Old 01-28-2002, 02:38 PM   #1726
R/C Tech Founder
R/C Tech Charter Subscriber
Whenever I have a glitch problem on my car, the very first thing I do is try a different motor. Nine times out of ten that fixes the problem, especially with the newer motors that have pre-soldered or built-in capacitors.
If the motor is the problem, I just take out the pre-installed caps and solder on the regular ones (like you had to do to every motor back in the "old days" of 2-3 years ago )
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-28-2002, 05:45 PM   #1727
MARK DAWSON
what kind of AE chassis film are you talking about.
JONW1020 is offline   Reply With Quote
Old 01-28-2002, 05:48 PM   #1728
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by JONW1020
MARK DAWSON
Jon - AE makes a "protective film" for the bottom of the chassis ( keeps the chassis from getting scratched). I think XXX-main makes one also.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-28-2002, 08:17 PM   #1729
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
here is the skinny on the tires....chris and barry were on yok 139gs.....paul and every one else were on sorex 28(however paul was on 24 sorex in his final main)...the reason the yok tires were better, was due to the fact that the traction was so high that they were more consistent....however they were only faster for one run.....in the sweaper corner pauls car was on two wheels part of the time, due to the tires.....
mdawson...when will we expect them?????
Matt M. is offline   Reply With Quote
Old 01-28-2002, 08:21 PM   #1730
Trader Rating: 19 (100%+)
not sure when they will be out the door. i was handed my samples about 3 weeks ago.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-28-2002, 09:03 PM   #1731
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Man, I love this site! You all know so much! MDawson, your website rocks man.
Jits
JitsuGuy is offline   Reply With Quote
Old 01-28-2002, 09:05 PM   #1732
JitsuGuy's Avatar
Oh yeah, I forgot to mention that I'm currently building my XXX-S and it's a blast. I guess the first thing I need to do is get threaded shocks right? Anything else you all would recommend? I heard I should replace the 4 bushings for the steering with 4 bearings of the same size so I skipped package C until I can get those bearings. Do you all recommend this?
Thanks,
Jits
Old 01-28-2002, 10:52 PM   #1733
yes, the steering bearings are essential.
TEAMORCA.SHOP
Old 01-28-2002, 11:05 PM   #1734
seamus0g's Avatar
Thumbs up
yo mr losi, how about those setups from the Novak?
seamus0g is offline   Reply With Quote
Old 01-29-2002, 07:51 AM   #1735
XER987's Avatar
HEY MARK DAWSON,
WHAT ARE THE SIZES OF THE STEERING BEARINGS? ARE THE SIZES OF THE STOCK BUSHINGS IN THE MANUAL?? THANKS.
XER987 is offline   Reply With Quote
Old 01-29-2002, 08:06 AM   #1736
stefan's Avatar
Send a message via AIM to stefan
5x8 mm
stefan is offline   Reply With Quote
Old 01-29-2002, 08:22 AM   #1737
Administrator
Matt M.'s Avatar
i will try and put those setups up tonight....
Old 01-29-2002, 08:57 AM   #1738
Send a message via AIM to ZER01
Thanks,
Jits
(1) Complete .28 threaded shock body set for the front(2 titanium shafts,2bodies). Part#LOS5081
(1) .36 threaded shock body set for the rear. Part#LOS5054
(1) Team Trinity shock collars for losi type threaded shock bodies. Part#TTK4038
(4) 5X8mm. bearings for the steering bellcranks. Part number can vary.
Well, thats about all I can think of. Good luck and happy racing!
ZER01 is offline   Reply With Quote
Old 01-29-2002, 09:49 AM   #1739
MDawson,
I was on the web site and noticed the following:
XXX-S DELRIN DIFFERENTIAL PLIES which the side bar says is 73T. Isn't the standard 41(Optional gear) 42 stock. If this is the case then won't this change the internal drive ratio?
nitrorcfan is offline   Reply With Quote
Old 01-29-2002, 10:05 AM   #1740
nitrorcfan
dont have an answer for that. the description is from CML. sent them an email to clarify what the actual product spec is but i beleive the pulleys are actually 41/42 and not 78 like they have posted.
TEAMORCA.SHOP
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
