Like Tree24Likes
Old 07-29-2010, 12:35 PM   #796
M03Racer's Avatar
Trader Rating: 33 (100%+)
Originally Posted by NiMo View Post
I had to do some hunting myself as I too thought they was old parts.
Anyway the details are on Tamiya America here:
http://www.tamiyausa.com/product/cat...p?sub-id=71100
Thanks that makes sense.
M03Racer is offline   Reply With Quote
Old 07-29-2010, 06:46 PM   #797
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
The other key to the original post is in the Part numbers. Old body sets would be a 50... part number, and a very new body set is a 51... part number. But these new body sets are a 84... part numbers which is the limited release set of part numbers, and is a newer part number string.
tamiyarcracer is offline   Reply With Quote
Old 07-29-2010, 07:23 PM   #798
Trader Rating: 44 (100%+)
Default swingshaft binding!
Ok,
This is an old topic and I've read all about how you have to flip the diff and make sure the diff adjustment is on the correct side. I've done all that but I have a fit issue with the 46mm universals. I'm running the aluminum diff halves and the plastic ears for the dogbones, with TB03 axle shafts. The left side (where the adjustment screw access is) is fine and has several mm of movement in/out. The right side, however, is hitting the end of the diff screw and binding the suspension. There's ZERO movement on that side. The diff screw just seems to be way too long!
Anyone ever figure out the magic for getting the aluminum diff halves, plastic dogbone protectors, and 46mm universals to fit? Do I need to cut the diff screw down, or did I somehow manage to screw something up?
M03R, M04L, TT-01R Type E, Midnight Pumpkin,
Lunch Box, CC-01 Wrangler, SC10.2FT,
SC10B, Traxxas Slash
minimadman2003 is offline   Reply With Quote
Old 07-29-2010, 07:55 PM   #799
Originally Posted by minimadman2003 View Post
Ok,
Just swap sides on the diff. Put the diff nut on the side were the diff screw goes and the diff screw on the side that the nut goes and it will work.
mrod is offline   Reply With Quote
Old 07-29-2010, 08:21 PM   #800
I tried both flipping the diff around and actually rebuilding it with the diff nut on the other outdrive and the problem always follows the diff nut side. It looks like I need 44mm dogbones or there will be a bind. How close are your outdrive protectors from the diff screw end?
Old 07-29-2010, 11:12 PM   #801
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Yo, Tamiyarcracer...how's it goes....?? good to see the FFs is coming back. Mine will be here soon...hee.hee.
CHRIS LIM
OVERGEARED RACING B.O.D
ORCA//AWESOMATIX USA//HEBIKI DESIGN WORKS//OPTION R/C//GRIPWORKS RC
chrisman is offline   Reply With Quote
Old 07-29-2010, 11:17 PM   #802
Hey Chris,
When is the next races up there?
Old 07-30-2010, 12:20 AM   #803
Hebiki's Avatar
Trader Rating: 26 (100%+)
my evil twin!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-30-2010, 05:12 AM   #804
cannon's Avatar
Trader Rating: 35 (100%+)
You are supposed to use 44mm shafts
When you look at the parts listing on companies like RCMART, they list the 44mm shafts as usable with the FF03. I have installed the 44mm shafts in my FF03 ... haven't run it yet but no binding issues
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-30-2010, 06:41 AM   #805
NiMo's Avatar
I thought it said 46mm if using XA blocks ?
Kit comes with XD blocks
NiMo is offline   Reply With Quote
Old 07-30-2010, 09:11 AM   #806
I used the TA05 universals. no problem
xcept the hole for the hex pin is too far out. like 1mm further out.
tpsolid is offline   Reply With Quote
Old 07-30-2010, 09:36 AM   #807
SilverShelby's Avatar
Minimadmann, runn 44mm axels thats what i have
and no probs
and YES Its a can motor!!!!!
M03,M05L,M06M,FF03PRO,CC01 Jeep,M03L-Yello Mini
ABC Hobby Goose,Genetic
2011 Memphis winner Mini,FWD
2013 e mergent winner Mini
SilverShelby is offline   Reply With Quote
Old 07-30-2010, 09:45 AM   #808
OSherman's Avatar
you need 416 stub axles... the pins offset is different
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-30-2010, 03:00 PM   #809
I'm using the standard suspension mounts XD and my swing shafts are 46mm and i don't have any problems at all.
addicted2blue is offline   Reply With Quote
Old 07-30-2010, 03:53 PM   #810
Do you have the aluminum outdrives and dogbone protectors? I'd like to see a pic of the side with the diff nut if you can get one.
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5806 09-22-2017 03:06 PM
Tamiya Championship Series Neil Rabara Racing Forum 21185 09-05-2017 07:20 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 730 08-15-2017 08:06 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
