Like Tree22Likes
Old 07-20-2010, 07:17 PM   #706
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by old-man View Post
Check your trust bearing. A crushed trust bearing will cause the diff to undo itself. The M05 has the same problem.
Very true. THe ball diff in the FF03 is very similar in build to the M05 and the M05 ball diff is rubbish .. it comes undone all the time
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 07-21-2010, 02:54 AM   #707
NiMo's Avatar
Had it all apart and checked, all parts seem ok.
Only thing I have noticed was that I had put the diff bolt in from the wrong diff half (side with lip) and that the bolt was on the wrong side in the car.
Am now rebuilding taking careful note of the manual (lots of bits easy to miss)
Have also noticed a lot of play in the steering already
NiMo is offline   Reply With Quote
Old 07-21-2010, 03:10 AM   #708
foampervert's Avatar
Send a message via MSN to foampervert
Default Just too weird...
I think it's a travesty to match the porsche gt3 shell with the ff03... And not only that, but to enforce it as THE ONLY shell people can run? What? Is TCS sponsored by Porsche?(if it were, that'll be different)
Tamiya makes (and is re-releasing) many awesome fwd shells. Not to mention all the other shells that do actually fit. It doesn't make for exciting racing (or hobby) if everyone races with exactly the same shell... How incredibly boring TCS is.
And also such a no-brainer... Set the gearing, install the silver-can, use the tcs approved battery, cover it with the approved bodyshell... Wow! Let's see... Might as well give them a setup sheet they have to follow strictly...
Yawn.
-Alexander
Originally Posted by reenmachine View Post
GT4 Rules for the TCS NA Finals:
1. Legal chassis platform: FF-03
2. Body Rule: For the TCS Finals the Porsche 911 GT-3 Cup body must be used. There are two available. Items 51336 and 51361. The kit Polycarbonate wing must be used.
3. Motor rules: The Silver Johnson 540J-two hole slot version, (item 53689), motor must be used for racing in this class.
4. Battery rules: Any TCS legal battery is legal for this class.
5. Tamiya 24mm tires and spoke wheels only. (Dish wheels are banned from GT-4)
6. Any pinion and spur gear ratio combo is permitted as long as the gear cover fits. The gear cover must be used. Helpful hint for the Tamiya Track. For a 5 minute race we have found the optimal final drive to be 3.85. The best spur/pinion combo for this is 80/54.
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 07-21-2010, 03:19 AM   #709
NiMo's Avatar
I ran with the Tamiya Vectra, and not only did it perform well, i also had a few of the top modified drivers (Chris Grainger & co) say it looked like a proper Touring Car
Old 07-21-2010, 03:27 AM   #710
old-man's Avatar
100% agree to that. We had the first FF03 race here in Malaysia recently
http://www.rctech.net/forum/malaysia...enmarie-8.html
All the shells looked awsome(thats before we destroyed it!!) in the FF03 class. The drivers to picked up some real BTCC driver names to make the class more interesting.
old-man is offline   Reply With Quote
Old 07-21-2010, 03:38 AM   #711
NiMo's Avatar
I picked up this HPI BTCC Mondeo from 2000 series, it is a 200mm shell but was half price, and it has a scale rear wing as well as a racing rear wing.
Just looking at the suspension mounts. FF looks to accept up to 1A, so can work out the rest for extra car width (I don't have to worry too much on width as I am running as a non championship car, just there to boost grid numbers and have fun, my GT car is my main car).
Old 07-21-2010, 04:30 AM   #712
cannon's Avatar
Yes ... small writing in the middle of the diff assembly instructions says ..."turn upside down" ... very nasty trick
Old 07-21-2010, 04:33 AM   #713
cannon's Avatar
80/54 ???????? WOW ... where do you hunt down 54t pinions?
Old 07-21-2010, 04:37 AM   #714
finished buidling my FF03 PRO, i have noticed that the steering turns more on the right then in left. once i turn the car to the left, the push rod is hitting the servo saver.
i test run it and has little turning radius to the left.
has anyone encountered this problem? any solutions aside from replacing the servo horn?
jebolution is offline   Reply With Quote
Old 07-21-2010, 04:44 AM   #715
NiMo's Avatar
Another case of things not being clear in the manual
Looks at the page VERY carefully and you will see it tells you to cut the back of the cup away.
(I missed it also)
Old 07-21-2010, 05:01 AM   #716
(I missed it also)
thats what i did... read and followed the manual carefully. but everytime i turn to the left, the pushrod shaft (plastic) is hitting the round part (aluminum) of the servo horn.
Old 07-21-2010, 05:08 AM   #717
NiMo's Avatar
Page 15, Section 30, bottom of page.
Where it has the 17mm bit, look to the left and read writing above.
I missed it until I found the same problem
Old 07-21-2010, 05:17 AM   #718
@jebolution,
Did you trimt the servo saver under an angle of 10?
I thought you have to do this towards the steering or to the front of the car.
addicted2blue is offline   Reply With Quote
Old 07-21-2010, 05:21 AM   #719
NiMo's Avatar
I had to lengthen the steering rod by 1 turns to get even steering
Old 07-21-2010, 05:26 AM   #720
Originally Posted by addicted2blue View Post
@jebolution,
yes, as per manual.
oh and when i turn right, the front right knuckles is hitting the shocks pushrod too... and if i turn left, has a big clearance. but thats not an issue
i removed the steering rods to check the length and both are the same, 15mm in length.
Tamiya Championship Series Neil Rabara Racing Forum 20961 03-28-2017 11:31 PM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5782 03-26-2017 03:14 AM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 723 02-09-2017 08:16 AM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 11:28 AM
