubs, and if you're using the AE hubs...) but I am guess that they would throw the geometry off.
I have never seen one of the knuckles (or whatever their proper name is) get broken, since the force of impacts normally ends up on the arms or C-hubs. I wouldn't worry too much about having spares of them.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 02-02-2002, 12:15 PM   #1788
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I have... I broke mine at the bottom where the screw goes in. It cracked right there. It was one heck-uva hit though.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-02-2002, 02:15 PM   #1789
Trader Rating: 23 (100%+)
the AE Spindles actually have a longer arm than the Losi spindles. you would have to adjust the links from the steering bellcranks. they may provide more throw than what you want.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 02-02-2002, 02:57 PM   #1790
R/C Tech Founder
TSR6: Losi needs to hire you as the "worst case scenario" when they test their cars.
Old 02-02-2002, 04:38 PM   #1791
RCTech Member #2
TSR6's Avatar
When can i start?
Troy
RCTech Member #2
Old 02-02-2002, 04:54 PM   #1792
R/C Tech Founder
As soon as you stop quoting the message you are responding to when it's right fricking above you! Sheesh!
heh
I finally got my .28" shocks today. Car is already handling great. Going to try 60/50 oil with a stiffer set up and see what happens. Still no swaybars.
Old 02-02-2002, 05:59 PM   #1793
STLNLST's Avatar
Trader Rating: 21 (100%+)
The car was on rails today. It's going to be an great nats for me if I can keep up the good driving. The car met up with a freak crash today though in the last round of qualifying. The damage looks like it's going to cost me a oneway out drive, front bumper, front bumper foam, chassis, front diff cover, and the screws for the front of the car. I ran a friends XXX-S for my main and his car was dialed too. Traffic wasn't too kind to anyone in the main so I pulled the car off before something happened to it.
futureal- Call Billy at Speedworld. He had the sway bars on the wall yesterday along with the new green springs.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-02-2002, 06:36 PM   #1794
Regional Moderator
kansasracer's Avatar
where do the new green springs fit? Are they in between the blue and purple?
kansasracer is offline   Reply With Quote
Old 02-02-2002, 06:49 PM   #1795
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
kansas..yes between blue and purple
fut...docks had a swaybar set in there yesterday.....unless wernik bought them.....he buys all that stuff and does not race...really screws the racers up...
Matt M. is offline   Reply With Quote
Old 02-03-2002, 12:07 AM   #1796
Regional Moderator
By the way:
I was just looking at the coverage of the Novak race and I saw Kindwald's car. That looks so crappy...does anyone know if it actually worked?
I know he is a good driver, but what is he trying to achieve by "milling" (and I use that term loosely) out the drive tunnel...
It looks like A$$... just my 2 cents...
Old 02-03-2002, 01:18 AM   #1797
R/C Tech Founder
Kinwald's car was, as far as I can tell, the best car there.
I know he's a good driver, but he was able to take the corners better than anybody. Part of that has got to be the car. I'm not saying the milling job helped in that sense, just that there certainly wasn't anything *wrong* with the car either...
Old 02-03-2002, 12:01 PM   #1798
Anyone tried to cut away material on the standard chassis???
My XXX-S is 88g to heavy........ (1500g is minimum limit where I race)
So I thought of doing a "Kindwall" on my XXX-S. Anyone tried it??? Do you think the chassis will flex a lot if I try????
By the way...
What bodies do you run????? Currently I run a Protoform Stratus.
TeeJay is offline   Reply With Quote
Old 02-03-2002, 01:13 PM   #1799
Regional Moderator
Darkseid's Avatar
TeeJay: Well theres not much doubt that it will flex more than Kinwald's did. He preformed that mod on the Graphite chassis, so your regular Stiffezell chassis will definitely flex more. Now whether it flexes too much is a matter of how it feels on the track after you try it.
If you run somewhere that has debree on the track, don't even think about "doing a Kinwald".
TLR 22...Tamiya F104...
Old 02-03-2002, 01:32 PM   #1800
STLNLST's Avatar
TeeJay- I wouldn't be so quick to mill out the chassis. Even though you need to shave off some weight you are giving up your sealed drive train. It might be easier to do instead of buying a graphite chassis but holes in the drive train makes the car too open to pebbles and other stuff on the track.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
