Like Tree22Likes
Old 10-01-2010, 08:53 AM   #1186
OSherman's Avatar
Originally Posted by andrew-01 View Post
Hey guys, just had a quick question.
According to Tamiya USA, "All bodies must use the wings that are supplied in the kit. Mixing and matching ABS plastic wings between different bodies is not allowed. Part number 53470 (Lightweight Wing) and 53604 (Racing Wing Set) or any future optional wing set is allowed to be used for any sedan or sports car body in certain classes".
So essentially any 'legal' body for an FF03 is allowed to use these optional wings correct? Is this what most are doing? I have seen some kit ABS wings that are awfully small and would like to run a different wing for some more rear down force.
This is legal practice.. TAMIYA Option wing set is 'legal'
OSherman is offline   Reply With Quote
Old 10-01-2010, 09:44 AM   #1187
Originally Posted by cannon View Post
I just received a shipment of Yeah Racing gears for the FF03 and TRF201.
All Delrin. Will be interesting to see how they perform
does the yeah diff take 3mm balls or same size as the original?
one-nil is offline   Reply With Quote
Old 10-01-2010, 09:57 AM   #1188
andrew-01's Avatar
Trader Rating: 22 (100%+)
Thanks Sherman! I'll head over to Speedtech to grab the wings once I get out of class.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 10-01-2010, 10:26 AM   #1189
fordmike65's Avatar
Trader Rating: 28 (97%+)
I'd like to see the quality,fit & finish of these. I've been thinking of ordering a set,but a bit leary being Yeah Racing. Please post your findings
fordmike65 is offline   Reply With Quote
Old 10-01-2010, 11:13 AM   #1190
stitchy's Avatar
Got some stuff back in stock, especially ALUMINUM ROCKER ARMS and CVD parts in...
Cuda, still looking for TRF shocks?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 10-01-2010, 11:20 AM   #1191
p-Lo's Avatar
Hey Albert, Dont let mike get my mini parts tree. He's threatening to go at lunch. I'll be down there a little later to pick it up. Thanks!
p-Lo is offline   Reply With Quote
Old 10-01-2010, 11:32 AM   #1192
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Got shocks Stitchdude, thanks.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 10-01-2010, 11:43 AM   #1193
stitchy's Avatar
Ha, you could always order on our site and select "will call" to take it out of our inventory and into the special P-lo bag.
Old 10-01-2010, 12:35 PM   #1194
F N CUDA's Avatar
Hey guys,
Charlie is cool enough to let me open the Cal Raceway track today!
I should be there around 2 pm to get things goin.
SUPPORT YOUR LOCAL RACE TRACK!
SEE YOU THERE.
'cuda
Craig Hammon
Old 10-01-2010, 12:38 PM   #1195
fordmike65's Avatar
Just picked it up. You snooze,you loose. Thanks Albert. I really needed the new body mounts.
Old 10-01-2010, 12:51 PM   #1196
fordmike65's Avatar
Originally Posted by stitchy View Post
and CVD parts in...
Thanks Albert. Got'em
Old 10-01-2010, 12:56 PM   #1197
Just found this body in my local hobby shop , NEW IN BOX
Now all i need is n FF03pro
sidecarphil1 is offline   Reply With Quote
Old 10-01-2010, 06:34 PM   #1198
cannon's Avatar
Trader Rating: 35 (100%+)
Just building a second FF03 and here is some interesting information for the techno geeks out there.
I have just started building the gearbox and have gone with aftermarket parts from 3 Racing and Yeah Racing. By adding the following items:
3 racing Top shaft and centre shaft
Yeah racing plastic gears (all 3)
3 Racing alloy outdrives (actually added 3.2g
A weight saving of 5.5g in rotational mass in the gearbox was achieved. Yes it doesbn't sound much but it is rotating mass. Obviously you could save more by staying with the plastic outdrives.
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 10-01-2010, 07:29 PM   #1199
stitchy's Avatar
Nice! Here's one more if you need a spare
Weren't you looking for one of these, P-lo?
Old 10-01-2010, 07:41 PM   #1200
cannon's Avatar
Same as the original ... Larger balls would most likely have a problem in such a small diff gear.. Hard to fit the 12 balls in with enough plastic between the balls
Tamiya Championship Series Neil Rabara Racing Forum 20961 Yesterday 11:31 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 03-26-2017 03:14 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
