Old 03-21-2002, 05:15 PM   #1
Post what would be a better tire for asphalt tracks?
what would be the best tire on asphalt tracks for a electric tc3 and why?
rctc3 is offline   Reply With Quote
Old 03-21-2002, 05:41 PM   #2
I guess it depends on the area and temperature. They are having success running Yokomo 138s for smooth sealed/clean asphalt.
HPI Xpatterns for dusty asphalt and seems to work better with our higher desert temps.
Sorex 36s are coming on strong. I'm new to Rubber tires/TC racing so can only report and buy what I see the guys using at the tracks.
The best bet is go to the track and see what the guys run and then ask them why.
MDM3 is offline   Reply With Quote
Old 03-21-2002, 05:47 PM   #3
i run in a parking lot, i live in mid fl so its kinda hot and most of the people there run nitro so? and all of them run rubber so would it help me if i ran foam instaed of rubber? im using pro-line v-rages now
Old 03-21-2002, 06:54 PM   #4
Send a message via AIM to Type S
take of cs 27's or sorex 36R or pits 35 or 26R
Type S is offline   Reply With Quote
Old 03-21-2002, 07:57 PM   #5
JohnA's Avatar
Foams only really work well on really smooth clean surfaces, If I were you I'd stick with rubber.
JohnA is offline   Reply With Quote
Old 03-24-2002, 02:02 PM   #6
Super Moderator
Grizzbob's Avatar
Well, a lot depends on temperature & your tastes, but I personally like to mix & match brands. I've been pretty happy with running Yokomo 137M's up front most of the time(they work well in all sorts of conditions, & won't give you too much steering), & any of a number of Sorex compound in the rear. If the temps are cool(like below 60 F) then I'd use something like a Sorex 20R or 24R, & as the temp comes up just go to a harder(numerically higher) compound. In 90 F heat I usually have either a 28R or 32R in rear. While you may be able to use a softer tire in high temps, they will wear out a LOT faster in heat they weren't designed to handle(& all of Sorex's tires are set up for a particular temp range, their website can give you more info on that)......
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
SEIDKRacing's Tracks (Carpet/Asphalt) dotjumper Kansas/Missouri Racing 167 04-29-2011 07:40 PM
Asphalt tracks Tral Electric On-Road 5 03-21-2007 12:51 PM
Looking for some outdoor asphalt tracks in the Harrisburg/Halifax Pa kgonder1969 Racing Forum 5 03-01-2007 06:53 PM
asphalt tracks in malaysia? eTiMaGo Malaysian R/C Racers 19 07-11-2003 07:53 AM
Pictures/Info on Permanent Asphalt Tracks TheBarber Electric On-Road 7 04-10-2003 07:55 PM
SEO by vBSEO 3.5.0
