Old 05-07-2010, 08:08 AM   #16
therizzle's Avatar
So, where should my droop screws be? they all seem to be in the same place, but could they be too low or high?
therizzle is offline   Reply With Quote
Old 05-07-2010, 10:24 AM   #17
Foxxrocket's Avatar
I like to go 4 all around.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 05-07-2010, 10:49 AM   #18
AM03GT's Avatar
Check Droop is a good idea... What you set it as will affect handling and weight transitioning but for straight line tracking it should not matter as long as it's even left to right.
Check shocks making sure damping is even left and right...
Check tweak since in most cases with a TC4 the battery side is always heavier and the weight is also more to the rear of the car. Balancing weights and proper tweak will fix this...
As was mentioned insane power will always make this characteristic show even in small amounts, with a computerized radio you can always set the expo on the throttle so it's softer on the low end...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 14930 10-18-2016 05:57 AM
Factory Team TC4 from RCX baih Electric On-Road 181 05-27-2005 09:33 AM
TC4 owners who had TC3 hogdaddy77 Electric On-Road 121 01-24-2005 01:52 PM
TC4 picture (+cliff lett) TryHard Electric On-Road 367 09-15-2004 10:39 AM
SEO by vBSEO 3.5.0
