tamiya tt01d engines
ey what is the fastest engine that fits into the tt01d??
You might want to look in the onroad nitro forum.
fastest motor: how much $$$ have you got?
You will get into problems on the 1st corner
TT01d is NOT designed for high power motors.
Limited on pinions & spurs you can use because of the crazy motor mount: its designed for beginners. You may not be able to get the gearing you need to suit the motor.
Also, standard pinion is too soft. You will need a hardened pinion.
Ezrun 9T will fit easily. Quite fast in a 'normal' 1/10 car.
9T Ezrun is a good motor for drifting as well.
