Old 07-14-2010, 11:09 AM   #676
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by foampervert View Post
Hiya folks,
A slipper might be an interesting add-on if you whack hard.
Do try it and share your findings!
-Alexander
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-14-2010, 11:35 AM   #677
OSherman's Avatar
Default Parts.
All i want is new parts in stock... car is perfect as is.. who has diff-halves in stock? Plastic or Aluminum..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 07-14-2010, 11:44 AM   #678
Default Diff halves available
I just ordered the aluminum diff halves and sway bars from Tamiya this morning. I also ordered a few sets of the idler gear to replace the damaged one I have and also some spares. Get the diff halves while available.
Budster is offline   Reply With Quote
Old 07-14-2010, 04:33 PM   #679
I've had my first run with my FF03 PRO and it was a plesure to drive it.
I've made some small adjustments about the setting and it made a big difference.
Only negative thing is the sloppy spur gear holder, after 30 minutes of driving my spur is totally wasted cause of it's being sloppy
It was a brand new FF03 102T spur gear
Overall the car performs great, great handling and well balanced in corners.
Even the speed at/in corners is amazing, i don't think there is a big difference between a FF03 and a 4WD at/in corners.
With a good set-up the difference will be minimum.
I also noticed that the car is (compared to a standard TA05) very light.
My car weights 1370gr with a heavy body (that also is being reinforced with alu tape) and a Lipo orion 3800 battery.
It sure is a great car and i could recomment it to everyone.
addicted2blue is offline   Reply With Quote
Old 07-14-2010, 05:07 PM   #680
OSherman's Avatar
Thumbs up
No center pulley, no belts, one less diff assembly, 1 less set of driveshafts, fewer quantity of bearing, smaller rear bulkhead.. All weight savings and less maintenance..
•KO Propo America
•EXOTEK
Old 07-14-2010, 05:07 PM   #681
Hebiki's Avatar
im not building mine until the diff halves are in stock.
Hebiki Design Works
Old 07-14-2010, 07:48 PM   #682
rtypec's Avatar
Bah...just build it. The stock ones are fine until you need to replace them, then use the good stuff Just remember to glue the diff rings with whatever you think works. I used a super microscopic thin coat of shoe goo applied with an exacto, then put the rings on and spun them to evenly distribute the glue, then built the diff with loose tension to put atleast some pressure on the rings until the glue dried. Finally adjustments were done in car.
rtypec is offline   Reply With Quote
Old 07-14-2010, 08:11 PM   #683
Diff halves are available at Tamiya as of this morning.
Old 07-15-2010, 04:10 AM   #684
RC MARKET's Avatar
Spur Gear mount
Castrol Civic VTi Kit
RC MARKET is offline   Reply With Quote
Old 07-15-2010, 09:57 AM   #685
OSherman's Avatar
Thumbs up
Bits are coming this week @ SpeedTech
Build it already SUCKA!!
•KO Propo America
•EXOTEK
Old 07-15-2010, 12:32 PM   #686
Hebiki's Avatar
sonova.... im all out of excuses.
Hebiki Design Works
Old 07-16-2010, 02:17 PM   #687
stitchy's Avatar
Aluminum diff joints and sway bar kits are IN at speedtech!
Quantities are extremely limited...we are expecting more stock next week.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-16-2010, 03:06 PM   #688
stitchy's Avatar
Oh yeah, and a couple of the heat sink bars too.
Old 07-17-2010, 01:50 PM   #689
Ok a quick question for those that have already fitted the golf bodyshell, how well do the marks in the bodyshell line up with the body posts ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 07-17-2010, 01:59 PM   #690
NiMo's Avatar
Got to run mine today, had to do almost no set up changes from kit settings, but I have noticed an excess of wheelspin/diff out when steering not straight.
Speed was good with a sealed can motor, 41mph.
NiMo is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20851 01-17-2017 10:21 PM
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF Mike Schumacher Electric On-Road 711 01-08-2017 09:27 AM
M03/M05's - The Aussie Mini Racing thread tony gray Australian Racing 5774 09-23-2016 10:49 PM
New Gen Front Wheel Drive Touring Cars (TAMIYA FF-03 PRO, T.O.P. Sabre FD) Rod M Australian Racing 34 06-11-2012 12:28 PM
SEO by vBSEO 3.5.0
