View Poll Results: Who makes the best high end servos?
Futaba
24
20.17%
Multiplex/Profi
0
0%
KO
59
49.58%
Hi-tec
11
9.24%
JR
5
4.20%
Sanwa
8
6.72%
Airtonics
12
10.08%
Other
0
0%
Voters: 119. You may not vote on this poll
What is ultimate servo for speed, torque and durability!?
#31
Originally posted by dtm
2344 Hi Torque 0.13s
2343 Hi Speed 0.06s.............
2343 0.08s
#32
2343 is 0.08s @6V
#33
The speed of a Servo has to be but together with his torqe. The fast servo is ussless with not enough torqe.
Take the steering link of the Servo from your car, hold the link in your hand and try to steer the car while you are full accelerate. The rotate mass of the wheels is incredible.
The other thing to consider is the actual size and weight of a servo, it makes sence to have a small servo, because of todays chassis design. With a light servo you would have the change to balance the car better with additional weigth.
#34
HSR or High Speed Response is a function of the radio and reciever and not the servo. I know that KO Helios and the new Futaba 3PK have it but don't know about others. This is also the same as fast frame rate. The faster rate gives you faster servo response times and even faster than the listed numbers. It is kind of like a turbo for your servos. Beware though, as this only works with digital servos. If you try to use it with analog servos they will burn up and so will your receiver.
#35
Thanks for your advice, dude...
I was waiting for a response.
HSR seems to be the "polling rate" of the servo.
This is important for me because I am driving it
off my own CPU on a robot, and can fully take advantage
of an HSR-capable servo.
#36
Originally posted by TFR
Not as versatile? What do you mean?
#38
i really really like my 2123
#40
KO Propo 2143, 2144, 2343, 2344 servos are some of the best servos out.
The 2143 and 2343 are high speed.
The 2144 and 2344 are high torque.
The 2343 and 2344 are programable.
I know these servos are expensive, but well worth the cost.
#41
yeah but who ever it may be he tried to fail the task, but he succeeded the task.
so has he succeeded the task or failed to fail.
haha....its a bit dodgey aint it
#43
if it takes 1 day for 2 men to dig a hole....how long does it take 1 man to dig half a hole?
