Like Tree19Likes
Old 04-21-2010, 07:13 PM   #61
colt1402's Avatar
Trader Rating: 84 (100%+)
Come on Tamiya, I NEED ONE OF PRO KIT NOW!!!!!!!!!!!!!!!!
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-21-2010, 11:55 PM   #62
JD Skyline's Avatar
Originally Posted by José Cordeiro View Post
Superb!
Tamiya sure knows how to feed your addiction. Been suffering from it for more than 25 years now...
TAMIYA is the brand of many of our lives, right guys???
Cheers,
Yes i've been suffering from this virus/addiction and I love it. Like I already said this FF03 chassis looks just great. If this chassis is released in Europe I will take the pro version to my local race track. Thanks to OSherman we do know the probable release date . That will be somewhere in June( this year??) so I'm saving my money for june to buy 2 pro versions and one Honda version.
JD Skyline
"NO GUTS NO GLORY"
Still lookin.......
http://jdskyline.blogspot.nl
JD Skyline is offline   Reply With Quote
Old 04-22-2010, 05:14 AM   #63
speedemall's Avatar
Trader Rating: 37 (100%+)
Superb!
Cheers,
I too have been a Tamiyaphile since 1982 and I hope to someday have every vehicle they have ever had but I'm sure it'll never happen.
speedemall is offline   Reply With Quote
Old 04-22-2010, 06:41 AM   #64
knd
why everybody says the ff cars are faster than 4wd in RC?
Aren't they dificult to drive in corners?
knd is offline   Reply With Quote
Old 04-22-2010, 06:45 AM   #65
colt1402's Avatar
Wait till you driven a M-chassis FWD minis... They're so FUN & EASY to drive... I doubt the FWD can beat any 4wd that easily... Need to put in lots of hard work & speed in order to beat a 4WD... Most importantly, FWD cars drive like a charm...
Old 04-22-2010, 07:21 AM   #66
JD Skyline's Avatar
I'm also trying and you know what .. I'll probably always keep on dreaming about having all the Tamiya RC vehicles. But the FF03 will be a nice addition for my collection. I liked the FF chassis very much. I used to have a FF01 chassis during the mid and late 90's. Unfortunally I sold it
Like Colt1402 already said" Most importantly, FWD cars drive like a charm... " I couldn't agree more.
JD Skyline
"NO GUTS NO GLORY"
Still lookin.......
Old 04-22-2010, 02:07 PM   #67
Barry White's Avatar
Tamiya Shizuoka News – Castrol Honda Civic
The fifth generation Honda Civic (EG) was first released in 1991. It featured larger dimensions and a more aerodynamic body than its predessors.
About the Model
This is a 1:10 R/C assembly kit model of Team Castrol’s Honda Civic VTi which competed in the British National Saloon Car Cup in 1993.
Polycarbonate body captures the sporty form of the Civic.
The newly designed FF-03 chassis features horizontally-placed front-motor and front wheel drive 2WD setup.
Front-motor layout provides unique cornering characteristics specific to front wheel drive chassis.
Short reversible suspension arms with inboard front suspension setup.
Equipped with 1050 ball bearing specification uprights, front ball differential, and CVA shock units.
Medium narrow 5-Spoke white wheels included.
A wide variety of Option Parts is available for you to further customise your machine:
54230 FF-03 Stabilizer Set (Front & Rear)
54233 FF-03 Aluminium Diff Joint Set
54234 FF-03 Aluminium Spur Gear Mount
58467 1:10 R/C Castrol Honda CIVIC VTi (FF-03 Chassis)
Availability: June
Barry White is offline   Reply With Quote
Old 04-22-2010, 02:12 PM   #68
Tamiya Shizuoka News – FF-03 PRO Touring Car Chassis
Tamiya is proud to announce the release of the FF-03 PRO, the newest touring car chassis kit in their line-up. The FF-03 chassis features a horizontally-placed front-motor, front wheel drive and comes enhanced with a range of high performance parts to offer you a new driving experience. Due to its unique chassis layout and FWD setup, you can enjoy a style of driving different from 4WD chassis machines. The chassis features a newly designed lower deck and comes with a compact front gearbox. Suspension is equipped with short reversible suspension arms and TRF416 uprights on the Inboard Front Suspension (IFS) setup. True to its name “PRO”, high-spec parts such as TRF dampers, aluminium turnbuckle shafts, and aluminium ball connectors are also included in the kit.
About the Model
This is a 1:10 R/C assembly model kit.
Chassis length: 384mm, Overall width: 185mm, Tread: 157mm, Wheelbase: 257, 245, 233mm.
