What's the deal with EVEN turn/wind Brushless motors? >
Old 04-12-2010, 01:50 PM
R/C Tech Elite Member
JayL's Avatar
Default What's the deal with EVEN turn/wind Brushless motors?
Why are they more uncommon, some companies don't even make them.
Are they harder to make correctly or more expensive to make?
Is there some reason why it is better to run a .5t? for example a 4.5t instead of a 5.0t
JayL is offline
Old 04-12-2010, 02:20 PM
HarryLeach's Avatar
It's the way the stators are wound.
http://www.mmsonline.com/articles/wy...in-perspective
http://www.roarracing.com/downloads/..._Rule_Book.pdf [pg 49]
Roar Approved "spec" motors are Wye wound, which means the windings are inter connected to a common point, which is usually on the pinion side of the stator. Since the connection to the speed control is at the other end, you end up with an extra 0.5T building the motor.
The "even" turn motors you asked about are Delta configuration windings, but would only be legal in mod.
Since a Wye motor can run just fine sensorless as well, there's not a whole lot of incentive for manufacturers to make both winding configurations.
HarryLeach is offline
Team EAM
Trader Rating: 79 (100%+)
Yea Jay from what I understand they are harder to make and I think the final assembly has to be all done by hand and soldered by hand (Not sure if they normally are or not). Its not that they are any better....just right in between turns and another option.
EA
EAMotorsports is offline
Old 04-13-2010, 11:24 AM
EddieO's Avatar
Wye is a bit different than you think.....
Brushed motors are wound delta. Delta is basically one big piece of wire from segment to segment that terminates at the common point at the end.
Wye motors are basically wound one segment at a time, so there is essentially 3 seperate pieces of wire (yes I am aware each segment can have multiple strands of wire)....with one termination at the top and one at the bottom. Was never used on brush motors, though big jim did make one for giggles....it was terrible.
Bob Novak flat out told me they wound their stuff Wye, because at the time it made the power in their mind more comparable to brushed......he said delta was much more powerful.
So, the reason you have a odd number like 3.5, 10.5 etc is cause the wire starts at the top, but never returns.....so the last wind is only half.
Later EddieO
EddieO is offline
Old 04-13-2010, 12:15 PM
Eddie doing research on brushless motors?
Kinda makes you go hmmmmm........
jiml is offline
Old 04-16-2010, 10:49 PM
EddieO's Avatar
brood brushless some day......working on it. Had plenty of time to think about it!
Later EddieO
EddieO is offline
Old 04-17-2010, 08:07 PM
nashrcracer's Avatar
glad to see you back online eddie..
nashrcracer is offline
