Old 04-25-2010, 11:42 AM   #16
musti72's Avatar
You adjust the tightness of the geardiff with those different viscosity diff oils...
Mustafa Alp
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 04-25-2010, 06:10 PM   #17
KevinHawk's Avatar
Schumacher is by far the best diff grease. It is thick enough to run the diff loose and keeps everything good and smooth.
KevinHawk is offline   Reply With Quote
Old 04-28-2010, 04:43 PM   #18
Have you guys ever tried RCSpeedworks diff grease? Very very sticky and heat-resistant. I have been using this the last weeks now and it is far better than Schumacher grease. I've tried everything from Associated, Schumacher, Trinity, Serpent and so on, but the RCSpeedworks grease works the very best for modified (or anything else). No more slipping diffs for me and almost maintenance free racing.
Also tested and occasionally used by Jilles. You just need a small amount and you're ready to go.
Nothing else for me.
www.rcpit.nl , Yokomo dealer
Custom airbrush: https://www.facebook.com/ncbodypainter?fref=ts
Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Govert is offline   Reply With Quote
Old 04-28-2010, 10:26 PM   #19
Jochim_18's Avatar
Associated sucks they are too thin for MOD usually couple of heat race you feel the roughness on your diff.. Schumacher is pretty good the grease is nice and thick.
Originally Posted by sidecarphil1 View Post
i use the Assosiated ball diff grease
it is amazing stuff , the diff is really loose but doesnt slip
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Old 04-29-2010, 03:02 AM   #20
Associated make two diff greases (diff balls not thrust)... One has red writing on it and the other has black writing. The black writing version (I believe they call it stealth diff grease) is thicker and works better for modified. The other stuff will give a slightly better diff but won't stay in for long under mod loads. It is better for slower classes like 25.5-17.5.
As a point though for best performance in mod, frequent diff rebuilds are quite norm.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-29-2010, 03:25 AM   #21
LOSI123's Avatar
Trader Rating: 63 (100%+)
Tamiya Ball Diff grease is the best!!!!!!!!!!!!!!!!!
Team Durango - Speed Passion - Gens Ace
LOSI123 is offline   Reply With Quote
SEO by vBSEO 3.5.0
