Like Tree21Likes
Old 11-08-2010, 12:08 PM   #1441
Originally Posted by eevul View Post
Does anyone know what tires they are using for the FF03? We are running indoor carpet with medium to high traction. I am looking for TCS approved tires and rims. Part numbers will be a great help. I found the Tamiya #51023 but I'm not sure if these are the right ones or if there are other tires out there.
Thanks in advance.
If you're running Canadian TCS, as of right now you can use any Tamiya tire, so Type A for carpet/cold surface and Type B for outdoor/hot surface. If you can get the new type C carpet tires, they will likely be the way to go, though they haven't been released yet.
Good luck, and enjoy. We had the first Candian TCS race with the FF-03 class this past weekend. It was great fun, and the cars all ran fast and were fun to drive. Nice to see a variety of bodies running around too.
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 11-08-2010, 02:48 PM   #1442
eevul's Avatar
Yes, sorry, I forgot to mention that this will be for the Canadian TCS here in BC, Canada. Do you happen to have any part numbers for the type A tires? I just bought my FF03 Pro so I don't have tires as of yet.
Thanks!
eevul is offline   Reply With Quote
Old 11-08-2010, 04:16 PM   #1443
Thanks!
Clicky
Old 11-09-2010, 01:55 AM   #1444
Default Weight
I was looking at the 2011 rules for TCS, and although they dont apply to me in any way, shape or form, I found some points interesting...
1) Pre-mounted tires only - Is this a good thing or bad thing? If the price is right....good thing!
2) No weight has been specified for the class.....and f I go back and check the current rules, it seems there was no weight limit either...(unless I am blind) I found an unofficial rule that says the weight needs to be no less than 1400g.
Does anyone add weight to this car when running Lipo? I found with a Turnigy 4000mah lipo, I have to add about 60g to get it up to that weight (1400g)..and mine is the std FF03 with Civic body set....
sirandy is offline   Reply With Quote
Old 11-09-2010, 02:47 AM   #1445
Originally Posted by charl mac View Post
Need some help guys, I had 2 ff03 diffs come loose this weekend and one of them snaped the bolt after coming loose 5 times. I have gone back 10 pages but no info has others had this problem, also see some are using 416 bolt and nut with alu outdrives, does anyone have the part no and why are you using this.
Thanks.
Thanks for the rely NiMo
Does anyone know if the tao5 or mo5 alu outdrives will work in the ff03, our local supplier is out of stock till end of Jan.
Info from another guy saying I should turn the diff the wrong way round this will also help the diff coming loose, the manual is the wrong way round......any thoughts.
Why are some using the 416 bolt and nut.
charl mac is offline   Reply With Quote
Old 11-09-2010, 07:53 AM   #1446
eevul's Avatar
Thanks ErikO!
Old 11-09-2010, 08:25 AM   #1447
kentech's Avatar
Carson Scirocco with Tech racing rear wing and painted everything except lights. It's a bit wide for the FF but impressed with the details. Seems to be PET rather than Lexan though.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-09-2010, 08:31 AM   #1448
OSherman's Avatar
Thumbs up
nice lookin ride
OSherman is offline   Reply With Quote
Old 11-09-2010, 06:35 PM   #1449
RossoTorro's Avatar
Looks good, but they are very fragile. Never thought of them as PET but that might explain things. Ordered one finished painted for my M05 and it lasted only one raceday. Shame as it drove well and looked good also.
I will avoid them in the future.
Partnumber for the wing or where i can get it, please?
RossoTorro is offline   Reply With Quote
Old 11-09-2010, 06:36 PM   #1450
RossoTorro's Avatar
Double post, sorry...
Old 11-09-2010, 07:34 PM   #1451
link for tech racing rear wing?
tpsolid is offline   Reply With Quote
Old 11-09-2010, 08:34 PM   #1452
oldnwise's Avatar
The plastic retainer (part 1 on K tree) is fragile and if the diff is too tight it will crack. The 2mm diff nut also has a habit of stripping in a tight diff.
The 416 lock nut is much more reliable.
oldnwise is offline   Reply With Quote
Old 11-10-2010, 03:51 AM   #1453
Barry White's Avatar
Wing link?
Barry White is offline   Reply With Quote
Old 11-10-2010, 05:28 AM   #1454
kentech's Avatar
Originally Posted by Barry White View Post
Wing link?
http://www.tech-racing.co.jp/sin-2010-7flame.html
There are 2 types:
TE0036
TE0037
Package includes 1 wide and 1 narrow wing. Used the narrow one and cut it down to look like a Super 2000 wing.
Old 11-10-2010, 10:04 AM   #1455
RossoTorro's Avatar
Where did you order it?
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 Today 03:14 AM
Tamiya Championship Series Neil Rabara Racing Forum 20952 Yesterday 10:43 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
