Like Tree220Likes
Tamiya FF03
Old 08-24-2010, 01:03 PM
  #931
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by OSherman
almost.. leaving office in a bit
we should bring it the track and watch how Fred plays.
Hebiki is offline
Old 08-24-2010, 01:10 PM
  #932
razzor's Avatar
Is it time to play yet?
FWD Porsche is just not right !!!!
razzor is offline
Old 08-24-2010, 02:11 PM
  #933
OSherman's Avatar
i dont make the rules... i just follow them..
OSherman is offline
Old 08-25-2010, 10:54 AM
  #934
Got some Civic bodies in...
Just a small first shipment, more to come later!
DAG I know you're out there...
stitchy is offline
Old 08-25-2010, 12:03 PM
  #935
OI82lose's Avatar
Are they 190 mm?
OI82lose is offline
Old 08-25-2010, 12:15 PM
  #936
yep!
stitchy is offline
Old 08-26-2010, 08:53 AM
  #937
Hi,
Was just wondering... the shaft that holds the spur gear... how much freeplay (if any) should there be?
mine seems to have quite a bit of free play... in and out of the diff case, as well as along the x and y axis (hope u guys understand what i'm trying to describe).
any feedback welcome.
sammies is offline
Old 08-26-2010, 09:12 AM
  #938
dag32's Avatar
Trader Rating: 112 (100%+)
dag32 is offline
Old 08-26-2010, 10:17 AM
  #939
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by sammies
Hi,
Check out your assembly of your gear box, the shaft itself has several bearings in a couple of sizes that you might have missed (i did), the shaft itself will come in and out a bit but should not wiggle. other than that the plastic holder itself is not true, you'll need to get the infamous aluminum spur gear holder!
izzyracer is offline
Old 08-26-2010, 11:54 AM
  #940
superspeed's Avatar
Nice, too bad my order is still on back order with tamiyadirect / alisohobby
It's a body that lots of people have been requesting for.
superspeed is offline
Old 08-26-2010, 11:59 AM
  #941
superspeed's Avatar
FF03 is getting more body styles, see the search result on tamiyausa site.
http://www.tamiyausa.com/search.php?....x=0&image.y=0
I used to race FF01 and TA02 on the parking lot during mid 90's, it was on-pace with 4wd cars. At the time, my competition was hpi RS4 pro, kyosho ep spider, and not sure if you guys still remember the dual sport from team associated.
I think I'm going to back order all the new bodies on my next Tamiya order
more at:
http://www.tamiyausa.com/search.php?q=ff-03&x=0&y=0
Last edited by superspeed; 08-26-2010 at 12:03 PM. Reason: ff-03 search and ff03 search
Old 08-26-2010, 02:59 PM
  #942
RossoTorro's Avatar
more at:
Why can't they get the Ford Mondeo back?
I want some of those badly....
RossoTorro is offline
Old 08-28-2010, 09:33 PM
  #943
rtypec's Avatar
Default Tamiya Nationals Setup
For those who are attending the TCS nationals, here's the setup sheet from today's qualifiers. It's a bit of a departure from the stock setup and will require arm flipping and some work to change to it. Also, longer camber and steering link turn buckles would be recommended.
Thanks to kentech and petitrc for the setup sheet as an editable pdf file.
*edit* I found a mistake on the shock mount position on the rear arms. The attached image should reflect this correction.
rtypec is offline
Old 08-29-2010, 12:26 AM
  #944
dag32's Avatar
What do you mean by "will require arm flipping"
dag32 is offline
Old 08-29-2010, 06:25 AM
  #945
TPhalen's Avatar
You need to remove the rear arms and replace them in the 'flipped' position. There are 4 holes in the arms...2 on each side that are offset from each other. His setup required one that is opposite of the side the kit tells you to build it with.
BTW, try this setup. His car is beyond uber-dialed. Got a chance to drive it. I think he's cheating but I can't prove it.
TPhalen is offline