FWD chassis features front-mounted motor and is designed for optimum weight distribution and a low centre of gravity.
Body, tyres, ESC, motor, R/C unit, battery and charger not included.
Front suspension features the IFS setup.
The damper mount is equipped with stabilizer holders.
3 wheelbases (257, 245, 233mm) can be assembled by replacing rear block parts.
Rear dampers can be installed to either side of the suspension arms.
Slim chassis features longitudinal battery position.
R/C unit is placed on each side for optimised chassis balance.
Motor is securely attached to blue-anodized aluminium motor plate which enhances dissipation of motor heat.
The compact gearbox is equipped with a large-sized ball differential.
FF-03 PRO Chassis Kit includes the following Option Parts:
Item 42102 TRF Special Damper (Hard Black Coating) plus Titanium Coated Piston Rods and White Coil Springs (Medium x2, Hard x2)
Item 51000 Hi-Torque Servo Saver (Black)
Item 53159 4mm Anodized Aluminium Flange Lock Nuts (Blue)
Item 53642 5mm Aluminium Ball Connector (Blue)
Item 54121 Aluminium Horn For Hi-Torque Servo Saver
Item 54223 FF-03 Aluminum Motor Plate (Blue)
Aluminium Turnbuckle Shafts (Blue)
5mm Adjuster (Grey)
The following Spare, Option, and Limited Edition parts for FF-03 Chassis machines will also be released in conjunction:
51419 FF-03 B Parts (Bumper)
51422 FF-03 M Parts (Damper Stay)
51423 FF-03 06 Spur Gear (68T)
54223 FF03 Aluminium Motor Plate (Blue) (Tentative)
54226 3/32 Inch Tu Ball (12pcs.)(Tentative)
54227 FF-03 04 Module Spur Gear (102T)
54228 Fluorine Coated 06 Module Pinion Gear (26T, 27T)
54229 Fluorine Coated 06 Module Pinion Gear (28T, 29T)
84130 FF-03 Ti Screw Set
FF-03 chassis machines are compatible with many 1:10 R/C touring car Spare Body Sets, but they are NOT compatible with the following:
Item 50809 Peugeot 306 Maxi WRC Body Parts Set
Item 51223 Audi A4 DTM 2005 Lightweight Body Parts Set (Finished)
Item 51265 ADVAN Courage LC70 Mugen Body Parts Set (Finished)
Item 51288 BMW 320si WTCC 2006 Team Germany Body Parts Set
Item 51292 EBBRO 350R Body Parts Set
Item 51295 BMW Z4 M Coupe Racing Body Parts Set
Item 51306 Raybrig NSX 2007 Body Parts Set
Item 51322 Nissan Fairlady Z Version NISMO Body Parts Set
Item 51357 ARTA Garaiya Body Parts Set
Item 51359 Xanavi NISMO GT-R (R35) Body Parts Set
Item 51395 Corolla Axio apr GT Body Parts Set
Item 51396 BMW M3 GT2 2009 Body Parts Set
Item 51401 Lancia Delta Integrale Body Parts Set
58463 1:10 R/C FF-03 PRO Chassis Kit
Availability: May
Old 04-22-2010, 04:57 PM   #69
reenmachine's Avatar
Trader Rating: 26 (100%+)
So I'll ask the obvious question -- what are the odds of a RWD version?
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 04-22-2010, 06:13 PM   #70
Kyuss's Avatar
Im hoping that the spur will be replaceable with standard spurs!
Kyuss is offline   Reply With Quote
Old 04-22-2010, 08:03 PM   #71
colt1402's Avatar
Let's keep our fingers cross!!
Unlikey can use any after market spur gears, on the earlier post parts list. There're specific ff03 spur gears part number for it...
Old 04-23-2010, 12:32 AM   #72
Trader Rating: 44 (100%+)
Yay I can get a civic eg body 2 though I probably wouldn't run it...I'd get something else to run like an rsx body
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 04-23-2010, 01:17 PM   #73
AWK
AWK's Avatar
Found this on another forum:
AWK is offline   Reply With Quote
Old 04-23-2010, 01:31 PM   #74
Cool that you found it on our Roadrunners RC Club forum, but I put it there after finding it in this very thread just a couple of pages up!!
Pete Waydo
Old 04-23-2010, 01:35 PM   #75
JD Skyline's Avatar
But still this pro version looks GREAT!!!!!!!!!!!!!!!!!1
JD Skyline
"NO GUTS NO GLORY"
Still lookin.......
Tamiya Championship Series Neil Rabara Racing Forum 20951 03-18-2017 03:26 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5779 03-01-2017 03:07 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
