Like Tree23Likes
Old 11-14-2010, 09:43 AM   #1471
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Granpa View Post
Craig, are you still running the dog bones?? If you are, I'll save them for ya
Thanks Granpa! You know I have a thing for running dogbones!
Originally Posted by OVA View Post
Who carry large inventory of Tamiya part in usa beside Speedtech?
I need spare or hop up for FF03..please PM back..Thanks
Check with Jimmy, he's got the connex for the Tamiya stuff too.
www.trackstarrc.com
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-14-2010, 01:59 PM   #1472
Racecrafter's Avatar
Trader Rating: 25 (96%+)
www.trackstarrc.com
Thanks Craig!
The web site doesn't show much. But we have quite a few things in stock.
LMK what you might need.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-14-2010, 08:03 PM   #1473
jasons36's Avatar
Trader Rating: 36 (100%+)
Default 48p or 64p
So i just bought a used ff03 off another rctech member and its my first time running on road. all ive ever needed to use in off road is 48 pitch gears. what are the positives and negatives to using either 48p or 64p gears in this car. If it helps ill be running 21.5 brushless and an fdr was recommended by cuda in the 3.5 range. i was able to find a 70t spur and pinions in the 40s that are 48p but im not sure if they are too large to fit under the gear cover or even able to mesh. my only concern about the 64p gears is that maybe theyre not durable enough, im not sure since ive never ran them before. any advice would be greatly appreciated. im hoping to have the car this week and would love to have a spur/pinion ready to go for it. thanks again.
FT SC10 - Tekin RS- Redline 17.5
Kyosho DB/SC-R (for sale)
Spektrum DX3R Pro
jasons36 is offline   Reply With Quote
Old 11-14-2010, 08:26 PM   #1474
It's a personal preference as much as it is a strength option.
The correct gearing for 21.5 on most tracks requires the gear cover to be left off. With saying that you need to ask yourself "Do the tracks I run at have a clean enough surface to run 64 pitch?"
Jimmy Wright
Old 11-14-2010, 08:37 PM   #1475
jasons36's Avatar
I would imagine that the overall diameter of the spur and pinion on whatever 48p gears I use to reach my desired fdr would be much greater than whatever 64p gears i use to achieve the same fdr. That leaves me wondering if I would even be able to achieve a proper gear mesh using the 48p gears. What do u think?
Spektrum DX3R Pro
Old 11-15-2010, 06:30 AM   #1476
NiMo's Avatar
You can get 48dp pinions up to 54t, and spur gears in to the 60's, so can't see gearing being an issue, especially if you are using a timing ESC.
NiMo is offline   Reply With Quote
Old 11-15-2010, 09:16 AM   #1477
F N CUDA's Avatar
The diameters will be the same, no?
Just gonna have more teeth covering that diameter when you go to 64 pitch.
Kinda like fine thread and coarse thread on screws.
Right?
Craig Hammon
Old 11-15-2010, 10:39 AM   #1478
Right?
+1
Jimmy Wright
Old 11-15-2010, 12:33 PM   #1479
OI82lose's Avatar
FF 03 motor esc combo's
I am trying to figure out which Esc / motor combo to use in the FF03
I first had the Speed passion Cirtix system, then everyone went to
silver can brushed. I now run this combo.
Many others are running 21.5 brushless/ Tekin rs combo (non-boosted).
MY LHS says Tamiya is testing a 18 motor/esc combo for the TCS races.
I really would like to get this car setup for racing with a legal motor/esc combo so I don't have to keep buy new equipment.
I race in So Cal.
OI82lose is offline   Reply With Quote
Old 11-15-2010, 12:59 PM   #1480
I am using a Traxxas Stinger brushed motor in mine till the Tamiya system is available. Geared around 4.4 it seems to be able to keep up on straightaway speed. For less than $20, this seemed a more viable option than buying a brushless system, then replacing it with the Tamiya System especially for those who were using a Silvercan.
Granpa is offline   Reply With Quote
Old 11-15-2010, 06:04 PM   #1481
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
Where are you gonna be running the FF03, Franko?
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 11-15-2010, 08:42 PM   #1482
maxepower's Avatar
Default Stinger motor in FF03
Grandpa,
That car was a missle with that motor, I think it was faster than most of the 17.5 motors with no timing. Good gage to set up for brushless once you switch over!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EXO-6,TA-07,TRF419,EVO-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 11-15-2010, 09:25 PM   #1483
reenmachine's Avatar
So what's the current medium-term FF03 drivetrain spec thinking for non-TCS races? Right when it looked like 21.5/zero was the ticket and many of us started running it 2011 TCS rules came out with the Tamiya 18T combo listed, which is probably closer to 17.5/zero.
So, will you just run whatever until the 18T combos are around and then run those, TCS or otherwise? Run 17.5/zero or 21.5/zero outside of TCS and swap in the 18T just for TCS races?
FF03s have been going great in Camarillo with 21.5/zero. Racing speeds are fun, reliability is high, and tire wear is good.
Hopefully we can settle on something and promote consistency throughout the region to grow the class.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-16-2010, 07:31 AM   #1484
Exactly what our conversation was about
I applaud you Pete and the RoadRunners for stepping up to start the ball rolling!
Others should follow (and be contacted) I know Charlie and his group would be more than happy with the 17.5's as 17.5 around the country has been the "stock" motor class for years.
Jimmy Wright
Old 11-16-2010, 08:45 AM   #1485
F N CUDA's Avatar
I'm gonna agree with you guys.
Athough the 21.5 is in lots of these cars right now it seems as though that motor choice came about as an equal to the Silver cans, sort of.
Ever since learning that we can gear the snot out of brushless motors and get away with it, the 17.5 has been the stock motor to equal the old stock motors that were brushed 27 turn.
If Tamiya's choice for this car is gonna be their 18 turn, and the 17.5 is gonna be the closest thing to that (supposed to be less KV), then it makes sense to get these things set up to run those 2 motors together/against each other.
Great, another 17.5 class to add to the decision of which one to run.
Craig Hammon
Tamiya Championship Series Neil Rabara Racing Forum 21026 05-25-2017 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
