Old 01-13-2002, 06:51 PM   #1606
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I would try a .062 sway bar. This might help. The 4degree carriers would help also.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 01-13-2002, 07:02 PM   #1607
Trader Rating: 49 (100%+)
Thanks for the feedback Mike.
I went to the 2degree casters to get a little better turn-in. I also want to try a sway but the hobby shop hasn't gotten them in yet.
BTW, the car is working very well (always top 2 or 3) just looking for that little extra.
Anything else to try? What about low roll center? I have the blocks, just haven't wanted to do the bumper modification yet.
rodneybarrett is offline   Reply With Quote
Old 01-13-2002, 07:51 PM   #1608
STLNLST's Avatar
Trader Rating: 17 (100%+)
Try coming out one hole on your front shocks. (maybe)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-13-2002, 08:06 PM   #1609
Kenneth Tan's Avatar
Just curious on what I observed yesterday. I tapped 4-40 holes on the suspension arms with a fingertap yesterday. Comparing with the holes that I tapped with the kit provided tapping screw, the one that was tapped with the finger tap was significantly looser when I screwed in a 4-40 screw. Is this normal? Will I strip the screw threads? I am asking this because this this is the first time that I tap plastic due to the hard losi plastics.
Kenneth Tan is offline   Reply With Quote
Old 01-13-2002, 11:25 PM   #1610
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
rodney, try going to the f-2 (2 deg of kick) and no caster.....that should eliminate your problem....also, put the low roll center blocks in....it helps....also, the weekend of the 26-27 th there is a big carpet race inn milw.....kinwald, hodge, and lemieux will be there..i will get the setup and post it.....
Matt M. is offline   Reply With Quote
Old 01-14-2002, 12:30 AM   #1611
Can anyone please post a template for the front bumper brace? I am trying to make one after a broken arm and not being able to buy it. Thanks a lot.
Old 01-14-2002, 08:35 AM   #1612
Hey Kenneth,
all you need is the bumper. Just place the bumper and trace the outline and the two holes that holds the body posts. Then from there outline the bumper brace and make sure you make allocations for the screws that is needed to mount the bumper brace to the front diff cover. That is it.
Cheers
viper1 is offline   Reply With Quote
Old 01-14-2002, 09:08 AM   #1613
mike_Webb's Avatar
For the bumper I have found that it is just eaiser to buy the Matt Francis Bumper Brace. I made one out of Fiberglass, Kydex and Lexan and all have failed. I bought the MF one and it has held up better then I had expected. Also I should mention that I am not hitting a lot of stuff now . Also a very good buy is the BRP front Bumper that goes on under the Los Bumper. It is a lot wider and protects the wheels better. Since going to that I have not broken any spindles or carriers.
Mike Webb
Old 01-14-2002, 09:21 AM   #1614
MIke
Just seen your reply re Bumpers/braces etc. I keep breaking spindle carriers and castor blocks and the BRP bumper sounds a good idea. Do you know if it is imported to the UK? Alternatively maybe you could give me details of US shops so I can try and track one down
chownr is offline   Reply With Quote
Old 01-14-2002, 09:55 AM   #1615
mike_Webb's Avatar
http://www.brpracing.com/brp_tc.html
part number 6226.
It is well worth the investment.
I am sure if you e-mail them they can help you out. I got mine at a place called The Track in Maryland, USA. Their website is http://www.rctrack.com. You could e-mail Mimi and ask her if she can send it to you also. Tell her that I sent you there and I thought that maybe she could do that. Other places to check out is Stormer Hobbies. http://www.stormerhobbies.com. They may be able to help you out.
Mike Webb
Old 01-14-2002, 01:18 PM   #1616
seamus0g's Avatar
Default Congo Spring Rates
XER987, here are the rates:
Yellow Congo 40 lbs
Purple Congo 35 lbs
Blue Congo 30 lbs
Black Losi 25 lbs
Purple Losi 20 lbs
Blue Losi 14.6 lbs
Silver Losi 12.6 lbs
Red Losi 11.6 lbs
Pink Losi 10.6 lbs
Yellow Losi 9.6 lbs
Orange Losi 8.6 lbs
White Losi 7.6 lbs
seamus0g is offline   Reply With Quote
Old 01-14-2002, 01:47 PM   #1617
Wazza22's Avatar
Trader Rating: 21 (100%+)
Cool
Hi
I have heard there is anew green losi spring for the sedan.
I have no idea of its rate though?
Wazza22 is offline   Reply With Quote
Old 01-14-2002, 01:58 PM   #1618
mike_Webb's Avatar
Green springs are going to be 17.6 lbs
Mike Webb
Old 01-14-2002, 02:36 PM   #1619
Wazza22's Avatar
Smile
Mike, Thanks
I will obtain a couple of pairs
Old 01-14-2002, 02:42 PM   #1620
mike_Webb's Avatar
Can I ask where you are going to retain them so that I can retain some also ?
Mike Webb
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
