Old 01-23-2002, 05:04 PM   #1681
Trader Rating: 62 (100%+)
are there any aftermarket front oneway units for the xxx-s? if there are, how do they compare to the one made by losi/trinity?
marvi is offline   Reply With Quote
Old 01-23-2002, 05:18 PM   #1682
mike_Webb's Avatar
Send a message via AIM to mike_Webb
The chattering also comes from the screw that goes into the bottom of the carrier to hold the steering spindle in. I put a .030 washer on it and then screwed in the screw and now with the steering totally maxed out I have no chatter at all in the front. You could use a smaller screw but I would stick withteh longer one with 1 washer under it. You may also want to put a .030 washer under the ball carrier that screws into the spindle also.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 01-23-2002, 07:50 PM   #1683
Send a message via AIM to ZER01
Mike Webb
Meaning the end of the screw is hitting the cup on the bone?
ZER01 is offline   Reply With Quote
Old 01-23-2002, 09:24 PM   #1684
mike_Webb's Avatar
yup
Old 01-23-2002, 09:45 PM   #1685
I don't think so, that chattering is coming from the cvd's binding at the joint. There's numerous post of people saying that their aluminum cvd bones are busting right where the cvd pin goes in. One one to eliminate the chattering is that you'll need to glue a .030" washer to the front spindle to eliminate the steering throw which is part of the reason why the cvd's are binding. Also, mounting the arms forward will help. This helps angle the cvd's straighter instead of angled back.
Old 01-24-2002, 07:49 AM   #1686
XER987's Avatar
THANKS GUYS, I'LL TRY BOTH SUGGESTIONS AND SEE WHAT HAPPENS.
XER987 is offline   Reply With Quote
Old 01-24-2002, 05:15 PM   #1687
what size of e-clips and washers will fit in the outer hinge pins of the xxx-s?
Old 01-24-2002, 05:15 PM   #1688
What are the size of hex screws use on xxx-s. thanks
smash123 is offline   Reply With Quote
Old 01-26-2002, 12:54 PM   #1689
Registered User
The XXX-S uses a variety of screws. 2-56, 4-40, and 5-40's. Most of the screws are, however, 4-40.
thatdog is offline   Reply With Quote
Old 01-26-2002, 11:41 PM   #1690
STLNLST's Avatar
Trader Rating: 19 (100%+)
The car felt pretty good today. I got to play with running the 41 tooth pulley in the front with the oneway today.....let me just say that it's way different from what I was use to. It did have it's bright moments as well as dark one's. I'm going to play with the set up somemore next week in hopes of working out a few bugs. (rear end was loose but controllable)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-26-2002, 11:51 PM   #1691
My xxx-s felt VERY good. Too bad I put a dog of a motor in for the main..........very EASY car to drive......very predictable.
acloco is offline   Reply With Quote
Old 01-26-2002, 11:54 PM   #1692
R/C Tech Founder
R/C Tech Charter Subscriber
All you XXX-S fans, check out the Events section of the site for pictures of Kinwald's XXX-S. His chassis milling job is, at the very least, worth checking out.
Losi has the TQ in pro-stock (Lemieux) but not in mod (Tosolini) at the Novak race. Who'd have thought?
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-27-2002, 01:17 AM   #1693
newracer's Avatar
so much for a sealed drive train!!
newracer is offline   Reply With Quote
Old 01-27-2002, 01:37 AM   #1694
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Default Sealed drive train
yea no doubt, wonder just how big a difference is that in oz.? I think Id rather have it sealed than deal with getting rocks stuck inbetween my pinion and spur
BHenderson is offline   Reply With Quote
Old 01-27-2002, 06:34 AM   #1695
Send a message via ICQ to Ragman
Silly thing is, he's had to put a load of lead on the car so it can't be a weight issue. What would he have gained by milling the chassis? More flex? Just put the original chassis on.
Very strange.
//Stu
Ragman is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
