Old 12-31-2001, 06:13 PM   #1546
has anyone experimented with different length bell crank links on the XXX-S. that way you could adjust the ackerman.
THE GOOCH is offline   Reply With Quote
Old 01-01-2002, 09:55 PM   #1547
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
The longer the link makes the car roll more which makes you gain traction, but it makes the car less stable. So the shorter the link less traction less roll and more stability.
KeNelson03 is offline   Reply With Quote
Old 01-02-2002, 10:08 AM   #1548
nitrorcfan: In the February 2002 edition of Hi-Torque's RC Car Magazine pg. 38, Matt Francis has an article concerning roll center and he addresses camber links. It is pretty easy to understand. You may wish to check that out. Happy Tuning.
623B is offline   Reply With Quote
Old 01-02-2002, 10:39 AM   #1549
Talking
Would it be possible to see if it is allowed to get this article here?! Again this is a Magazine not available to the poor Euro guys in The Netherlands.....
Arnoud is offline   Reply With Quote
Old 01-02-2002, 11:49 AM   #1550
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
stlnlst...trinity took care of the adaptor....but the fact is there is a lot of runout in the part.....for5 bucks you are nuts not to run losis gears.....
i tryed the black and purple, but i am back to blue silver, i think that i will try purple, blue at some point.....i worked with paul l and another guy, and we found a pretty good setup....i will post it if you guys like....
Matt M. is offline   Reply With Quote
Old 01-02-2002, 07:37 PM   #1551
Kenneth Tan's Avatar
Just installed the one-way. Anyone got the experience of having one of the one-way drive cups being too tight on the pins of the CVDs, whereby causing binding? There was no binding without installing the silver rings. If yes, what can be done to solve this?
Thanks.
Kenneth Tan is offline   Reply With Quote
Old 01-02-2002, 08:24 PM   #1552
STLNLST's Avatar
Trader Rating: 21 (100%+)
[QUOTE]Originally posted by mr. losi
[B]stlnlst...trinity took care of the adaptor....but the fact is there is a lot of runout in the part.....for5 bucks you are nuts not to run losis gears.....
I'm glad that they took care of you....as far as the Losi spurs, I do agree that $5 is a great deal but I sometimes like to play with my final drive ratio to get a little more from the motor or I might want to get a hair more punch but don't want to go too far below what I'm looking for so the only solution is to change the spur gear to get a better ratio. This really helps when running stock. The set up that you guys worked on, is it for rubber tire's or foam? If it's rubber please post it.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-03-2002, 12:11 AM   #1553
Hi Kenneth,
I have the same problem but they do not really pose a problem.If you took out the springs the outdrive will have the habit of popping out from the One Way.
By the way you will also have the same problem if you use the outdrive protectors from Trinity. You know the blue things......
Cheers
viper1 is offline   Reply With Quote
Old 01-03-2002, 12:24 AM   #1554
Trader Rating: 23 (100%+)
Thanks.
A light filing inside the splines with loosen up the fit. After a few runs the fit will fix itself.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-03-2002, 07:19 AM   #1555
Administrator
Matt M.'s Avatar
stlnlst...ok...i will copy it down and post it....i understand the adaptor deal....mine was so out of round though....it was just unusable...give me a day or so on the setup..
Old 01-03-2002, 01:36 PM   #1556
Hasnt been a need to.
But if you think you need it you can do the ackerman yourself by using ball-stud/ballcup with a short adjustable turnbuckle link.
TEAMORCA.SHOP
Old 01-03-2002, 10:47 PM   #1557
Send a message via ICQ to ALFRED
STLNLST - how many teeth are you running on a 64p for the xxx-s? we have a 100 x 50 feet track. i run a 22 pinion with a 90 spur. i just want to try out 64 pitch again. what would you recommend? emailing me would be great! thanks in advance!
ALFRED is offline   Reply With Quote
Old 01-04-2002, 04:45 AM   #1558
Hey guys........if any of you know somebody who might be looking for a XXX-S with most of the needed hop ups have them check out the RCTech for sale boards. I'm selling my car and am headed back to the TC3. Thanks!
Schuie Driver is offline   Reply With Quote
Old 01-04-2002, 04:59 AM   #1559
STLNLST's Avatar
Alfred- You got mail.
Old 01-04-2002, 07:01 PM   #1560
Registered User
KeNelson03's Avatar
Default Screws
It looks like ti-screws went out of buisness, any one know of aftermarket screws?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
