Old 05-03-2010, 05:41 AM   #1
Default Tamiya BZ superstock motor gear ratio limits
G'day, will a Bz superstock motor work with a gearratio of 5.72 ? It states on the packaging that it will only work with gear ratios between 9.1 and 11.1. I can get a very good deal on a new one but there is no point in buying it if it wont work with my tt 01e with a gear ratio of 5.72.
I want to use it in Tamiya superstock races where only tamiya motors are allowed.
Any suggestions ? Thank you.
cpk1 is offline   Reply With Quote
Old 05-03-2010, 06:16 AM   #2
Skitee's Avatar
You can run that ratio with the BZ on a track with a long straight and not too technical infield, if it's shorter and more technical you want to gear between 6.75 and 6.00
Xray T4 2016 ~ ORCA Vrita VX3 ~ Speedzone 7.5
Xray T4 2016 ~ ORCA Vrita VX3 ~ Speedzone 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Speedzone 10.5
Skitee is offline   Reply With Quote
SEO by vBSEO 3.5.0
