Like Tree34Likes
Old 07-30-2010, 04:02 PM   #811
cannon's Avatar
Trader Rating: 35 (100%+)
I should have also said that I am using the aluminium diff halves with blades and the 44mm shafts
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-30-2010, 04:50 PM   #812
izzyracer's Avatar
Trader Rating: 27 (100%+)
I'm using 42mm Aluminum Outdrives, what's yours?
izzyracer is offline   Reply With Quote
Old 07-30-2010, 04:56 PM   #813
Originally Posted by OSherman View Post
you need 416 stub axles... the pins offset is different
thank you sir. I will order them.
tpsolid is offline   Reply With Quote
Old 07-30-2010, 06:02 PM   #814
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
I think they are acutally considered TB03 wheel axles
tamiyarcracer is offline   Reply With Quote
Old 07-30-2010, 06:30 PM   #815
foampervert's Avatar
Send a message via MSN to foampervert
Default Diff build
Originally Posted by minimadman2003 View Post
Ok,
This is an old topic and I've read all about how you have to flip the diff and make sure the diff adjustment is on the correct side. I've done all that but I have a fit issue with the 46mm universals. I'm running the aluminum diff halves and the plastic ears for the dogbones, with TB03 axle shafts. The left side (where the adjustment screw access is) is fine and has several mm of movement in/out. The right side, however, is hitting the end of the diff screw and binding the suspension. There's ZERO movement on that side. The diff screw just seems to be way too long!
Anyone ever figure out the magic for getting the aluminum diff halves, plastic dogbone protectors, and 46mm universals to fit? Do I need to cut the diff screw down, or did I somehow manage to screw something up?
Hiya!
First off, you need to build the diff correctly. If the 46mm shafts do not fit, you need to look at the diff halves very carefully.
One side has a bit of shaft(we'll call it side A), the other side has a dimple where a bearing fits(side B)...
The spring and nut holder goes into side A(if it went into side B, the diff will exhibit the issues you faced), and the thrust bearing and diff screw goes into side B. Also make sure the diff plates sit proper as you assemble it, they slide out easily and will also cause mis-build.
I'm using 46mm shafts with absolutely no issues. No binding at all.
Good luck!
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is online now   Reply With Quote
Old 07-30-2010, 06:36 PM   #816
Originally Posted by foampervert View Post
Hiya!
Good luck!
-Alexander
+1
Old 07-30-2010, 07:14 PM   #817
Trader Rating: 44 (100%+)
Hiya!
Good luck!
-Alexander
Built it per the instructions the first time, then rebuilt it the way everyone else did (not seeing the little flipper-do sign). No difference. Tried putting the diff in both ways. No difference.
I meant to add that I am running stock blocks per the instructions, and that seems to make a difference in the width of the car. I think you can get away with 46mm shafts if you play with the optional blocks, but I'm not going there yet.
I rebuilt my diff per the instructions (again), but this time before I built it I cut about 2-3mm off the end of the diff screw. Now it fits flush with the plastic diff nut, and I have enough room to run 46mm shafts. But for safety sake, I've ordered some 44mm shafts.
Maybe my diff screw was slightly different out of the kit. My kit was one of the second batches to come out, but I don't know if that has anything to do with it. My screw also had a slight bend to it near the end, which is probably going to screw me up in the long run. But for now it is tight, smooth, and ready for the rest of the build.
Thanks for all the tips.
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 07-31-2010, 04:22 AM   #818
I am using 46mm and aluminium outdrives without any problems.
Fabiz
Fabiz is offline   Reply With Quote
Old 07-31-2010, 04:55 AM   #819
NiMo's Avatar
I'm still on Dogs and Plasdiff
NiMo is offline   Reply With Quote
Old 07-31-2010, 09:14 AM   #820
reenmachine's Avatar
Trader Rating: 26 (100%+)
Stock outdrives, stock blocks, and 46mm steel universals here. Works perfectly.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-31-2010, 11:38 AM   #821
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Outside of the Alfa Romeo 155VTI, the BTCC Alfa Romeo 156 was my next favorite... I'm glad it's available again
akura2 is offline   Reply With Quote
Old 07-31-2010, 07:01 PM   #822
akura2's Avatar
I love my FF01... but I can't wait to get an FF03
My FF01
Old 07-31-2010, 11:00 PM   #823
My FF01
Beautiful car, Mine is still in the box, wrapped in plastic, sitting on my shelf
Old 08-01-2010, 12:00 AM   #824
Default What motor?
What motor and esc setup are you using? I believe the stock diff halves, suspension blocks and stuff are perfectly fine for use with lightly tuned motors, silver cans or high turn brushless setups(17.5, 18 or 21.5)
Do you glue the diff rings to the diff halves and with what type of glue?
Likewise, for the suspension blocks, at lower speeds and handling forces do not affect the durability and handling of the plastic blocks as much.
Old 08-01-2010, 03:30 AM   #825
Do you have the aluminum outdrives and dogbone protectors? I'd like to see a pic of the side with the diff nut if you can get one.
I have the alu diff installed and i also use the swing shaft protectors.
I don't have any pics of it as i don't have a camera yet. Sorry
addicted2blue is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21196 Yesterday 11:56 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 732 10-12-2017 02:34 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
