Like Tree23Likes
Old 07-22-2010, 07:38 PM   #736
Originally Posted by cannon View Post
I have found some servos to have slightly different case shape which can cause problems
Originally Posted by Besercoe View Post
The idea is for the rings to slip on the outdrives, rather than slipping on the balls, generating a flat spot, making the diff crunchy sooner.
If you want notched rings, get the 3Racing diff rings for the 416, they have the D ring.
Cannon is correct, in the past Tammy rings barely needed sanding, nowadays they are like rusted old plates of pitted steel.
If the idea is for the rings to slip, why does the instruction have you use contact cement?
Budster is offline   Reply With Quote
Old 07-22-2010, 07:53 PM   #737
dodo's Avatar
Send a message via Yahoo to dodo
if i remember correctly, these are not direct fit to 416 outdrives, useable but too much tolerance, it will still slip against the outdrives. not sure how they go against FF03 outdrives
dodo is offline   Reply With Quote
Old 07-22-2010, 07:59 PM   #738
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by RossoTorro View Post
What part was that? I got the same problem with mine...
The L shaped Bell crank
K6 in Step 7 it says "note direction"
tamiyarcracer is offline   Reply With Quote
Old 07-23-2010, 02:43 AM   #739
foampervert's Avatar
Send a message via MSN to foampervert
Default darn these japanese manual writers!
WHAT? we actually have to READ our manuals? preposterous!
teehee... first Tamiya manual that requires actually and careful reading... IMHO.
very farnie Tamiya guy! bet chu laughing your skinny japanese butt off, yes prease?
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 07-23-2010, 06:06 AM   #740
reenmachine's Avatar
Trader Rating: 26 (100%+)
I've seen the steering "note direction" and the subtle "diff flip" in several other Tamiya manuals...it's just the way they like to do it I suppose. People get it wrong every time too and are on here asking about it!
Makes you wonder how many messed-up Tamiya cars are out there with owners who don't happen to use the forums.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-23-2010, 06:22 AM   #741
Finally got mine up and running and got some practice in yesterday afternoon. It was quick and fun to drive with a 540J in it geared 85/50.
I need to find more steering, but I can work on that. It had a pronounced push at higher speeds.
It came off a little hot, but I ran it at least 10 minutes non-stop. I'll be racing it this Sunday and will check temps regularly.
I'm going to open up a few cooling holes in the area between the body's upper and lower grille areas to help cooling -- they'll blow directly on the can. With the body fitting snug against the bumper there is basically zero airflow to the motor. I'm going to get the heat sink bars as well.
Pete Waydo
Old 07-23-2010, 08:36 AM   #742
OSherman's Avatar
Thumbs up
sweet lookin Golf!!
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-23-2010, 08:55 AM   #743
OSherman's Avatar
Thumbs up
Originally Posted by Hebiki View Post
im not building mine until the diff halves are in stock.
Originally Posted by rtypec View Post
Bah...just build it. The stock ones are fine until you need to replace them, then use the good stuff Just remember to glue the diff rings with whatever you think works. I used a super microscopic thin coat of shoe goo applied with an exacto, then put the rings on and spun them to evenly distribute the glue, then built the diff with loose tension to put atleast some pressure on the rings until the glue dried. Finally adjustments were done in car.
sonova.... im all out of excuses.
[RANT] Why do spur gears cost more than pinion gears? Is it because they can strip and then be considered a consumable item? Thanks to the "gear cover" rule, my little $35 collection of ginormous pinions and tiny spurs will now grow with additional sets of quarters and silver dollars...hmm might actually be cheaper to machine coins with teeth. [/RANT]
In all seriousness, thanks for posting the actual spur/pinion combo that will work with the gear cover as that saves guess work/money. There is a video some pages back that shows an FF-03 geared at 88/59 for FDR of 3.88
throwing in my super-dooper diff halves and super-dooper-jupiter gears tonite.. game on tomorrow...
bring em out..
•KO Propo America
•EXOTEK
Old 07-23-2010, 10:14 AM   #744
Hebiki's Avatar
bring em out..
got those bits..and i STILL havent started building.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-23-2010, 10:22 AM   #745
OSherman's Avatar
SLACKER!!!
•KO Propo America
•EXOTEK
Old 07-23-2010, 10:27 AM   #746
Hebiki's Avatar
SLACKER!!!
not slacking...just completing challenges for my assault rifles.
Hebiki Design Works
Old 07-23-2010, 10:29 AM   #747
OSherman's Avatar
Thumbs up
i dusted off and wired in two old GTX speedos to assault you on the track.. BRING IT!!!
old relics that will do the job just fine...
question... SCHOTTKY diode... stripe is positive or negative?? its been a looonnnggg time.. lol
•KO Propo America
•EXOTEK
Old 07-23-2010, 10:32 AM   #748
Hebiki's Avatar
ill bring something... might not be worth anything since i wont run FF03 at nats (uh... porsche body.. bleh).
Hebiki Design Works
Old 07-23-2010, 10:33 AM   #749
Hebiki's Avatar
i dont have one on my esc/car. someone hopefully answers.
Hebiki Design Works
Old 07-23-2010, 10:43 AM   #750
OSherman's Avatar
BEULLER!!??
•KO Propo America
•EXOTEK
Tamiya Championship Series Neil Rabara Racing Forum 21026 05-25-2017 08:50 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5789 04-27-2017 10:11 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 724 04-03-2017 12:43 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
