Old 05-17-2010, 04:18 AM   #1
Default Corally F1 (Older model, not NXG) Front foams?
Just accqired this chassis. It has silver stars foams all round. The rears are great, but the fronts don't bite going into the corners. I've adjusted camber and castor and applied additive, with no desirable effect. I run indoors on carpet. Could anyone suggest a foam tyre grade change or set up change.
squarewheels is offline   Reply With Quote
Old 05-18-2010, 07:34 PM   #2
stronzo's Avatar
Been a long time since I raced that car.
On carpet it was black and greys, black rears and grey fronts. Sometimes purple or black fronts. Depends on the track.
The silver stars are for asphalt (dusty)
For asphalt I would run green or pink rears and purple fronts
By additive do you refer to tire compound? I used TQ Orange and Paragon
also I only applied on the inner half of the front.
What is your castor and camber settings?
stronzo is offline   Reply With Quote
SEO by vBSEO 3.5.0
