Old 05-03-2004, 06:40 PM   #1
Registered User
ritchie's Avatar
Default internal ratio vs. spur gear size
ok someone help me out, is there a "perferred" spur gear size for different internal gear ratios? does it make a difference on shaft drive cars vs belt drive cars? stock motors vs. mods?
different brands of mods?
ritchie is offline   Reply With Quote
Old 05-04-2004, 02:03 AM   #2
Cole Trickle's Avatar
Not sure what you are asking about....
First: You need the proper gearing. There's no buttom line, it depends track layout, driving style and motor. The general rule of thumb, is that your car should reach top end speed, when it's 2/3-3/4 down of the longest straight. On tighter tracks, you might want one tooth less on the pinion. On more open tracks, one more tooth on the pinion.
Assuming you found the right ratio: Now you can use a larger pinion and a smaller spur and still have the same ratio. Which is best? Derpending on the car, the motor might sit lower with a larger spur. That will give you a lower center of gravity - which you'll like
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 05-04-2004, 06:51 AM   #3
also for the same ratio of pinion and spur..
the larger spur and smaller pinion will give more grunt and low end power, good for tight tracks
the smaller spur and larger pinion will suffer a little on the grunt but have a better handle on higher speeds... more for open tracks
the ratio is the same, but the power outputs of each scenerio can impact your car's speed.
correct me if i am wrong, this is how i always envisioned it.
MManson is offline   Reply With Quote
Old 05-04-2004, 03:50 PM   #4
Send a message via AIM to R/C Anonymous
run the biggest 64 pitch gear you can put on your car and go from there...with a larger spur theres a smaller "jump" of final drive ratios when you change pinions
Geoff C.
R/C Anonymous is offline   Reply With Quote
Transmission/Internal Gear ratio lesterrr Singapore R/C Racers 7 10-30-2007 06:51 AM
T2 Spur Gear Size butrflynlambie Electric On-Road 11 10-18-2006 04:25 AM
Internal Gear Ratio for a MF2 and a T4? BSchorr Electric Off-Road 7 03-03-2006 02:45 PM
Spur Gear Size Torqer Electric On-Road 10 08-11-2004 04:55 PM
Internal gear ratio difference advantage GTO2 Rookie Zone 1 05-25-2004 02:37 PM
SEO by vBSEO 3.5.0
