Old 01-10-2002, 05:03 PM   #1591
mike_Webb's Avatar
Send a message via AIM to mike_Webb
KilRuf-
Craigs car had the Low Roll Center on it and he used the regular Diff's. Droop was probably 3 in front and 5 in rear. I think that is what I heard him say.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 01-10-2002, 05:10 PM   #1592
JimmyMac's Avatar
Thanks!
JimmyMac is offline   Reply With Quote
Old 01-11-2002, 08:20 AM   #1593
psycho's Avatar
Default Re: Trinity MF upper bumper brace
Originally posted by Rick Draper
Quick question when using the trinity mat francis upper bumper brace is it safe to use the red alloy screws trinity supplys with it as its quite a high load ares right so they might snap off if you have a hard impact? Thanks Rick
The MF bumper brace is a pos. I would buy a piece of kydex or cf and use your MF bumper brace as a template to make one that won't snap in half with your first mild impact. As the brace fits flush against the front bulkhead, I don't think you need to worry about sheering off the alum bolts, but I twisted the head off of one when backing it out. I replaced mine with Dubro steel bolts and a washer to spread the load around.
psycho is offline   Reply With Quote
Old 01-11-2002, 10:34 AM   #1594
Send a message via AIM to ZER01
Sway bar angles?
Mark D, do you know if sway bars are suppose to be level with the chassis or not? I just finished customizing some sway bars for the xxx-s but the front bar is a little nosed-down. If so, what effect will it have on the car? Thanx- Jesse
ZER01 is offline   Reply With Quote
Old 01-11-2002, 10:37 AM   #1595
mike_Webb's Avatar
psycho-
How did you snap the MF Bumper Brace? I have had multiple front end colissions and some were very hard but all is fine with my bumper.
Mike Webb
Old 01-11-2002, 10:49 AM   #1596
ottoman's Avatar
R/C Tech Charter Subscriber
I broke my aluminum screws on my MF brace after a hard hit. I suggest using steel screws. I just let mine float now and it seems to work fine that way.
ottoman is offline   Reply With Quote
Old 01-11-2002, 10:57 AM   #1597
psycho's Avatar
I don't remember exactly what happened, but the crash caused the brace to snap along the left edge of the milled out "M" up to the left screw hole. I've seen several other broken braces that looked just like mine. This is wheer there is the least amount of material, so it makes sense that the break would occur here. I am using the stock foam bumper, which isn't very sturdy, so maybe the impact flexed the foam bumper and contributed. I think the MF brace would be stronger if they didn't mill out the letters in the middle.
Old 01-11-2002, 11:16 AM   #1598
stefan's Avatar
Send a message via AIM to stefan
Default Bumper braces
A couple of posts back I warned everybody to use a solid bumper brace.
Ottoman, if you used steel screws your whole fron bulkhead cap would have been most likely ripped off, just like mine did.
Look at Spashett's car from Cleveland. Why do you think he used a flexible Lexan brace?
I made the holes, where my brace connects to the bulkhead big enough to insert rubber grommets (hardware store, cheap)
I use large washers on my screws and don't tighten them beyond snug.
Since then I haven't had any problems.
stefan is offline   Reply With Quote
Old 01-11-2002, 04:03 PM   #1599
Rog
Anyone have pics of the amount of material that needs to be shaved off to use the Integy (or MF) low-rollcenter blocks?
Rog is offline   Reply With Quote
Old 01-11-2002, 05:07 PM   #1600
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
What length droop screws should I purchase to use with the low roll center blocks? Thanks everyone.
Ty is offline   Reply With Quote
Old 01-11-2002, 05:45 PM   #1601
R/C Tech Founder
I don't remember offhand as far as lengths go, but for the droop screws you can get away with just cutting the kit ones in half -- that's what I did. I couldn't find any droop screws in the correct size/length at my LHS so I just busted out the Dremel (again).
As for how much to shave off the chassis to use the blocks, just do it bit-by-bit and test fit the parts each time. You want the low-roll blocks to sit perfectly flush (horizontal) with the chassis, otherwise you'll be throwing off the kick-up angle. You shouldn't have to shave off too much.
For the bump-stops on the front and rear bumpers, just use a cutting wheel on the Dremel and cut the stops off so that they are flush with the rest of the bumper's surface. You should be fine with that.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-12-2002, 06:39 AM   #1602
XER987's Avatar
WHAT ARE THE SPRING RATES FOR TRINITY'S CONGO SPRINGS? YELLOW, BLUE, AND PURPLE RIGHT?
XER987 is offline   Reply With Quote
Old 01-13-2002, 09:19 AM   #1603
psycho's Avatar
XER987
They don't rate them in pounds. Yellow they call .70, Purple .65 and Blue .60. I hope that helps. I've directly compared Losi purple and Trinty purple. The Trinity are slightly stiffer.
Old 01-13-2002, 09:46 AM   #1604
Ty
Ty's Avatar
Ask Larry D. on Trinity Tech Talk. He once gave the Congo spring ratings but I didn't write them down.
Old 01-13-2002, 05:48 PM   #1605
Trader Rating: 49 (100%+)
alright experts, gotta question for you.
Currently running Paul L's carpet setup for rubber tires with the exception of 2 degree casters (he ran 4) and green springs front/blue rear.
My question is this:
My turn-in is good but I am still having a probem with a little bit on power push on the tight turns. My current tire setup is Pit 24 (jb foams firm) up front and sorex 20 (yok 26mm firm) in rear.
Any ideas?
rodneybarrett is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
